Question about Harman Kardon AVR 235 Receiver
Wont stay on.
My harman kardon AVR 235 wont stay on. When I turn the power on it starts up then says protect and shuts of. Also the front right channle has no sound coming out( for the 3 seconds that it stays on) but all the other channles work fine.How do I fix this?
  • 1 more comment
  • sub guy Jul 01, 2008
    Thanks so much. how much would it cost to get it fixed? Is it just one piece or is it all the little resisters and transisters of the whole channel?
    Is there any way to pinpoint what is blown?
    Well thanks for giving me a starting point. I wouldnt try to solder new pieces in, i'm not that skilled. Now at least I can figure out what is blown. Thanks!
    President:
  • 624 Answers
The only way you can fix this is you have the proper tools and have very good soldering skills. If so, I will post more instructions on how to fix this.
It has a blown channel, it can not be fixed without some good troubleshooting skills. The protect mode is so you don't cause more damage to it. If you continue to turn it on, you may cause more damage.
Your best bet is to take it in to get repaired at a service center.
Let me know if you require more help,
Dave
Posted on Jul 01, 2008
  • 1 more comment
  • Dave DeGain
    Dave DeGain Jul 01, 2008
    The price would depend on just how bad the channel is blown. It would be most likely the 2 output transistors, a couple of resistors and maybe a couple of driver transistors for that channel (if it is a blown channel, sometimes it can be something different but this is most common). The price cost for that type of a repair runs anywhere from $120 to $175 depending on the cost of parts and the labor rates of the shop. This receiver is a decent one, so the repair would probably be less than a new one by a good margin.
    Glad I could be of some help to you.
    Dave
  • Dave DeGain
    Yes, by troubleshooting the circuit. If you have a multimeter you can check most of the components. You would also need a soldering iron, solder, solder wick (to remove solder) and possibly an O-scope (depending on how difficult isolatiing the problem is). it is good to have very good soldering skills, one little mistake, like a solder bridge, will blow up all the parts you just replaced, and sometimes more.
    You can start by using a multimeter and put it in the ohms check mode. Any shorted transistors will measure very close to zero ohms across 2 of the 3 legs. Check every combination of 2 legs( 2 outside legs, middle and 1 outside, middle and other outside). Sometimes a transistor is bad that does not measure shorted. it can also be open.
    The resistors have a color code, let me know what color the bands are and I can tell you what value they are. If they are burned up and the color bands can not be determained, you need the schematic to see what value they are.
    The reason I advise against doing it yourself is that if you miss one bad component, or put a transistor in the wrong way, or a capacitor in wrong, you will burn up that channel and have to start all over again. It really is not as easy as you may think. Some amplifier circuits are very difficult for even a seasoned technician who repairs amps all the time, they can have fits trying to figure out all the problems.
    It would take me hours of communications back and forth with you to guide you thru all that would need to be done. As much as I would like to help, that is just not a feasable thing for me to do, I really don't have that much free time. If you have some knowledge of electronics and soldering skills, a good amount of help would be needed still.
    You could at least start by unsoldering all the output transistors (the ones on the heat sink) and check them out of circuit to see if any are shorted. Then you at least know what channel to be looking at.
  • Dave DeGain
    No problem, and good luck with it!
    Dave
Harmon/Kardon AVR 146 wont stay on when hit power
Probably was damage buy a power surge, Internal damage to (Reciever)
Nov 03, 2012 | Harmon Kardon Harman Kardon Avr 146 5.1...
I have a Harman Kardon receiver Type AVR 500 RDS. Can I set it to 5ohz or 60 hz as I wish?
Should only set to frequency of your power supply otherwise may damage your receiver
Apr 29, 2011 | Harman Kardon AVR 500 Receiver
Wont turn on it stays on stand by
This could be a power supply issue to a audio output problem, I strongly recommend a top notch tech to check your unit because this is a high end device.
Dec 30, 2010 | Harman Kardon AVR 235 Receiver
Harmon Kardon AVR 235 no sound
Ensure that your speakers are connected to the terminals that you have your speaker selector switch turned to.
Then check that you have your device, whether it be a CD or DVD player, or turntable, plugged into the correct input and that you also have the correct input selected on the receiver.
Dec 29, 2009 | Harman Kardon AVR 235 Receiver
Harman Kardon AVR 154 OSD setup screen wont display
It will only display via component. Your HDMI firmware is either 1.1 or 1.2 and has HDCP issues (High Definition Copyright Protection) it's a firmware problem that has been fixed on all new receivers, not just a HK issue, all receivers! the new version 1.3a and 1.3b have fixed the issue. Unfortunately you cannot update the firmware on the receiver. Hope this explains it for you, sorry! Lot's of angry people out there!!! myself included.
Jun 27, 2009 | Harman Kardon AVR 235 Receiver
I have a Harman Kardon AVR 235 Receiver that go's into Protect
To avoid making the avr go into protect mode when you power up your Hafler 4000 that is connected in the avr's pre-out, you must power up the set up in the correct sequence.
1. Turn off your avr
2. Connect Hafler 4000 to the avr's pre-out it it is not yet connected
3. Turn on your Hafler 4000. The avr will not go into protect mode becasue of the transients from the Hafler because it is still not powered on.
4. Turn on you avr. There should be no more transients from the Hafler at this stage unless it is not functioning correctly, so the avr shouldno longer go into protect mode.
Dec 08, 2008 | Harman Kardon AVR 235 Receiver
My AVR 235 stays on stand by
Hi...
That sounds like a amplifier module /section that has failed.
Do you ever get power surges at your place?
Oct 05, 2008 | Harman Kardon AVR 235 Receiver
Harman Kardon AVR 120 turns off by itself after normal work for about 1 min
Do you get an indication on the display where the point of failure might be? It would show up on the LCD speaker diagrams just before shutting off.
Dec 05, 2007 | Harman Kardon AVR 120 Receiver
Harman Kardon AVR 235 Receiver Logo
466 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
