I have a remote control truck from radio shack. Well I had to install another motherboard from another r/c (from same radio shack model) It worked for maybe 2 minutes then I noticed one of the wires on the motherboard wasnt soldered good. So I resoldered it and now it goes by itself as soon as I turn on the remote. Please help
Its not the r/c pictured. That was the only way I could figure out which category it went in. Its green f350 with regular tires and mattracks tires. It will go by itself as soon as I switch on the remote control. Please help Thanks getting tired of messing around with it.Its not the r/c pictured. That was the only way I could figure out which category it went in. Its green f350 with regular tires and mattracks tires. It will go by itself as soon as I switch on the remote control. Please help Thanks getting tired of messing around with it.
Also this is not a picture of the truck I have. Its a f350 with mattracks takes 7.2 volt battery.Also this is not a picture of the truck I have. Its a f350 with mattracks takes 7.2 volt battery.
Yes it worked before being soldered on and a little after then one of the hot wires came unsoldered a little. It just goes by itself as soon as I turn the remote control on.Yes it worked before being soldered on and a little after then one of the hot wires came unsoldered a little. It just goes by itself as soon as I turn the remote control on.
You can't post conmments that contain an email address.
Looks like the one you soldered is not supposed to be there.
Check it again and look for the part that might the original soldered point for that wire.
Hope that solve everything!
Read the instructions that come with the Radio Shack remote control. Or give a model number. Chances are you can find that remote controls manual online by searching google.com or such.
