Question about Sony KDS-R60XBR1 60" Projection HDTV
Its happening to me...
O my gosh.. the same thing is happening to me.. the tv keeps on blinking the red lights on four times.... and it costing me a lot to fix it....it would worked then it wouldnt.... please give me a suggestions.. thanks.
Four blinking lights means one of your fans are dead. You need to find which one isnt working and replace it. It cost me $19 to order the fan and is an easy fix.
You have to take off the back cover and turn the tv on and see which one doesnt spin and replace it.
Posted on Apr 11, 2009
  • nicollopez Nov 12, 2010
    Where did you order your fan from?
Why wont my sony kv-30hs420 tv wont turn on? When i try all that happens is the red light will keep blinking seven times!
My TV continues to blink on Standby with Red light ...
https://community.sony.com/t5/...blink...Red-light-flashing.../59141
Jan 12, 2013 - I need help with my Sony TV. The red flashing light keeps going on and off. ITs on standby. can someone guide me as to how to fix the problem. ... I have a Bravia KDL52W3000 with a 7" wide dead pix... Television - Picture & Sound ... What is the exact model number of the Sony TV? Check if the same issue ...
Nov 14, 2015 | Sony Televison & Video
Red light blinking four times, pause, four blinks again, etc. etc.
Only a repair shop can tell you what you ask .SORRY
Oct 05, 2015 | Televison & Video
Why my Sony Wega tv standby light blinks 10 times?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Aug 23, 2014 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I have a Samsung TXF2899 28" TV that is not turning on. When I press the power button on, I hear the power-on sound, it's red power indicator light blinks 10 times as if running a test but then...
It's running through a self diagnosis when the light blinks. The 10 blinks just happens to be how long it take to find a problem. Would have to be plugged into Variac and started at about 90 volts in order to keep it from shutting down. The life of a Television is averaged at 10 years, however most last longer and it could be something very simple to fix or something major. Thing is get an estimate from a reputable co before having it fixed and consider the cost to repair, age of the TV vs the price and warranty of a new one.
dhgill1949
May 22, 2011 | Samsung TXF2899 28" TV
Tv light standby red just keeps blinking after replacing bulb
If red light was not blinking before lamp replacement and after that it start blinking 3 times then pause for three seconds and again blink, check lamp cover that has not been fixed on tv or it is not fixed/ seated correctly there.
Lamp cover is first thing that you removed from tv to replace lamp.
Hope these info will help. If red light is blinking other than 3 times, let me know how many times it is blinking along with tv model number written at rear to provide you helpful info.
Thanks.
Jan 27, 2011 | Sony Grand WEGA KF50WE610 50" Rear...
No picture or sound. Red light blinking four times on sony bravia tv. Suspect power supply problem?
Red light blinking 4 times on Sony bravia TV.This is the problem of INVERTER BOARD.The inverter board has to be replaced.Every Sony bravia tv has a particular model number and the Inverter board part number depends on model number of the tv. As you have not mentioned the model number so the exact part number of the inverter board is hard to tell.But you can get the required inverter board part for your tv from www.partstore.com ----------- Thanks. Keep updated for any more query. You can rate thissolution and show your appreciation.
Aug 18, 2010 | Sony Televison & Video
Set wont turn on, stand by lights blinks 9 times
Have the same thing happening with ours... we were told by a repairman that it needs a new D Board. He told us that if we could fix the TV for under $500 that it was worth it, if not (which of course, we can't when you add in labor cost) don't fix it. I like the TV but I can buy a brand new flat screen for that!
Good Luck
Mar 29, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
My Sony HD-TV KDF-50E2000 is about 18 months old. The picture went out. The green on light stays on for only a few minutes then goes off and the red lamp light flashes. You can turn the Tv on again and the...
How many times Red Lamp flashes, its important as it shows problem and its location in tv. Below is detail of lamp blinks and you may know the problem area in tv by counting lamp flashes.
Need further help, let me know.
Sep 13, 2008 | Televison & Video
Red lite blinking
help mine is doing it also, 4 blinks, no power
if any gets it fixed or knows how please email me at
ron1978@comcast.net thanks
Dec 27, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony KDS-R60XBR1 60" Projection HDTV Logo
162 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
