Question about Kenmore 24032\24036 Top Load Washer
Clothes still wet after spin cycle
I have an 80 series kenmore that is a top loader. It appears that during the spin cycle my clothes are still wet after the spin cycle. I'm thinking I have a clog or need to have a new filter or have the filter cleaned. How do I do so myself?
Diane
  • 1 more comment
  • Anonymous Nov 01, 2008
    the final spin the clothes are soak and wet
  • Anonymous Jan 04, 2009
    same problem with kenmore 80 series spin cycle will not spin out clothes. Does not appear to be sipinning with enough foce.
  • Anonymous Mar 11, 2009
    when on spin cycle it is making a very loud noice and not spinning at all
  • 481 Answers
The first 2 things you need to check is:
  1. if it is spinning as fast as it used to
  • if not it needs a new clutch assembly ($35 + labor)
  1. if it is draining as fast as it used to
  • if not then it needs a new water pump ($30 + labor)
there is no filter that would cause this problem. prices are from repairclinic.com
  • if none of this describes the problem then let me know and i will help you figure it out. i know these machines well.
Mike
Posted on Jul 07, 2008
Clothes still wet after cycle is over
Be sure drain hose is not kinked and no higher than the top of washer to drain pipe. Remove clothes as soon as it stops spinning
Jun 23, 2010 | Kenmore 23822 Top Load Washer
During the spin cycle water pours continuously like fill cycle
This problem is commonly attributed to either a water inlet valve leaking by, or a pressure switch malfunction. The following link explains how to diagnose the problem:
http://www.fixya.com/support/r3753517-whirlpool_top_load_washer_fills_when_not
I've included parts sources (if required) and how to repair each problem. If you have any questions, please post back and let me know. I hope this information is helpful to you.
Mar 19, 2010 | Washing Machines
Wet clothes
the reason the clothes are wet is the washer is not shifting to high spin,does the washer have a speed switch(normal wash spin,high wash spin)if its not the speed switch than the clutch is bad,how old is the washer?mike
Apr 19, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore elite calypso top loader clothes still wet after spin
more than likely the machine has a bad clutch or motor.. in most cases it is cheaper to just buy another top loader.
Mar 06, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore washer series 80, Clothes still soapy
If you are getting no water spray during the rinse cycle that would cause the soapy clothes issue.
Are you getting cold water during the wash/rinse cycles? If you have the machine set to warm/warm you may only be getting hot water while the final spin is calling for cold.
If you have cold water available then the timer is not calling for the water spray. The problem is either in the mixing valve or the timer.
Jan 10, 2009 | Kenmore 23822 Top Load Washer
Wet clothes at end of spin cycle
sounds like your transmission is not working properly. check your warranty information. (should be in your owners manual) many of the whirlpool made top loaders came with a 5 year warranty on the transmission/gear case
Dec 29, 2008 | Kenmore 22422 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
886 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
