Question about Gateway Computers & Internet
My computer wont go to windows xp when started up and it doesnt even go to any type start up screen
    Scholar:
  • 141 Answers
Hi gllwymiller;
1.check all your connections
2.check monitor and cpu power
3.when you power on your cpu, do you actually hear the fan turning or see your power led light up?
4. what OS are you using?
5. Feel the rear fan or your CPU, is it blowing out air?
get back to me :)
Posted on Jul 01, 2008
Realy to know what to type in edit windows vista wont even start in safe mode
What is it actually doing? When you turn the power on and the computer starts up what does windows do as far as where does it stop? Most likely your start up is damaged. This is common if you did the windows upgrade versus a clean install or if there was a power surge while the computer was starting. If you don't see the Computer Manufacturer splash screen the problem is not windows at all but is the computer and we will need to isolate that. What type of computer do you have, How Much RAM memory is installed are also key elements to finding the problem. If you don't have enough RAM the Windows OS will not load properly. Typically Windows indicates a Minimum RAM level that is required but experience has taught us that in many cases double that amount is actually needed in order for it to function. On the other had, the problem could be something as simple as a driver. Windows XP drivers will not work in Windows Vista.
Oct 08, 2011 | Microsoft Windows Vista Ultimate Edition
When i start my Notebook (HP mini 110 1034) it goes to a black screen with my password requirement and when i enter my pasword it doesnt go to my regular startup page. It doesnt let me boot even with my...
Start you're computer on safe mode an run you're antivirus
Using the F8 Method:
  1. Restart your computer.
  2. When the computer starts you will see your computer's hardware being listed. When you see this information start to gently tap the F8 key on your keyboard repeatedly until you are presented with the Windows 7 Advanced Boot Options screen as shown in the image below.
  3. Using the arrow keys, select the Safe Mode option you want.
  4. Then press the enter key on your keyboard to boot into Windows 7 Safe Mode.
  5. When Windows starts you will be at a typical logon screen. Logon to your computer and Windows 7 will enter Safe mode.
  6. Do whatever tasks you require, and when you are done, reboot to go back into normal mode.
Jul 19, 2011 | Computers & Internet
T42 gets message"NTLDR" not available. Tried to
Don't try loading windows with out fixing the NTLDR...Try this simple steps in recovery console,
  • Insert the Windows XP CD-ROM into the CD drive, and then restart the computer.
  • Click to select any options that are required to start the computer from the CD drive if you are prompted.
  • When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
  • Press 1 (One) to select windows XP and then hit enter.
  • When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
  • At the command prompt, start typing
COPY D:\i386\ntldr C:\ (Considering that D is your CD Rom Drive)
COPY D:\i386\ntdetect C:\ (a file that may also be missing)
  • Then rebuild the boot configuration boot.ini file by
    Attrib -H -R -S C:\boot.ini (if not found skip the next line)
    DEL C:\boot.ini
    BootCfg /Rebuild
    Note:
    Do not use the repair option in the recovery console.
    Or, if you can get into XP, even safe mode, you can arrange to bypass the
    password by the following registry change:
    Click on Start then click run and type Regedit. Navigate to the key mentioned below,
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\WindowsNT\CurrentVersion\Setup\RecoveryConsole
    Set the DWORD Security Level value to 1
Hope this helps
Dec 27, 2010 | IBM ThinkPad T42 Notebook
Cannot boot on any mode.
get a bootable xp cd boot from cd after booting press r key on the screen u get now xp will start in recovery console now login on it after type the command chkdsk and after completion chkdsk /p after that chkdsk /r exit recovery console restart pc if it doesnt work ur ram module has some problem
Jul 10, 2010 | Microsoft Windows XP Professional for PC
My t43 won't start up windows. Freezes on ibm logo screen
People need to understand that you can't even get to the windows bootup if it freezes at this screen. Honestly if you have never dealt with this SPECIFIC issue then please don't answer. From what I have seen so far, you need to remove the HDD, reboot, enter the BIOS, reset it to optimal config, power off, reseat your HDD, then power back on. Seems to be a issue with the HDD itself. I had 6 of these laptops with the same issue and it is hardware based and has NOTHING to do with Windows.
Apr 06, 2010 | IBM ThinkPad T43 Notebook
IBM thinkpad wont work
Try to get hold of a bootable xp pro disk and boot from it, when finished loading the initial drivers and files onto the system gointo the 'R' option recovery console, this is a command line recovery, once there type chkdsk c:/f and press enter let it run its coarse and then restart pc.
Jan 21, 2010 | IBM ThinkPad R31 2656 Notebook
Novalogic Delta Force 1 wont show picture, Windows XP
I suggest you not download/buy pirated copies of game, and they might not have copied it correctly to the disk, and that causes it not to work.
Aug 11, 2009 | NovaLogic Delta Force for Windows
Msconfig won't work
If youre running windows 2000, it doesnt come with msconfig. For a missing msconfig in XP, download it from the internet, copy it to the C:/WINNT/SYSTEM32 folder. The version that works for windows 2000 will work for XP. DONT USE the 95, 98, ME version on 2000 or XP.
Mar 29, 2009 | HP Pavilion a450n PC Desktop
Windows xp home edition computer will not start
If the system cannot start on safe mode probably your operating system has gone bad, to check your hard disk you can go use your windows xp disk, to boot from it press f12 choose cd rom keep on tapping enter and dont mind the message that you need to press any key to boot from cd, and then when you are on the welcome to setup page press r for recovery console, once you are there try to type in chkdsk /p and after type in fixboot and press y, and restart your system, if that wont work then your hard drive is bad.
Oct 31, 2008 | Microsoft Windows XP Home Edition
Reformat HP pc hard drive.
to perform a clean install of your XP. follow this steps.
1.    Start your computer from the Windows XP CD-ROM. To do this, insert the Windows XP CD-ROM into your CD drive or DVD drive, and then restart your computer.
2.    When you see the "Press any key to boot from CD" message, press any key to start the computer from the Windows XP CD-ROM.
3.    At the Welcome to Setup screen, press ENTER to start Windows XP Setup.
4.    When you see the End-User License Agreement, press F8.
5.    Follow the instructions on the screen to select and format a partition where you want to install Windows XP. This would be your c:\ drive
note: when formating the drive do not choose the quick format option.
6.    Follow the instructions on the screen to complete Windows XP Setup.
Nov 01, 2007 | Computers & Internet
Computers & Internet Logo
64 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
