I bought a Kenwood KVT-815dvd player and got everything hooked up to only find out that it had a security code. The problem now is that I got it from a pawn store and they did not even know that it had a security code on it. So is their a way I can bypass they password or just reset the whole unit so that it does not have one. Also, where is the memory for this unit?
Thank you
My KVT-617 display unit was stolen out of my dash, but they neglected to snag the items under the rear seat: the "brain" hideaway unit, the HD radio receiver, the 10 disc CD changer, the navigation unit, and the powered subwoofer.
Everything was replaced via the insurance except the sub because the new system was not compatible with the old components. Make me an offer on the items you want!
I have seen problems in the hideaway (brain) where 8v reg circuit fails causing higher voltage(12v to 14v) to be on that 8v line. First component to fail is the Tuner followed by electronic volume ic. I have probably seen 6-8 failures where tuner fails. Fix is to replace tuner and replace open chip resistor in Hideaway box to restore 8v regulator to proper voltage. [email protected]
The kvt-617dvd doesn't list your changer as one that's compatible. However the changer install procedure is relatively simple - just plug the 13-pin cable from the changer directly into the kvt-617's hideaway receiver. I would suggest you connect it to see if the changer will work before buying anything else.
