Question about Panasonic Cameras
Droped my fx07 in off position. Batery lid popped open but there is no visible trace of the fall. Problem: it will not turn on. any ideas short of $108 with no cap?
  • g1a2w3 Jul 01, 2008
    I had hoped for a plan of action short of blowing a minimum of $106 with no guarantee of sucess by sending my fx07 to Panasonic
  • g1a2w3 Jul 08, 2008
    decided not to pay to fix it.
  • 6,487 Answers
You really need to take this camera to a repair center near you for the repair because there's no way that you can fix it by yourself and also to avoid another problem that may arise...
Good luck....
Posted on Jul 01, 2008
    Master:
  • 638 Answers
Panasonic models r very sensitive n halfknowledge repairing person can lead to further damages.i would advice u to get it repaired from proper panasonic service centre.
feel free 4 further assistance .rate the particular experts solution as fixya that helps u understand n solve ur problem
    Guru:
  • 859 Answers
The contact points that are part of the camera body are some times flexible. look at these inside and on the lid to see if one is loose or not riding high enough to make full contact with the battery.
Remove your memory card and reinsert it.Check the mode dial and be certain it is in the right mode for your normal use.
If the battery compartment contacts are looking okay, use double or triple As which ever is called for for your camera. If then, the power switch fails to gain any activity before shutdown, you've broken something inside, most likely a little circuit board is dislodged but getting into the guts is no easy task.
At this point, I'd say its fixable and worth the 106 dollars to take it in. Go for it, no kidding. If you can replace it for twice that amount then do so.
Regards,
Worldvet
Please, don't forget to rate our solutions on Fix Ya.
  • Panasonic Master
  • 13,433 Answers
You will have to send your camera in for repairs either to panasonic or to another place which repairs your brand.
I recommend against trying to fix these yourself, as they are a real pain in putting back together.
few repair places
http://www.advancecamera.com/repair/
    Sergeant:
  • 260 Answers
Most likely the phone was damaged in the fall. Small misalignments can create big problems for the phone. Most likely, it should be repaired by a professional.
  • Ken Jones
    Ken Jones Jul 01, 2008
    sorry, i meant to say camera
    Genius:
  • 3,422 Answers
Did you try replacing it with the new batteries?
  • 1 more comment
  • Priya darshan Jul 01, 2008
    Here are few more troubleshooting steps:
    Polish
    the terminals with a dry cloth and make sure the terminals are clean.
    If the terminals are covered with oil from your skin or similar matter,
    this may cause poor contact and power may not be fully supplied to the
    camera.
    Also,
    polish the battery charger terminals with a dry cloth before charging
    the battery. If the terminals are covered with oil from your skin or
    similar matter, this may cause poor contact and the battery may not be
    fully charged.
    If
    the lens does not extend then it is possible that it has become jammed.
    Sometimes this can cause the camera to sense an error and shut itself
    down immediately after powering on.
    There
    are other explanations for the behavior, but if the lens does not move
    this is the most likely cause. If the lens does extend but then the
    camera shuts right back off it is possible that an inner component such
    as the focusing element is not functioning properly
    The battery cover or CF card (SD card) slot cover is not securely closed.
    Most
    cameras have a lock mechanism on the battery cover. The camera will not
    turn on if the battery cover is not locked or securely closed, or if
    the CF card (SD card) slot cover is not securely closed. Make sure
    these covers are securely closed.
    If you still face the problem then the only solution is to get it repaired.
My pressure cooker is locked shut. It is cool but will not rotate to open. It seems a little pin comes out and stops the rotation. any ideas?
Most have a pressure lock feature. The pin ususally pops up and locks the lid when there is pressure inside. sometime when cooking thick liquids the pin can be stuck in the up position. Just push it down slide the lock back and open the lid..Sometime running water over the top will budge it.
Jan 08, 2018 | Cars & Trucks
I press the open button but it doesn't open.
Have u droped it? if so my idea is to takee ur thumbs on each end of the tray and push extermly hard. mikte her click or pop sounds. mite got poped of tackes.
hope this helped
Dec 31, 2012 | Televison & Video
Zxr400 fuel wiring diagram
what was it doing before it stoped runing.
you my try a fox and a hound to trace the
wireing for a short.
Nov 12, 2011 | Cars & Trucks
Lcd becomes visible every time i turne lcd on,
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 12, 2010 | Computers & Internet
Blowing lid fuse. Lid switch tested fine. Other Ideas?
You might want to test the inlet valves for a very low resistance reading or a dead short Also check the motor etc for a short to earth using a Insulation Tester. Does it pop the fuse while it's meant to be filling up or while it should be spinning or washing? Cheers
May 15, 2009 | Maytag Dependable Care LAT9706
Samsung L730 wont extend lens and dosent turn on right
Try removing the batteries and memory card. Let the camera set for awhile. Put the batteries back in but not the memory card, restart the camera. Does it work know? If it does, turn the camera off put the memory card back in. Turn the camera on, does it work now? If it doesn't, replace the memory card.
Dec 27, 2008 | Samsung Digimax L730 Digital Camera
Lens cover not opening and mode dial problems.
It is a cheap part, if you can find someone that sells it. I would sell it as-is online somewhere to recover some money.
Nov 12, 2008 | Panasonic DMC-FX07 Digital Camera
Panasonic DMC-FX07. Dropped and died
this cam slip from my hand and the lence was open thats why lence one side down position and not working, i took this cam from saudi arabia 2 month before so pls give the suggest what i will do and where solve the problem
Nov 01, 2008 | Panasonic DMC-FX07 Digital Camera
Sony DSC W70 lens stuck!
This is what I found out on this and how I fixed it. This is all relative to my camera. What I found out was the view finder has a small detent which rides in a groove. When droped or bumped it falls out of the groove. To fix this I had to remove the lens assembly and realign the view finder guide. I was a fairly simple procedure.
Aug 12, 2007 | Sony Cyber-shot DSC-W70 Digital Camera
Cameras Logo
26 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
