Question about Dual XDVD8170 Car DVD Player
Hoowww parking brake wire how do i bypass i have a olds 98 1990
    President:
  • 624 Answers
You need to put it on a switch that goes to ground in one position and in the other position it needs nothing connected. Then you flip the switch to ground it when you what to watch the video
Posted on Jul 01, 2008
There is no video on my kenwood ddx8017, why? Do i have to bypass the parking break wire? which one is it, the solid green, or red with black, or pink?
If you want to watch videos on your unit it is necessary to bypass the parking brake wire from the Kenwood unit. The parking brake wire is light green and the best possible way to bypass the unit is by installing a toggle switch. The toggle switch should be a two wire device. Connect one wire to ground and the other wire to the parking brake wire from the unit. This will allow you to switch the supply on the wire to ground when needed.
Also, in some older Kenwood units you could just as easily connect the parking brake wire to ground and be done with it but, it does not always work.
Oct 08, 2010 | Kenwood DDX8017 6.5" Wide Dual DIN Indash...
How do i by pass parking brake wire for indash dvd jensen vm9312 i'm puting it in old car no p.b.
Hi jason
To answer your question;
You do not need to connect that wire but you need to bypass the parking brake function in the menu.
Here`s the parking brake bypass procedure:
1: Go into AM/FM mode
2: Hit "setup" on the remote control
3: Enter 543210 on the remote, listening for the beep for each number
entered
4: A new menu will appear. Touch the button that has the hammer/screwdriver on it in the upper left-hand part of the screen.
5: Select Brake bypass to "ON" and hit the "X" near the bottom of the screen.
6: Use the unit wisely and above all safely. A ticket is one thing, causing a fatal accident due to negligence is another.
Hope this help Cheers
Apr 20, 2010 | Jensen's VM9312 Car DVD Player
Parking brake safety bypass
If you have the old firmware then all you need to do is ground the parking brake wire
if you have the new firmware(just bought the system) a toggle switch is involved:
1 - connect e-brake wire from dvd unit to the switch
2 - connect a ground wire from switch to the unit chassis(any good metal grounding surface will do)
3 - pop in a dvd, toggle the switch back and forth 2 or 3 times depending on what wire you placed where...and voilaa!! your dvd system should work in motion!!
Jun 26, 2009 | Jensen VM9510 Car DVD Player
Putting kenwood kvt 617 dvd in rear of surburan how can i bypass parking brake so movies can play while driving
On bypasses you can either hook the parking brake wire straight to ground, if that does not work you can install a toggle switch between the parking brake wire and ground so you can mimic the parking brake on off.
Jun 04, 2009 | Kenwood KVT-617DVD Car DVD Player
How do i bypass the brake safety switch on a pionner avh-p4000
CONNECT A SWITHC TO THE PARKING BRAKE WIRE ONE OF THE PINS FROM THE SWITCH TO GROUND AND THE OTHER SIDE TO THE PARKING BRAKE WIRE.
Mar 14, 2009 | Pioneer AVH-P4000DVD Monitor
Parking brake bypass
apply 12v positive to the wire to bypass the parking brake
Dec 12, 2008 | Jensen VM9510 Car DVD Player
How do i bypass the parking brake switch in order for my video to play
To bypass the parking brake you should connect the parking brake wire from the unit to ground. It is better to do it via a switch because is illegal to watch video while you're driving. :)
May 15, 2008 | Car Audio & Video
BYPASS
The security device was created to avoid you from watching DVD's while driving. It is simple to bypass. Simply take the parking brake wire (blue/yellow stripe wire) and connect it to the a ground wire (all black wire). This will trick the DVD player into thinking that the car is in park with the parking brake on at all times.
Apr 03, 2008 | Panasonic CQ-VD7001U Car DVD Player
Parking Brake Bypass
I know my PLTS75 when we hooked it up. you connect the brake wire to the negative pole to bypass that
Mar 28, 2008 | Pyle PLDF7IN Car DVD Player
Parking brake
ground the pink wire that will allow player to play video
Feb 04, 2008 | Car Audio & Video
Dual XDVD8170 Car DVD Player Logo
60 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jose Velazquez
Jose Velazquez
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
