Question about Whirlpool GS460 Gas Kitchen Range
Oven door came off
While sliding the oven out for cleaning the door accidentily came off. Is there a trick to getting the hinges back onto the pins in the range frame?
Got it fixed! I found the owners manual posted on another site with replacement instructions. Expand the hinges from the door and insert a nail or screw into the hole there to hold hinges open. With hanging slots parralel to pins in oven frame slide back into place.Once in place open door completely and remove screw or nail. Couldn't be easier.
Posted on Jul 01, 2008
Whirlpool oven door
Hi ShellBrokeIt,
Pivot the hinges outward, and GRop the door by both edges,  Feed the slots of the door onto the hinges and slide it on, Close the door and your done.
Oct 16, 2007 | Whirlpool GR478LXP Electric Kitchen Range
Installation oven door
In order to reinstall the door you will need to extend the hinges out on both sides...You will notice a small hole at each hinge..Insert a nail in to each hole (one on each hinge)...Set the hinge so that the it is extended outward with nail in place...Once completed set the door back onto the oven with hinges inserted into slots in housing....Open the door as far as it will go...Remove the nails ..The door should now work properly..
Apr 20, 2010 | Whirlpool GS460 Gas Kitchen Range
I lifted the oven door off to clean it and now I can get it to go back on. Is there a trick to putting the removable door back on?
Hello.The hinge levers need to be pulled open to the first click.(partially open if the door was on)The door should slide back on the hinge arms and maybe click into place.
builderdale
Feb 28, 2010 | Kitchen Ranges
How to remove door for whirlpool oven RBS305PDB2
open the door about 1/3 of the way and lift it off the hinge pins. it helps to have two people do this. when it is time to replace it, put the hinges in that 1/3 open position and slide the door back down on.
Oct 02, 2009 | Whirlpool RBS305PD Electric Single Oven
The oven door fell off how do i put it back on?
hi. most oven doors are removable. Since yours is off let me help you put it back on. The hinges will pull out and stay out about 1/3 of the way. Get both hinges situated that way and then carefully slide the door back onto the hinges thru the slots on the bottom of the door. This is easier if you have another person to assist you.
Jul 05, 2009 | Ovens
Cant get the oven door back on
Use a wrench to lower the hinge arms down. There is a hole in the arm that you can put a nail into through to the frame of the oven/ This should leave the arm in an outward position. Do this on both sides of the oven, or both hinges
Pick up the door, and slide the door onto the arms until they stop.
Press down on the top end of the door lightly so that you may remove the nails inserted above.
Lift the door to close. If you didn't slide the door onto the hinge pieces far enough, then repeat the procedure.
Jan 24, 2009 | Frigidaire GLEB27S7A Electric Single Oven
Whirlpool range
Hello dolphin 1 mom
Welcome tofixya.
You said, accidentally removed the door to my range and now it won't go back on. The door won't go back into the slots on the range.
Send me your e-mail address and I'll e-mail the diagram with the door instructions for removal and replacement.
It will not fit in here with the diagrams.
Waiting for you.
Huuum
Please do not forget to enter a rating when we are done
These are the installation instructions, but with no diagrams
To Remove:
1. Open the oven door. Insert door removal pins, included with
your range, into both hinge hangers. Do not remove the pins
while the door is removed from the range.
2. Slowly close the door until it rests against the door removal
pins.
3. Grasp the door on the sides with your fingers on the front of
the door and your thumbs on the inside surface.
4. Pull door straight up, then toward you. Hinge hangers will
slide out of front frame hinge slot. Do not remove door
removal pins until the door is replaced on the range.
To Replace:
1. Grasp the door on the sides with your fingers on the front of
the door and your thumbs on its inside surface.
2. Hold oven door so that the top edge of each hinge hanger is
horizontal. Insert hinge hangers into the front frame hinge
slots.
3. Tilt top of door toward range. Slide hinge hangers down onto
front frame support pins. Make sure the hinge hangers are
fully seated and engaged on the support pins.
4. Insert the door stop clip with its angular surface at the top of
the frame hinge slot, then push in the bottom of the clip until
its flanges are flush with the front frame.
5. Open the door completely and remove the door removal pins.
Save door removal pins for future use.
6. Close the door.
StorageDrawer
The storage drawer can be removed. Before removing, make sure
drawer is cool and empty.
To Remove:
1. Pull the storage drawer straight back past the drawer stop
notch and the end of the side rails.
2. Lift up the back of the drawer and pull the drawer out.
To Replace:
1. Lift up the back of the drawer and place it inside the range in
its fully forward position.
2. Lift up the front of the drawer to a level position.
3. Slowly push the drawer into the range until the drawer side
rails engage with the gap in the drawer glides.
4. Once the drawer is fully engaged on both sides, slide the
drawer back into the closed position.
NOTE: When removing and replacing the storage drawer, a slight
push may be needed to move the drawer stop notch past the
drawer glides.
A. Removal pins
B. Hinge hanger
A. Hinge hanger
B. Door frame hinge
C. Support pins
A
B
A
B
C
A. Drawer stop notch
B. End of side rail
A. Engage drawer glide
A B
A
Sep 09, 2008 | Whirlpool GR465LXLS Electric Kitchen Range
Oven door
I know on the older units it usually slides right back on. You might have to pinch the locking part of the hinge together, as it will have a spring that lets this happen. Once together, slide door onto hinge slowly. Too fast and it might slide past where it needs to go; if so, just pull back as if you are trying to remove for servicing. It should snap into place. Hope this helps. I might be able to tell you more if I knew the model#, type, etc.
Dec 23, 2007 | Jenn-Air JJW8130D Electric Single Oven
MAYTAG (AMANA) OVEN DOOR
I finally got my door back on, I had to wedge a butter knife in the hinge to keep it open, then I could put it back on the pins and slide the metal cover/locking thinge over it. Was a pain in the ass.
DANGdoor
Nov 27, 2007 | Maytag MER5755QAS CleanDesign Electric...
Whirlpool GS460 Gas Kitchen Range Logo
277 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
