Question about InFocus X1 Multimedia Projector
INFOCUS Lamp replacement
Just replaced lamp and unable to reset lamp clock. Followed instructions in manual and it still wont reset. The projector sounds like it is trying to "boot" up but it just shuts down after about 30 secs giving me the blinking red lights again. Same (I think) scenario. Lamp ran completely out (but didn't explode this time, yay!), but now I replaced it and when I power on all I get is a green light for a few seconds and then blinking red. There were no errors, the counter ran down cleanly (lots of warnings on screen). I ordered replacement, installed replacement, no lamp... The volume-keys thing didn't work for me.
  • Anonymous Mar 22, 2014
    after replacing a lamp the led was still blinking red twice so I tried what the manual said to reset timer by holding down both volume buttons for ten seconds this didn't work so I held down both keystone buttons this gave me a green light but it remains blinking and the lamp wont light
    Genius:
  • 1,447 Answers
Chances are its the projector itself that you are having an issue with, one more thing that you can do is for you to clean the filters, try cleaning the filters and try reinstalling the lamp, then power it back on, if you are getting the same thing still, have the projector service or if within warranty have it replaced. best i got. Thanks for using Fixya!
Posted on Jul 01, 2008
I replaced the lamp on my NEC LT280, but am unable to reset the lamp so that the projector works again.
Whe the lamp exceeds 2100 hours (up to 3100 hours in ECO mode) of service, the projector cannot turn onand the menu is not displayed. If this happens, press the HELP button on the remote for 10 seconds to reset the lamp clock back to zero. When the lamp clock is reset to zero, the LAMP indicator goes out.
Here is the URL for the User Manual:
http://www.necdisplay.com/documents/UserManuals/LT380_user_manual.pdf
Dec 14, 2014 | NEC LT280 LCD Projector
The old lamp in my in focus LS 110 reached its maximum hours. I replaced with a new lamp but it is not firing up - i think I need to reset the lamp hours but don't know how and don't have the...
Sorry, I am not familiar with the Infocus LS 110 but the user guide can be downloaded at
http://www.retrevo.com/support/InFocus-LS110-Projectors-manual/id/1081dj697/t/2/
You don't need to put in your email address but you will need to type in the numbers. It come in a PDF format so you will need adobie acrobat to read the file. It should have instructions on how to reset the lamp hours.
Hope this helps
Aug 01, 2011 | InFocus LS 110 Multimedia Projector
I have replaced new lamp to InFocus LP540 projector, but it still indicating in the LED display "please replace lamp".. and LED is blinking two times as red.. Lamp door is closed properly and the safety...
To reset the lamp timer , press the increase volume button on the remote and the increase volume button within 3 seconds
The maintenance manual is on the infocus web site
Aug 19, 2010 | InFocus SP-LAMP-017 Projector Lamp for...
Cannot Reset Infocus LP 350 Projector after replacing a bad lamp
that model has a history of bad ballasts. you'll need to replace it.
Mar 03, 2010 | InFocus LP350 Multimedia Projector
Light comes on and goes off.
the lamp may have exceeded 2000 hours. you need to replace the lamp and reset the lamphours. you can check in the menu.
Aug 08, 2009 | InFocus Projector Lamp for IN24+, IN26+
The lamp warrning light on my infocus in24+
If you are able to measure/show any continuity whatsoever your bulb is way past bad!!
As these lamps do not have filaments.
If you have replaced the lamp you can easily reset the lamp timer from the projector menu.
This procedure can be found in the user manual as well.
Cheers
May 02, 2009 | InFocus Projector Lamp for IN24+, IN26+
Infocus Lp240 Projector Will not power on NEW BULB. Red light Blinks on and off.
The owner's manual should have a troubleshooting chart that will indicate what the blinking lights mean. If the new bulb did not clear it, the problem may be the ballast (part that starts the bulb). Also, when you replaced the lamp, you should also reset the lamp timer. Some units will continue to indicate a lamp needing replacement until the counter is reset. The procedure for that should also be in the manual.
Keep us posted.
Dan
Dec 18, 2008 | InFocus LP290 1100 Lumen XGA LCD Projector...
Infocus LP725 Replacement Bulb
if you don't know exactly how many hours are on the new lamp, you can't be sure it works. since it's a mercury lamp, there will be no contenuity. check the lamp for cracks or clouding, not just burn marks.if the lamp is actually good, you may have a ballast issue.
Nov 02, 2008 | InFocus LP725 and LP735 Replacement...
---------->> My Infocus Screen Play 4805 -Popped*
Hello David,
The best way to find the best price is to do some hunting/research. Google "infocus 4805 lamp"
and wade through to find the best price.
You will find instructions on the lamp replacement procedure in the manual. If you dont have the user manual browse to www.projectorcentral.com and search infocus 4805 and on their spcifications page there is a "user manual" Acrobat PDF icon.
click on the icon to open the manual in pdf format
Take Care!
Jun 17, 2008 | InFocus ScreenPlay 4805 Multimedia...
you tried holding down both of the volume keys for 10 seconds while powering up?
Jan 29, 2008 | InFocus X1 Multimedia Projector
InFocus X1 Multimedia Projector Logo
147 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
