Question about Garmin nuvi 350 GPS Receiver
Acquiring satellites My garmin nuvi stopped working and I can't get it to acquire satellites. It's about 1 year old.
  • Anonymous Jul 10, 2008
    I have the same problem it's been exactly a year since i got my Garmin and now the Satellite does not acquire a signal.
  • Garmin Master
  • 2,130 Answers
Having taken several Nuvi's apart, the flip up antenna has a 1/4" wide flat flex cable that runs from the flip up antenna assembly to the main board.
The flex cable carries the voltages required to power the antenna assembly and bring the signals back to the main board.
There is actually a printed circuit board in the flip up antenna assembly. It's possible that this is the receiver itself.
The flex cable runs through the round center hinge of the antenna assembly on the right (looking at the Nuvi from the rear) back to the main board.
There is also a magnet involved with the flip up antenna assembly that tells the main board whether the antenna is up or down. If the antenna is down, the Nuvi will NOT look for satellites.
A couple things can happen here that can make your Nuvi not find satellites: Assuming you have tried a hard & soft reset:
1. The antenna flex ribbon cable has become damaged.
2. The antenna flex ribbon cable has become detached from either end (it's held in with just a snap down flap).
3. The magetic switch isn't operating correctly and the main board thinks the antenna is down.
4. The front-end receiver has failed.
If your good at taking things apart (and the Nuvi is a little tricky to take apart), you might be able to verify some of the possibilities I mentioned above.
You might also try looking for a Nuvi for parts on eBay. Maybe you can find one that has a bad LCD screen and salvage the antenna from it.
- Jim
Posted on Jul 10, 2008
Same here. I had mine for 13 months. Tried hard reset, cleared and reinstalled all data and nothing.
I called Garmin, it took a half hour before a person got on the phone. They gave me instructions to ship it back to them and said they would send me a refurbished unit even though it's a few weeks outside warranty.
There are many posts about this problem on this website. Probably why they are not making the flip up antenna on the newer units.
I know it sucks that you paid all that money and it doesn't work. I bought a magellan maestro while my GPS is getting repaired and I already took it back.. Garmin is way better than the magellan.
Posted on Jul 08, 2008
  • 3 Answers
Try flipping the back part up.
2 Suggested Answers
  • 135 Answers
SOURCE: Acquiring satellites
Dear Customer,
Thank you for your recent inquiry regarding yourproduct.
In response to your query, please be advised that it appears to be a common problem . I have called the tech guys and even they r dumbstruck with this problem.
If its under waranty ur replacement cost is $175
Yours sincerely,
Posted on Jul 09, 2008
The touch screenon my Garmin Nuvi 600/650 won't work. What can i do?
This is a common problem with units having the serial numbers beginning with "14V", "12P" and "143". It's caused by a defective SHARP touchscreen and needs to be replaced. Please see this link for more info:
http://www.sharc.net/gps_LCD_repair.htm
- Jim
Jan 21, 2010 | Garmin Nuvi 660 GPS Receiver
Did you try reseting your nuvi?
Jul 09, 2008 | Garmin nuvi 350 GPS Receiver
Garmin Nuvi not acquiring satellite
I am having the same problem with my nuvi 350 and its about the same age. I read on another post it may need a new battery but you need to send it to garmin. I am going to contact garmin directly.
Aug 20, 2009 | Garmin nuvi 350 GPS Receiver
Satellites not found garmin 755
is it getting to the satellites?
if not improve the battery level by charging properly.
Jul 06, 2009 | Garmin Nuvi 660 GPS Receiver
My sons Garmin nuvi 360 has just stopped acquiring
Try resetting everything. The first step is to Start the GPS unit, while it is starting (when the screen turns on) hold your finger in the lower left corner. It will then prompt you to open in maint. mode. Select yes, and go through the menus by selecting next. When a third option is shownsuch as reset, select it. Reset everything including deleting your saved addresses, you will loose all of your saved info but it should start working again. Hope this works for you as it did for me.
Feb 21, 2009 | Garmin Nuvi 350 Car GPS Receiver
my friend has the same unit his will only acquire satellites when unit is plugged in the cigarrette lighter
Jan 24, 2009 | Garmin nuvi 200W GPS Receiver
Wont acquire any satellites
Have you tried an external antenna? The flip antenna's are known to give problems,
May 12, 2008 | Garmin nuvi 350 GPS Receiver
Trouble acquiring satellites
Garmin nuvi
will not acquire satellites
Apr 30, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin Nuvi takes a long time to Acquire satellite
No. 98% of the time it took 45-56 seonds for your NUVI 660. Thats the compagny set up time acquisition and it did very well.
Be sur you had your flip antenna parallel to earth surface.
660 has THE BEST SIRF Chipset for acquiring satellite.
I had 2 NUVI 660 since 2 years. It work much better than those new 7xx series who it really took 2-3 minutes to acquire satellite.
Be sure you update your version to the last one.
----> https://buy.garmin.com/shop/store/downloadsUpdates.jsp?product=010-00540-00&cID=134&pID=400
Best regards
Jan 12, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin nuvi 350 GPS Receiver Logo
191 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
