Is my trutech lcd flat panel digital?
I have a 15" trutech LCD I purchased in January 2007. Is it already digital and ready for the February 2009 change over to all digital broadcasting stations?
  • ajnruy Jul 01, 2008
    Is my trutech Lcd Flatpanel 15" TV digital and ready for the coming digital broadcast station changeover?
  • 4,889 Answers
LCD monitors are compatible with Digital Video Input(DVI) and have the slot for it. Hence you can use it with a Digital signal source.
Regards,
Sai.
Posted on Jul 01, 2008
I have a RCA TV, model L32WD12YX7 purchased from WalMart new in 2007. The Warranty expired in July 2009. My Power supply is flaky. It works if I unplug and replug power cord over and over, but this can...
The failure with the power supply is related to overheating. Flat screens TVs do not have enough space for the internal circuits to cooldown properly causing them to fail.
Check this link to find a power supply replacement for your LCD.
Let me know if you need further assistance.
Jan 08, 2011 | RCA L32W11 32 in. HD-Ready LCD Television
Is my TV digital ready?
I just checked in to this for you. I found a website about this exact television. Here is the link :
http://www.fcc.gov/eb/FieldNotices/2003/DOC-274084A1.html
It says that Target did not put up the appropriate notification on these TVs about them being only analog. You will need a converter box for this TV.
Feb 05, 2009 | TruTech PVS31170S1W 17 in. LCD Television
I have a Trutech PVS31170S1W LCD Tv,do i need a converter box?
Your tv is DTV ready, it has both an ATSC and NTSC tumer. You can recieve analog and digital OTA (over the air) signals.
You will need to connect an antenna and set the tuning band to AIR not CABLE..
I have provided a link with more information on DTV and Antenna's.
http://www.antennaweb.org/aw/welcome.aspx
Let me know if this helps and please rate this solution.  Lone99star
Jan 24, 2009 | TruTech PVS31170S1W 17 in. LCD Television
Trutech 17 LCD TV/VCR Tuner
If the TV was purchased as recently as 2007, then chances are decent that it DOES have the ATSC (digital) tuner. HOWEVER, I cannot confirm this for you on my end with the amount of information supplied. (Remember to include as much information as possible when inquiring, such as model numbers!)
HOWEVER...
If your set was sold as a "monitor", or an "HDTV READY" or "High Definition READY" set then indeed it will NOT have an ATSC tuner. If it was sold as an "HDTV" or "DTV", then it SHOULD have a digital tuner. This is based on my experience as lead TV tech at a local repair shop.
Take a look in the menus, and see what channels appear when you attempt to scan for them (assuming you are using an over-the-air antenna). Almost everywhere in the US now stations are already transmitting concurrently in digital and analog, and if you can receive the digital channels, you have a digital tuner! You can sometimes tell by the aspect ratio (widescreen, particularly on new programming, during primetime; be aware that smaller screen sizes usually are not widescreen). You can also tell if any of the channels received use a decimal or hyphen such as "channel 6.1 or 6-2" If you see this type of naming convention, you most certainly DO have a digital tuner.
Otherwise, you might consider how much you paid for the set- If it only cost you $150 brand new, or was on clearance, you probably do NOT have a digital television. Expect to pay well in excess of this amount for a digital TV. Hope this helps!! please comment with any additional ??'s and I will respond further as necessary until we know for sure what you have going on. Thanks for asking!
Jan 08, 2009 | TruTech PVS31170S1W 17 in. LCD Television
Does my Sanyo CLT1554 15 in. EDTV-Ready LCD have a digital tuner?
Your specs are here, http://reviews.cnet.com/flat-panel-tvs/sanyo-clt1554-15-lcd/4507-6482_7-32013875.html?tag=mncol;psum
unfortunately you have a
  • Analog TV Tuner NTSC
and
  • Enhanced Definition Television (EDTV) Monitor - EDTV Monitor refers to a monitor or display with the following minimum performance attributes:- Display Scanning Format: Has active vertical scanning lines of 480 progressive (480p) or higher- Aspect Ratio: None specified
You need a tv that has this:
Enhanced Definition Television (EDTV) Tuner - EDTV Tuner refers to a RF receiver with the following minimum performance attributes: - Receiver: Receives ATSC terrestrial digital transmissions and decodes all ATSC Table 3 video formats.
So Sorry, the tuner is not Digital.
Jan 05, 2009 | Sanyo CLT1554 15 in. EDTV-Ready LCD...
Toshiba 47WL T66
Correct, its problem of LCD Panel and will be replaced.
No alternate solution for vertical or horizontal lines in LCD Panels.
Nov 10, 2008 | Toshiba REGZA 47WLG66 47 in. HD-Ready LCD...
DTV????????????????????????
From the side of the carton in which it came:
CONSUMER ALERT: This television receiver has only an analog broadcast tuner and will require a converter box after February 17, 2009 to receive over-the-air broadcasts with an antenna because of the U.S.'s transition to digital broadcasting. Analog-only TVs should continue to work as before with cable and satellite TV services, gaming consoles, VCRs, DVD players, and similar products. For more information, call the Federal Communications Commission at 1-888-225-5322 (TTY: 1-888-835-5322), or visit the commission’s digital-television Web site at: www.dtv.gov.
The only other thing I could add to this, is that the Post Office in 2009 will get the task of handing out $40.00 coupons to to anyone wishing to purchase a converter.
Nov 15, 2007 | Sylvania 6620LG 20 in. EDTV-Ready LCD...
HD?
cannot program the tv to verizon FIOS
Oct 28, 2007 | TruTech PVS31170S1W 17 in. LCD Television
Televison & Video Logo
100 people viewed this question
Top Televison & Video Experts
