Question about LG 24 in. LD-12BS6 Stainless Steel Free-standing Dishwasher
LG LD-12AW-2 DISHWASHER
Hi
MY LD-12AW-2 HAS STOPPED WORKING.. IT BEGINS , IT SUCKS OUT THE WATER AND THEN IT STOPS. wE HAVE CHECKED IF IT BLOCKED AND UNPLUGGED IT AND RE PLUGGED IT BUT IT IS STILL DOING THE SAME THING.. WHAT COULD IT BE ,,
  • Anonymous Oct 09, 2008
    My dishwasher is doing the same thing. It starts and it sounds like water draining, then water is running in. As soon as it starts to wash, the machine's power goes off. This happens approx. 4 minutes after first cycle starts.
    What can I do?
    Problem Solver:
  • 10 Answers
Common problem with this model, the main pcb is faulty and doesn't drive the inlet valve anymore. all d/w will do the same pattern : drain, fill up, wash.
take care.
Posted on Jul 22, 2008
What indication are you getting on the display? sounds like the water inlet sensor is defective. one needs to watch carefully from the start of the cycle to when the problem begins to be able to make a diagnosis.
Posted on Jul 11, 2008
Lg LD-1403w dishwasher stops mid cycle
Most likely the water temperature is not reached as required and the dishwasher times out and stops without draining the water. It is likely the inlet water temperature is not adequate or if only using cold water the thermistor or the water heater are faulty.
Look for part M083 in the diagrams at the back of the service manual attached. you can also perform some diagnostics as shown in there but be very careful about the sequence otherwise you may flood or damage the dishwasher components.
http://www.jordansmanuals.com/ServiceManuals/LG/Dishwasher/LD1416T/LD-1416T%20Service%20Manual.pdf
Aug 06, 2014 | Dishwashers
LG dishwasher LD-14AW2 starts up & tries to drain for about 2 mins & then the alarm comes on. The wash, rinse & dry lights are flashing. The hose is raised and not blocked because we can blow...
Hi Jeff - am not too savvy with LG - am a Electrolux/Miele serviceman is it possible to gain access to the drain pump from inside the unit? I think it does sound like there is a restriction somewhere perhaps the pumps not running freely.
To check you pour water inside , take the drain hose , operate machine to see how good the flow of the drain is, rule of thumb if you cover the outlet no flow then the problem.
hope this is a start..
Jun 17, 2011 | LG 24 in. LD-12BW5 Free-standing...
Hi I have an LG LD - 14AW23 dishwasher. It shows an IE error (no water) but it fills, stops and then gives the error message. What's thye problem? Many thanks, John
Hi
Error code IE on LG dishwasher means Inlet error. This error comes up when the Water Supply Tap is closed or Water Supply is shut off. If water supply is turned on then make sure that the Inlet Hose is not kinked and water Pressure is not low (should be above 10 psi). Next thing to check for is Water Inlet Valve, measure the electric resistance of Inlet Valve. (950-1300 ohms) Make sure the filter of Inlet Valve is not clogged.
Hope this helps... Please post back for further assistance.
Daniel
Mar 26, 2011 | LG 24 in. LDF 7811 Built-in Dishwasher
My LG model LD-12AS1 dishwasher will not drain, please help
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter.
Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines.
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 08, 2009 | LG 24 in. LD-12BW5 Free-standing...
Error Code OE
The most common cause of an OE error code on a modern LG dishwasher is:
1. Blocked drain hose
2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction)
3. Failing drain motor.
else you need to REPLACE THE PCB POWER CONTROL BOARD
Good Luck!!!
May 02, 2009 | LG 24 in. LD-12BS6 Stainless Steel...
Stopped - no error message, power, drainage lines all good Andy
No Power on when the power button pressed.
Check out the web site
http://spares.bigwarehouse.com.au/file.php?document_id=5831
Apr 19, 2009 | LG 24 in. LD-12BW5 Free-standing...
Error code OE; dishwasher stops with error message 2 min into cycle, drainage seems OK, water doesn't appear to pump into machine - any advice?
Good Luck!!!
I have a lg dishwasher ld-14aw1over flow
On an LG LD-14AW1, three is a float sensor on the left hand side of the dishwasher, behing the water outlet port.
It is the sensor that tells the dishwasher to stop filling just before the wash or rinse cycle begins.
A service call is needed or post back here is you want help replacing it.
Apr 09, 2009 | LG 24 in. LD-12BW5 Free-standing...
Lg dishwasher stops throughout the full cycle
If you are still having problems with your LG dishwasher, turn off the hot water supply to the dishwasher and remove the hot water inlet pipe (remove the lower, front panel (toe kick plate) )
Check the screen/filter at the water inlet on the dishwasher.
Reconnect the pipe and turn the hot water supply back on.
Test out and enjoy!
Apr 01, 2009 | LG 24 in. LD-12BS6 Stainless Steel...
IE error message
Hi, had the same problem on a LG LD 12aw5. (No water entering). Check the inlet solonoid. There should be 220V over the solonoid. I replaced the solonoid, at first, just to have the same problem. The problem was a bit more serious, the Triac driving the solonoid burnt out, and the solder on the mainboard keeping the transformer were shot to. I replaced the Triac, soldered the Transformer - and wolla - working. If water enters - but you sill get the IE error it could be the float(checks the water level). This device tells the machine when there is enough water. If this is stuck, the machine will think no water is entering. conrad_dot_dewet@gmail.com - replace "_dot_" with "." to email me.
Apr 05, 2007 | LG 24 in. LDF 7811 Stainless Steel...
LG 24 in. LD-12BS6 Stainless Steel Free-standing Dishwasher Logo
137 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
