Question about GE Dishwashers
Our dishwasher, GE model # GSD4800, installed in Oct.'03,is emitting a bad odor. We do have a GE disposer, but there are no odors or problems with that appliance. I am not sure if the DW drains thru the disposer or not. Is there anything I can do with the DW (such as look for a drain trap, etc.) or do I just call a plumber? Thank you.
  • 983 Answers
There is nothing within the construction of a dishwasher that can cause bad odours.
If your dishwasher smells it can only be the result of food debris left within the appliance because of a poor or faulty house drainage system, incorrect installation of the dishwasher drain hose or some sort of blockage in the drain pump (see Dishwasher Will Not Drain). Less likely is a problem with the water supply.
It is a good idea to run a dishwasher cleaner through the appliance every three months or so. You can find these in most supermarkets, usually in the same area that other dishwasher products are displayed. Make sure that you also clean and wipe the edges of the door and the door seal, especially at the bottom of the door.
Posted on Jul 01, 2008
    Master:
  • 638 Answers
Its a normal problem every dishwasher comes to this stage after some period .it is the problem of all the food remains stuck to your unit in the corners for a long time in your unit .its the time for a servicing required for the unit.a plumber is good idea.but a professional service technician will do it in much better way and also provide you the garrantee for near about six months if the same problems presists.and that to not more than his service charge he will charge you.
rate the solution as "FIXYA" if you get helped by it.thank u in advance. wish u success .bye
    Genius:
  • 2,028 Answers
There is a DW protein cleaner you can get at Walmart that is for f getting rid of food buildup that creates bacteria and odor. Oxyclean has worked well in mine.
I have a GE Advantium microwave model 2001 scb2001 03. It stopped working in the middle of a cooking and power goes completely out. A few days before that there was metal odor when using microwave
Betty, it sounds like you might have 2 problems and the power shutting off could be an end result of the metal odor you described. The power shutting off, more than likely is just a blown fuse. That is usually a simple and in-expensive repair. The metal odor could come from either your magnetron or from the high voltage transformer. Either one of those is going to be a rather expensive repair and if repair part stores in your area are anything like in my town, unless you repair them for a living or know someone who does, you can have some difficulty in getting those parts. Sorry for the bad news, but it might be simpler to just replace the microwave.
Feb 05, 2015 | GE Microwave Ovens
Bosch dishwasher model she6af02uc/03 odor
try running some bleach in the wash cycle
Aug 28, 2012 | Bosch Dishwashers
My 86-year-old mother purchased a Kenmore microwave (small/red/abt. 70 dollars) last week at KMart. When she used it, it emitted a bad odor. She returned it and got a replacement, same model. Same odor....
I do not know what the odor is from, but I would take it back, ask for another, have them open it there in the store, plug it in, test it. If it stinks, have them go through the lot, or ask for A. money back, or b. the next model up in exchange for your trouble.
Feb 24, 2011 | Vacuums
Continuous Odor in the machine
I would check your drain line. If its connected to the disposal make sure its elevated you may be getting back flow from the disposal into the dishwasher. Hope this helps _MJ_
May 20, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Our jenn-Air built in dishwasher smells foul and has since the first time we used it 4 months ago. we have tried bleach, vinegar, finish brand dishwaher cleaner, less soap, cascade soap, running every day,...
We had similar type of problem (as well as residual water always left in bottom) and after pulling out the dishwasher, found that the drainage tube was incorrectly installed by contractor. It was laying on the floor behind it with a only a slight rise to the garbage disposal inlet. I suspect this contributed to sewer odors as well a water back flowing into the dishwasher. I disconnected drainage tube so that it went up 24+" and then connected to garbage disposal (creates a loop that blocks sewer odors and back flow conditions). I also cleared out the filter at bottom of inside the dishwasher. The Use & Care Guide suggested using baking soda in China/Crystal mode for 10 minutes, opening the front door and letting it sit overnight. I repeated that for 3 nights and it did clear up the remaining odor. Don't know if this will help your issue or not. Good luck!
Jan 09, 2010 | Jenn-Air 24 in. JDB1090AWS Stainless Steel...
Odor in dishwasher
Dishwasher must be cleaned on a daily basis.
This will prevent the sediments coming from the
dirt of the dishes to rot, and emit gas (bad odors).
Try this recommendation, and see the results.
Sep 23, 2009 | Dishwashers
New Kenmore Dishwasher Model 587-1401 has a toxic smell
Use a descaling agent.Clr (calcium,lime,rust) remover availiable at super markets,drugstores.Pour a cup in and run a couple of cycles.When finished keep the door open to air dry.
Apr 11, 2009 | Dishwashers
Bad odor when open door after cycle
This is just a suggestion, run a cycle and after a few mins of it washing, open the door and add a cup of bleach and let the washer run. See if this helps.
Apr 09, 2009 | Bosch 24 in. SHU66C05 Stainless Steel...
The dishwaser has a bad smell
run unit through acycle or 2 with a bowl of vinegar on lower rack this should clear all odors from machine,does this drain into a garbage disposal?? thats where smell can be coming from if so pour some vinegar down there regularly as well
Jan 25, 2008 | GE 24 in. Profile PDW9880JSS Built-in...
Kenmore Ultra Wash Model 665 Dishwasher
Dishwashers which are properly installed and regularly used won't normally have a problem with bad odors. Check the following: ?Was the drain hose brought in at the top of the cabinet, or down near the floor? it must be 34" from the floor. ?Do you run the unit at least once every 2 days? -Run a cycle with a quart of vinegar to clean the tub and pump. ?Does the disposal tend to back up slightly when the dishwasher drains? Drain may be clogged. -Don't use gel detergent! ?Check your water softener(If so equipped) These can cause foul odors in the water supply if not properly balanced or maintained Good luck!
Sep 02, 2007 | Kenmore 24 in. 17032 Built-in Dishwasher
Dishwashers Logo
186 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
