SOURCE: unable to write to file
I had this same problem and went to www.epson.com/support for help. Basically, the problem was fixed by downloading new free epson scan driver software. I suggest you go there for the details.
Sincerely, Ward Thomas
SOURCE: Epson 4490 Photo - multiple PDF pages
Please follow the steps below to scan and save a Multi-Page PDF with Epson Scan.
1. Launch Epson Scan from your START, (ALL) PROGRAMS, EPSON SCAN.
2. If prompted, select your scanner model. Epson Scan will now launch.
3. Click the drop down arrow next to SCAN, select FILE SAVE SETTINGS.
4. Select PDF for IMAGE format. Click OK.
5. Click SCAN. Click OK to proceed (if prompted).
6. Once the image has scanned you will be prompted to click ADD PAGE or DONE.
7. Click ADD PAGE to scan more documents.
8. Once you have scanned all your documents, click DONE.
9. Your documents will now appear in the EDITING PAGE window. Click OK.
10. The multi-page PDF is now created.
SOURCE: Scanning multiple page documents
Yes you can. You need a small scan application whitch allows you to scan multipages.
There are for example ScandAll21 from Fujitsu (freeware) or PaperPort 11.
http://www.opendrivers.com/driver/229211/fujitsu-scanners-scandall-21-v4.2.34-windows-free-download.html
http://www.nuance.com/paperport/
I had the same problem and fixed mine without re installation. Even though the error does not indicate it very well, the application could not write to the destination. The EPSON Scan application has a destination in two places. One under configuration, in my case, correct. However, a more buried location, next to the Scan button, press the arrow to edit more settings. There, you will find another destination, in my case, incorrect ( a folder that did not exist). Change the setting to a folder that does exist, it should work. Check out my fix here, detailed with pictures. Thank you. Hope this helps someone.
http://it.megocollector.com/?p=946
SOURCE: EPSON Scanner 4490 Problem
So you've completely ininstalled. Now you should download and install nCleaner, and do a Clean System, and then a Clean Registry. Now:
Download and install the latest 4490 driver software from here:
http://esupport.epson-europe.com/ProductHome.aspx?lng=en-GB&data=+ab4PwTTw7cRmkks+y0Lel8FKCE2A3PV7yPoa5gsU002FboU003D
The Epson Copy Factory Update may be of some use to you also.
Hope this helps
Chris (ziraffa)
