Question about Sony STR-DE835 Receiver
Loss of Sound
Recently the sound disappeared. Discovered it involved the speaker selector switch on the front panel. By jiggling the switch, the sound would (or would not ) be restored.
    Genius:
  • 2,028 Answers
Good deal, hope we helped some.
Posted on Jul 01, 2008
2 Suggested Answers
Pyrhyc
  • 2028 Answers
SOURCE: Loss of Sound on Sony Receiver
Did you get the switch replaced?
Posted on Jul 02, 2008
My speakers wont work, everything is plugged in, and nothing will still not work.
I know this was old query, but i recently had a problem with sound cutting out. Discovered if I jammed a spoon between the two cables input to the sub box, I could get sound back. Today finally got around to opening it up and discovered the soldering on both sides of the 8 pin anchor leads were broken. The pressure of the spoon jam allowed the connection to "seat" temporarily. Fixed with 25w iron and 60/40rosin core 0.032" solder. Wicked the old broken mess off and applied dab of new shiny complete solder. Good Luck all.
Sep 11, 2010 | Altec Lansing Audio Players & Recorders
When I turn on my technics sa-gx amplifier I can't hear the sound
Have you noticed if the speakers selector switch in the front panel is set to off ? That position for the switch is only suited to listen heaphones. Good Luck.
Flavio/BRAZIL
Jul 28, 2010 | Technics SA-DX750 Receiver
My reciever has no sound. everything else still works but it just won't put out any sound at all. yamaha RX-V863 7.1 channel. less than 6 months old.
Check your "A/B" speaker selector switch on the front panel of the receiver, if they are on, you will see "A" "B" or"AB" on the front display. If they are on, You need to have the receiver serviced. Just a note, Yamaha's rarely have an output problem! Hope this helps
Jan 09, 2010 | Yamaha RX-V863 Receiver
Center speaker and wireless rear speakers have no sound
I had the same issue, but apparently...it's not an issue. What I discovered is that the system was fine, but the station I was watching didn't broadcast in 5.1 surround sound. Therefore, only the front speakers will have sound. Try putting a dvd in, or listening to a gameing system through it. If you don't have sound after listening to something that puts out full surround sound, then you know you have an issue.
Jul 07, 2009 | LG LHT854 Theater System
Surround sound not working
sorry but start with the obvious..the surround speakers usually are a looped curcuit using one single live split .so check each speaker works the cable is ok .if all checks out ok go for the selector switch if its a push switch press it repeatedly .if all this fails tap around the unit there might be a dry joint.good luck .farr64
Apr 29, 2009 | RCA RS2600 CD Shelf System
Jul 02, 2008 | Sony STR-DE835 Receiver
Speaker hook up
Shari,
It is my hope that I can help. This applies to the type of sound card on your PC.
- If you have a 2-channel sound card: Select 2 on the source selector switch on the subwoofer. Connect the green plug from the audio input cable to tyhe front jack on your PC sound card. With this input setting, your speakers will upmix the 4-channel signal and create a center signal for your speakers.
- If you have a 4-channel sound card: Select '4' on the source selector switch on the subwoofer. Connect the colored jacks on the audio input cable to the jacks on your PC sound card, making sure to match the colors.
- If you have a '6'-channel sound card: Select '5-1' on the source selector switch on the subwoofer. Connect the colored jacks on the audio input cable to the jacks on your PC sound card, making sure to match the colors.
Your sound card is located on the back of your PC Tower.
Good luck
Jun 24, 2008 | Logitech Z-5300 Computer Speakers
Yamaha DSP A-1000 input selector switch not working properly
i did not post that....and why would fixya be asking the poster of a problem for a solution?????
Bug? Pls delete these posts moderator.
ty
Mar 09, 2008 | Audio Players & Recorders
No speaker sound
check the 2 buttons under the source selector knob they are labeled A and B check to make sure both are not pressed in just the one you have your front speakers hooked up to
Sep 10, 2007 | JVC RX-770V Receiver
Sony STR-DE835 Receiver Logo
61 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
