Magellan RoadMate 1470 GPS Receiver Logo
A
Anonymous Posted on Dec 14, 2010
Cracked LCD screen. Can I replace it myself? Where do you get them?
Anonymous
Level 3:
President:
  • Master 1,111 Answers
  • Posted on Dec 15, 2010
Anonymous
Master
Level 3:
President:
Answers
1111
Questions
6
Helped
381041
Points
3221
There fairly easy if you have a little patience..the hardest parts is getting the screen ribbon cable back on the board and not breaking or knocking the plastic locking tab off...i buy them off ebay ..search for broken ones not working, particularly one with a software problem, but has a good screen...you can buy them new for about 100.00 but you can buy a new unit off ebay for less then that, so who would buy a screen for a 100.00 when you can just buy a new one for the same price or less.
if you need step by step to replace it, let me know "before" you even remove the screws off the back..you need to remove the back cover the right way so you dont break off your usb/power port.
search ebay for as is, broken, parts or repair...theres a few on there right now pretty cheap
http://electronics.shop.ebay.com/i.html?_nkw=magellan+1470+parts&_sacat=139835&_odkw=magellan+1470+as+is&_osacat=139835&_trksid=p3286.c0.m270.l1313
http://electronics.shop.ebay.com/i.html?_nkw=magellan+1470+as+is&_sacat=139835&_odkw=magellan+1470+parts&_osacat=139835&_trksid=p3286.c0.m270.l1313
http://electronics.shop.ebay.com/i.html?_nkw=magellan+1470+broken&_sacat=139835&_odkw=magellan+1470+parts&_osacat=139835&_trksid=p3286.c0.m270.l1313
Bill
Standing Member of G.O.T.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Feb 11, 2011
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
473
Points
Where do you get lcd screen for maellan 1470 gps
My heiwei M886 screen is cracked just enough to where you cant use the screen.
Here you go. It has all the tools and everything. This is your best bet. Do not buy just a digitizer. It has to be a screen/digitzer combo or you will never get it working. They are aligned to work together. Huawei Mercury LCD Screen Replacement and Digitizer Premium Repair Kit...
2answers
Hello, I would like to fix my Samsung Strive phone screen myself. Can you help me? The screen is broken but not cracked. It has a spider/star shaped blotch that covers about half of the screen.
Hi barbaradwall,
Actually the spider web blotch that you can see on your screen is an indication of a cracked LCD. The only way that you can fix this is to have the LCD replaced by an authorized technician since special tools will be needed to open your phone and fit a new LCD.
Hope this helps.
Thank you for using FixYa.
1helpful
As per original notes: Camrea LCD is cracked, I
A cheapest way to get a replacement LCD is to buy another used camera through ebay. Look for one sold for parts, but with good lCD. Open the camera.s is easily done by removing 5-6 screws. Once the cover is removed, LCD is directly accessible. A good tutorial available in:
http://camerarepair.blogspot.com/2007/11/fixing-or-replacing-broken-lcd-screen.html
1helpful
I have a cracked lcd screen
You need to have a Repair manual with proper diagram..
otherwise watch the online video
Cracked Screen
2answers
Olympus D560 Digital Camera LCD Screen
The LCD screen on my Olympus fe-230 camera is cracked and I am trying to find a replacement screen to install. Any ideas where I can find one? Is this something I can replace myself
Canun digital camera powershot A630 lcd screen blank
I also cracked my Canon Powershot A630 lcd screen by dropping the camera. I saw a suggestion to buy a new replacement lens and either have it professionally replaced or try it myself. I ended up doing the replacement myself following instructions I found online. Now it works. Total cost US $63.
I would not recommend trying the replacement yourself, however. There are a few very delicate plastic parts in there which I ended up damaging. Luckily the camera and lcd screen are working great now. But it is probably worth having a professional camera repair shop do the whole job or insert the screen you've purchased. Good luck!
HP 3310 lcd cracked
Fraid not. unless you can locate a scrap printer[failed for some other reason] Printers are considered 'disposable' items these days.
2answers
Cracked LCD screen
No likely or possible - No parts- sellotape it
Top Magellan GPS Experts
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
Are you a Magellan GPS Expert? Answer questions, earn points and help others
