When I use it now cpc usage and memory go thru the roof and my vista os eventually crashes!! Pc is fine with any other file convertor or software. Basically I want cucusoft back as I miss it a lot.
    Sergeant:
    Champion:
  • 417 Answers
UPGRADE TO MORE MEMORY THAN ALL SHOULD BE FINE
Posted on Jul 02, 2008
Dns failed
dns.exe problems occur when important operating system files become misconfigured, deleted, or damaged. This is a common problem with computers that don't get maintained regularly. Eventually the system becomes overloaded with problems and begins to crash and display errors. You may also notice your system becoming very slow due to high CPU and memory usage.
Resolution
We strongly advise against fixing dns.exe errors manually. Doing so could take several hours, do more harm than good, and end up not even resolving the underlying problem.
The most recommended solution is to use a reliable software application that can quickly diagnose and fix dns.exe errors (and much more). Programs such as Advanced System Cure run a variety of troubleshooting and diagnostic tests on your computer in order to pinpoint and fix almost all known issues. The result is an error free PC that is actually much faster than before. And it is free!
Nov 13, 2013 | Computers & Internet
Upgrading from vista to win7
I would start by deleting partitions and doing a full format. Then loading an OS. Check MS minimum system requirements for OS and double them.
If it crashes again. Start checking RAM.
Sep 27, 2012 | Dell Computers & Internet
Laptop dell inspiron n5010 hanging suddenly
There are many things that might cause your PC to run slowly or restart at time and then. It could be a fragmented disk; fragmented registry; a virus, Trojan, or spy ware; high CPU and/or utilization due to too many programs running; high disk I/O; or something else.
To check your CPU and memory utilization, run Task Manager. You can start Task Manager by pressing CTRL+ALT+DEL and then clicking on the Task Manager Button. In Task manager, click on the Performance tab and check CPU Usage and PF Usage. PF Usage is an indicator of memory usage. If one or both of these is high, click on the Processes tab, and sort the columns by CPU or Memory to see what processes are consuming the resource. If you are not sure what the process "Image name" is for, Google the name and you should find what the process is for.
If your CPU and memory usage are reasonable, then you may have a different issue. Even if you running anti-virus software, it may be beneficial to scan your PC with another scanner to check for viruses. Here is a few good virus scanners that you can run to check your PC:
http://c74b6qq6lbo8zlievtv2q810g1.hop.clickbank.net/?tid=DMWDH6W3
Nov 24, 2011 | Dell Computers & Internet
Slow running of window vista
Nov 24, 2011 | HP Pavilion dv9000z Notebook
HPa206x crashes coming out of hybernation
If your CPU and memory usage are reasonable, then you may have a different issue. Even if you running anti-virus software, it may be beneficial to scan your PC with another scanner to check for viruses. No anti-virus software is 100% perfect at catching everything. Here are a few good free online virus scanners that you can run to check your PC:
http://security.symantec.com/sscv6/home.asp?langid=ie&venid=sym&plfid= 23&pkj=RRJEDTKJBTVISBYWWYP
http://onecare.live.com/site/en-us/default.htm
http://www.eset.com/us/online-scanner
http://www.pandasecurity.com/homeusers/solutions/activescan/
An excellent free utility for overall system maintenance is Advanced System Care Free ( http://download.cnet.com/advanced-systemcare-free/3000-2086_4-10407614 .html ). I use this utility on a regular basis.
Any further assistance mail me at smilingraj2k2@gmail.com
Nov 22, 2011 | HP Pavilion a206x (DK320AR#ABA) PC Desktop
HP Ipaq h1940 won't sync with Vista
Hi. While holding power button, and pressing reset will do a hard reset to your PDA (reset the device to its factory default settings). So if your PDA is working well, don't do it. As for the syncronization with your Vista PC; Winodws XP uses the ActiveSync software for syncronization, and for Windows Vista, Microsoft developed a brand new syncronization software called "Windows Mobile Device Center". It can be downloaded here: (http://www.microsoft.com/windowsmobile/en-us/help/synchronize/device-center-download.mspx). When you download/install this software to your PC, you should be able to connect your PDA to your PC without any problem, and definitely without changing any OS in your PDA or PC. Hope this helps.
Jun 01, 2009 | HP iPAQ H1940 Pocket PC
Powercinema NE for Everio keeps crashing
i think it not support or may be files is corrupted. check with other systems. also reinstall the software with same path
merry christmas
Dec 19, 2008 | Computers & Internet
Cpu
upgrade ram should do the trick
Jul 11, 2008 | Computers & Internet
Vista crashes while publishing movie in Windows Movie Maker/DVD Maker
i just found out the problem.
I have nero 7 installed on vista. To fix the vista movie maker crash when rendering, I just renamed this folder
C:\Program Files\Common Files\Ahead\DSFilter
Renamed DSFilter to something else. VMM no longer crashes and when I want to use Nero again, just rename DSFilter back to normal.
Jun 28, 2008 | Computers & Internet
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
