Question about Refrigerators
Amana refirgerator/freezer combo not working properly
This morning we heard a clicking noise coming from our refrigerator. By this afternoon, the freezer portion was completely thawed out and the refrigerator fan isn't blowing at all. Is it time to get a new one or is this repairable?
  • andy_foulger Dec 10, 2008
    The start relay is showing 12 ohms but increases as I hold the leads on the relay. Do you think this is a bad relay?
  • 481 Answers
It sounds like a bad:
  • start switch (on the side of the compressor) or
  • compressor itself
the start switch clicks  off usually when the compressor is pulling too many amps or the compressor is overheating. if the compressor is not even running then its probably not overheating.
  • so either the compressor is pulling too many amps (bad compressor) or the start switch is bad and cannot handle the amps required to start the compressor.
Posted on Jul 01, 2008
Can a Miele Fridge Freezer, warm in both sections, fan working - be repaired
All too often it IS the fan, but not always the way you think. the impeller on the fan is simple plastic an clips on the motor shaft. and can come off very easily. Since there are not two compressors in many refrigerator/freezer combos due to both production and operation costs, the refrigerator "borrows" some of the cold from the freezer so the fan on the freezer side not operating properly will allow the coils to ice up internally, on those that only have the fan on the refrigerator side this is multiplied by the galley way icing up, blocking the cold air from reaching the refrigerator side
Sep 05, 2014 | Refrigerators
Amana fridge stopped working for 2 days
Do you see any ice buildup on the back wall of the freezer or behind it?
Dec 03, 2012 | Amana AFF2534FE Bottom Freezer French...
Our Amana refrigerator has stopped working. The compressor does not start and is cool to the touch. There are no clicking noises and no signs of life, no fan is running. The freezer and refirgerator are...
If you have power to the plug, then it is either the start capacitor, the start relay or the compressor. IIf it is the compressor it is a major expense, so you will decide how much you are willing to invest in an old one, before you buy a new one.
Jul 07, 2011 | Amana ARB2217CSL Bottom Freezer...
Amana ARB9059cs: compressor makes loud noise (come and go). Refrigerator not working but bottom freezer is working. All lights on. Please advise.
they had problems with some compressors siezing up due to lubrication issues.refrig not cooling probably air flow problem.either fan in freezer section not working,coils iced up,or return air vent blocked
Jan 25, 2010 | Amana ARB9059CS Bottom Freezer...
Refrigerator not cool freezer working
Rick,
This is the generic answer. Use the hair dryer (below) and reset the defrost (look for instructions from Sea Breeze)
Most of these units work with the freezer providing all of the cooling and a thermostat in the refrigerator section controlling a fan in the freezer (where the fan directs cold air from the freezer section to the refrigerator section via a duct in the back).
Look at the rear area of the refirgerator and locate a vent. This vent receives cold air from the freezer to the refirgerator. If you feel cold air coming out of this vent, then there may be no problem, just wait a few hours and recheck the refrigerator temperature.
Look at the rear area of the freezer and locate a vent. This vent provides cold air from the freezer to the refirgerator. Shine a bright light into this vent. You should see fan blades (possibly black plastic). If there is ice on the blades, then you have a defrost problem, and look to other posts on this site for how to manually defrost (or reset the automatic defrost). If the fan blades are rotating, then there is probably a blockage in the duct. Direct a hair dryer (warm setting) through the rear freezer vent and check to see if there is very warm air flowing out of the refrigerator vent (which indicates that the duct is not blocked). While using the hair dryer, you may be able to see the fan blades rotating.
If you do not feel warm air flowing out of the refrigerator vent, then run the hair dryer for a few minutes. (this was my problem, I saw no moisture drip from the vent, which led me to believe that it was more of a dry ice buildup, or that the ice was evaporated (desublimed to be technical).
If there is air flow and no ice buildup on the fan, then reset the automatic defrost. If this is not your solution, either the thermostat or the fan motor is the problem.
KWJ
Jun 22, 2009 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Freezer Quit working
Hi, That clicking noise is the relay/overload trying to start the compressor. Is this under 5 years old?
They have had a lot of problem with these. I might suggest you calling Amana and inquire about the warranty.
If the warranty has expired, you can try to replace the relay kit.
If I can assist you further, please let me know.
Thanks
Vic
May 22, 2009 | Amana ARB2517CC / ARB2517CB / ARB2517CW...
Freezer and fridge not cooling properly
Clean it up. Check under it and behind, clean ,vacume and or blow out all dust and check the fins on the bottom, a soft brush and portable air compressor work really well but very dusty, take out side if possible, or just vacume really well.
Jan 26, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Amana AFD2535DEW freezer/refrigerator with intermittent tempurature swings
I had the same issue. It was the relay overload which essentially provides the extra boost to get the compressor going. The switch tries for about 10 seconds before giving up and then retries 3 - 4 minutes later. In the early stages of failure, eventually it will work and the compressor will kick on. But eventually the switch will fail and will just cycle through the 10 second attempt every 3 to 4 minutes. The part is about $35 - part number 67005560.
Jun 26, 2008 | Amana AFD2535DES French Door Refrigerator
Refrigerators Logo
149 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
