Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Console Which part of the machine is the console...is it where the control dials are located? I assume so, but want to be sure before removing it!
    Genius:
  • 1,028 Answers
Yes
Posted on Jul 01, 2008
How do i replace the timer part number 3351744
This video will show you how to open the control panel(and remove cabinet) disregard the cabinet part but it shows how to open the console. To replace the timer,push in timer knob and unscrew knob ina counterclockwise direction and use a small screwdriver behind dial to remove it.under the dial will be the screws the hold timer to console remove those.
Good luck i hope this helps,
Gene
Aug 09, 2011 | Roper RAS8445KQ Top Load Washer
Need to replace a front heat blower resistor on 2002 mdx, where is located???
moz-screenshot.pngHere's an excerpt from the 2002 Acura MDX 4WD 6cyl Repair guide for replacing what the reference manual calls the "control assembly" - its located under the console rear trim and may (or may not)
contain the blower resistor - my manual doesn't say - but this is the closest thing I could find for you. Every other blower resistor I've had to find was located close to the heater controls - and this
car seems to be no exception -- its heater controls are located in the console between the seats, rather than in the dash (as in Acura 2003-06 MDX models).
You may want to call your friendly Acura dealership ad speak to the parts department, to make sure where the blower resistor is located - or a visit to a dealership parts counter often (or
Advance Auto Parts is helpful too) ofen clarifies questions I have from Haynes manuals (the cheapest car repair guides).
All this assumes that you've correctly diagnosed your blower control problem -- as in "replace the blower resistor when the blower works only on the MAX/Highest setting."
-- begin excerpt from 2001-2 Acura 4wd 6cyl MDX Repair manual --
Control Assembly Removal & Installation
2001-02 Models
  1. Remove the console rear trim. Refer to the accompanying illustration.
    Fig. Exploded view of the console rear trim
  2. Remove the self-tapping screws and the rear heater-A/C control unit (A) from the console rear trim (B).
To install:
  1. Install the control unit in the reverse order of removal. After installation, operate the control unit controls to see whether it works properly.
  2. Run the self-diagnosis function to confirm that there are no problems in the system.
    Fig. Remove the self-tapping screws and the rear heater-A/C control unit (A) from the console rear trim (B)
  3. --- end excerpt from 2001-2 Acura 4WD MDX 6cyl Repair Manual ---
Jan 02, 2011 | 2002 Acura MDX
Where is the pump located?
It is attached to the motor.
Disconnect your Kenmore Oasis washing machine from its power source. Make sure that your washer is unplugged before beginning to disassemble it.
Remove the screws that hold the control console to the top of your Oasis washer. In some Kenmore Oasis models, the two screws may be covered by plastic end caps. After removing the screws, set them aside until you are ready to replace them.
Flip the console up, back and out of the way.
Locate the cabinet clips on the top of your Kenmore Oasis washer. These clips are located toward the back of the washer top and would be hidden by the console if it were not currently flipped up.
5
Slide your screwdriver underneath the metal cabinet clips. Wiggle the screwdriver back and forth to gently pry the cabinet clips free.
6
Disconnect the group of colored wires that plug into the top of the washer from the control console. These wires control the lid switch on your Kenmore washing machine. To disconnect, grasp the white plastic clip and pull gently.
7
Remove the washing machine cabinet. Tilt the cabinet towards you, and then lift the entire cabinet up and off of its platform.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 26, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
F1 code
This is a problem associated with the machine/motor control assembly and/or the pressure sensor system. Either the machine/motor control assembly is at fault or it is sensing an error in the signal from the air pressure sensor circuit. Unplug the machine for half an hour or so to forcibly reset the machine/motor control assembly and eliminate the possibility of a simple electronic glitch.
Remove the three screws from the rear of the console assembly, if unplugging the machine does not resolve the issue, then pull console towards the front of washer to hinge it open and remove console.
The machine/motor control assembly is located on the right hand side of the machine that is enclosed in a casing with a clear tube/hose connected to it.
The clear tube/hose is the pressure hose. Check to make sure that everything connected to the machine/motor control assembly is properly attached and fully inserted and the pressure hose has no air leak, kinks, or moisture.
Turn off the water supply to the washer and disconnect the hot and cold water hoses from the rear of the washer then remove the end of the drain hose from where it is installed. Remove the eight screws from the rear panel and remove the panel.
Inspect the pressure hose for evidence of water then replace the hose (part number 353244) if water or moisture is present. Inspect the air dome hose connection port for lint or flashing.
Use a small round device such as a small screwdriver to ensure that there is nothing blocking the air dome outlet on the tub.
Replace the machine/motor control assembly if and only if verified that there are no issues with the air pressure system. Remove all the wire connections to the machine/motor control then remove the screw holding it to the console tray. Two plastic legs on the rear of the machine/motor control assembly are fitted into the console tray. Lift the front of the control assembly to pivot it out from the console tray. Reinstall the new machine/motor control assembly then secure it to the console tray and reconnect the wire harnesses.
NOTE: It is a good idea to take note of the wire harness connections before disconnecting them to prevent messing them up upon reconnection.
Aug 31, 2010 | Maytag Bravos MTW6600T Top Load Washer
Delayed lid lock and F1 signal on dial. Push pause and then start again continues to go into F1 signal all types of cycles.
Keypad/User Interface Failure
A fault code of "F" then "1" flashes when there is a primary control failure.
You will need to replace the machine/motor control assembly.
Page 14 and 16, in the manual link below will help you with this.
F then 2 flashes when in:
Diagnostics Test mode if a stuck key is detected.
Standby mode if there is a user interface mismatch.
DISPLAY (Saved Code) EXPLANATION AND RECOMMENDED PROCEDURE
Console and Indicators
This test is performed when any of the following situations occurs during the Console and Indicators Diagnostic Test:
None of the indicators light up No beep sound is heard Some buttons do not light indicators None of the indicators light up:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P11 connector is inserted all the way into the machine/motor control.
2. Visually check that the user interface assembly is properly inserted in the console assembly
3. If both visual checks pass, replace the user interface assembly.
4. Plug in washer or reconnect power.
5. Activate the Console and Indicators Diagnostic Test mode to verify repair.
6. If indicators still do not light, the machine/ motor control has failed: Unplug washer or disconnect power. Replace the machine/motor control assembly.
Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
No beep sound is heard:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P5 connector is inserted all the way into the machine/motor control. If visual check passes, replace the user interface assembly.
2. Plug in washer or reconnect power.
3. Activate the Console and Indicators Diagnostic Test mode to verify repair.
4. If replacing the user interface assembly failed: Unplug washer or disconnect power. Replace the machine/motor control assembly. Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
Some buttons do not light indicators:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the console electronics and housing assembly is properly inserted
into the front console. If visual check passes, replace the user interface assembly.
To Access/replace the CCU:
#1
Unplug the Whirlpool Cabrio power cord from the wall outlet. Turn off the water supply to the washing machine. Pull the washer away from the wall so that you can access the screws behind the control console. Remove the hex head screws securing the control console to the washer with a nut driver. The screws are on the lower rear edge of the control console.
#2
Lift the control console up, and rotate the console forward so that the face of the console is resting on the top of the washer. Locate the interface board cable connector to the right of the plastic tube on the back of the console. Pull the end of the connector straight out of the control console. The primary machine control is the box that the plastic tube connects.
#3
Place small pieces of masking tape around the nine wires connecting to the primary machine console. Label the wire locations onto the masking tape with a pencil. Grasp each wire at the connector with your fingers, and pull the wires away from the primary control. Pull the plastic tube out of the primary control.
#4
Locate the nut toward the bottom of the primary control. Remove the nut with a nut driver. Lift the front of the primary control slightly, and slide it down to disengage the retaining clips. Pull the primary control out of the control console. Insert the new primary control into the control console. Slide the primary control up to engage the lower clips. Secure the primary control to the console with the single hex head screw.
#5
Push each of the wire connectors into their respective positions on the primary control until they lock into place. Push the plastic tube hose over the port on the right side of the primary control. Remove the small pieces of masking tape from the wires.
#6
Position the control console back upright on the top of the washer. Secure the control console to the washer with the three hex head retaining screws. Slide the washer back against the wall. Turn on the water supply and plug the washer into the wall outlet.
TECH SHEET LINK: http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208567037.pdf
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.@!$^
May 20, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
F1 Display
#1
#2
#3
#4
#5
#6
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&*$%^
Apr 26, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
How do I get the control panel open to replace/repair the water level dial?
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
Also see the following for how to release the console.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131
Most Kenmore washers use two endcaps on the front of the console that cover screws. Pull the endcaps off, remove the screws and pull the console up and forward to tilt it back.
Some models don't use endcaps.
They have two clips under the console holding it to the cabinet. If yours is one of these, slip a thin putty knife between the console and cabinet to release the clips.
See the Sears diagrams of the console and the following for a betteer diagram of the console and all internal parts.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=138
Jan 27, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
When I start the machine it starts to fill up and then it stops and on the dial it displays F and I can't find my user guide help please>>>
The F1 error code on Whirlpool Cabrio Top Load Washers means primary control failure . Check every wiring harness to the machine control assembly for any poor and loose connection. Clean the wiring harness connectors and terminals to ensure good connections.
Resolving F1 Error on Whirlpool Cabrio Top Load Washers
  1. Safety first. Unplug the machine.
  2. Remove the three hex-head screws from the rear of the console assembly.
  3. Lift the console assembly off the cabinet and disconnect the user interface wiring harness from the machine control board.
  4. Disconnect and clean every wiring harness connector and terminal on the machine control board. Ensure that all connections are good and tight.
  5. Reconnect the wiring harness connectors and reassemble the console.
  6. Replace the machine control board if the problem is not resolved.
  7. Pull the pressure transducer tube off the fitting on the machine control board.
  8. Remove the hex-head control board mounting screw.
  9. Lift the front of the machine control board, slide it out from under the clips at the back, and remove it.
  10. Install the new machine control board in reverse order of the steps above.
  11. Reinstall the console and secure it with the three mounting screws.
Jan 24, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool washer not spining clothes
Hi
Thanks for using FixYa. If the washer isn't spinning then it might be due to a Lid switch or due to a bad motor coupler. You can check for the lid switch & replace it--
First unplug the washing machine. Then remove the two screws that hold the top console in place; these are located in back of the main console (where the dials are). Once removed, the entire console swivels back, exposing the wires underneath.
After this unplug the wiring harness that is connected to the washing machine top flat surface. Now remove the two s-shaped brackets with a screwdriver by prying underneath. This will allow you to remove the main sheet metal frame around the washing machine. The lid switch assembly is located under the top console. Now, remove it and replace with the new assembly and put it back together.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Oct 22, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Everytime i try to run the washer it gives me a F1 reading on the dial, Why?
#1
#2
#3
#4
#5
#6
Sep 12, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
20 people viewed this question
Dan Webster
Dan Webster
Sal De
