Question about PfaFF Hobby 4260
Pfaff Hobby 1142 Reverse stitch lever twisted doesn't work
Hi, the reverse stitch lever on my Pfaff Hobby 1142 looks twisted and won't reverse stitch - been to 1 repair shop who actually told me it was MADE that way (turned toward the sewing operator) to make it easier to use - BUT his sample stitch cloth showed NO reverse stitches because it doesn't work!
Can I open the machine somehow to get to this and see if it simply got "unhooked" or whatever from the reverse thing?
Thanks
  • 1 more comment
  • HeadWench Jul 03, 2008
    Hi Sewman7, I spoke to them on the phone and after a few days of being put off, was told I could bring it back in - Unfortunately we were leaving to travel for 6 months, we did dispute the charges... I guess I'm going to find someone up north of Cleveland, that really knows the "pfaff" brand. Thanks so much!
  • Anonymous Mar 16, 2014
    stitch setting for freemotion sewing on pfaff 139
  • Anonymous Mar 25, 2014
    the machine is only reverse stitching even after releasing the reverse button !,,,hw can i fix it
    New Friend:
  • 37 Answers
Hi, your reverse stitch lever is broken, it's plastic and should have been made stronger. Pfaff doesn't make it easy to get the front half of the plastic case off, which you will need to do to get to the lever. I haven't found anyone selling a replacement part. You can go my route and try a repair with epoxy.
Posted on Apr 21, 2015
  • 323 Answers
Take it back to the Dealer.( He probably has a guarantee on the work he did). Let him show you how it works. If he won't do this then it is definitely time to find a more reputable dealer. If you paid for a repair it should have been repaired.
sewman7
Posted on Jul 01, 2008
I have the same problem. |Until I can get it fixed \i have been tipping it back to straight and then pressing down evenly which seems to give me a little reverse. I think that the plastic extension inside is cracked. \i hope that this is a part that is acessible!
Posted on Jan 10, 2009
  • posiedouthwr May 01, 2014
    I have the same. Problem. How can I get it open?
I have my moms pfaff 1222 which I love. But having issues with buttonholes. Seems first row of stitching works but when I push button to make end stitch and then reverse it doesnt reverse
Your machine looks quite similar to some of the older Berninas I've worked on in the past. Perhaps your machine has seized due to the old oil solidifying. This could have happened with the reverse mechanism and the selector levers/buttons on your machine.
Wheel on right side that controls the needle up and down is very tight...
Nov 22, 2016 | PfaFF Sewing Machines
Is there a reverse switch? where
Depends on your machine. Consult your owner's manual.
On a lot of older machines, the Stitch Length Selector will reverse if the lever is pushed all the way up. Some really old machines do not have a reverse, so what you have to do is sink the needle in the fabric, lift the presser foot, and swivel the fabric 180 degrees so you can stitch back over the previous stitches.
Newer computerized machines will have a button, lever, or switch sometimes labeled with a reverse arrow.
Jul 15, 2015 | Sewing Machines
Brother AE2500 reverse sewing lever is too stiff to move , how does this work please, bacause in the CD provided with this sewing machine , this lever (plastic) for doing reverse is being moved down t
Try turning the flywheel and operate the reverse lever at the same time. Some machines need to be at a certain point in the stitch cycle for the reverse lever to be used.
Dec 26, 2014 | Brother Sewing Machines
I just got an old Sears Kenmore Sewing machine model 385.17781. Everything is working fine except the reverse stitch. When the reverse button is pressed, the fabric doesn't move or sometimes movin
it sounds like the feed dogs & the reverse button need to be
checked at a repair shop,
to see why they are not responding to each other.
Sep 08, 2012 | Sewing Machines
Looking for the reverse button on a necchi bu nova
There is no reverse button, it is a lever.The stitch length lever also reverses the feed dogs - when down, it runs forward - at zero, it does not feed at all and when moved up, it reverses the machine. Set your stitch length by loosening the thumbscrew on the vertically moving lever and sliding the plate into position while moving the lever up to the desired mark. Tighten the screw and move the lever down to sew - to reverse just move the lever up until it hits the stop to sew the same stitch length in reverse.
Jan 12, 2011 | Necchi 4575 Mechanical Sewing Machine
Pfaff hobby 1142. only goes one way, does not complete buttonhole.
it sounds like the buttonhole mechanism is seized up or gummed up with old grease. try following the linkages for buttonhole mechanism or button to see you can locate the stuck linkage.
otherwise it sounds like a tech job.
scott.
Jul 28, 2009 | PfaFF Hobby 4260
Sewing Machines Logo
808 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
