Central air coil is frozen over - Heating & Cooling
    Champion:
  • 254 Answers
Ok lets start by checking the filter inside the furnance. Also while your there make sure the indoor fan is running. If the filter does not fix your problem you could have a leak and be low on refrigerant.
Posted on Jul 01, 2008
Bryant central a/c working great, then suddenly inside fan not working, but outside unit on and pipe frozen.
sounds like inside coil froze due to low air flow. bad fan motor, fan relay,dirty coil or filter.
Sep 09, 2013 | Bryant Heating & Cooling
Outside central air conditioning unit not working, is there a reset button?
Hello my name is Heath it will be my pleasure to assist you. The first thing to check is the filter in the furnace or air handler. Also check the inside coil to be sure its not frozen up. Does the air coming out feel cold? It sounds like the unit could be low on charge which means it has a leak and should be leak checked repaired and properly charged. You would need refrigeration gauges to put on the system in order to properly check the refrigerant charge in the system. One other thing could be a dirty condenser coil. Turn the power off to the unit and use a garden hose with a strong nozzle and spray water through the whole coil to try and blow any dirt or debris through the condenser coil in the outside unit.
Sep 05, 2011 | Haier ESA3125 Wall/Window Air Conditioner
My central air conditioner wont blow out cool air and wont blow enough to cool the house what could be the problem?
Check the Filter 1st, that might lead you to find either a frozen coil.If neither of those things
are the problem, check to make sure the blower is operating.
Sep 03, 2011 | Fedders A&B Chassis A1A07W2B Air...
My A/C blowing air, but it is not cool. It has started freezing up. We just replaced the air filters and since then it is freezing up. We even gently cleaned the a/c coils before replacing the filters. ...
Hello, sounds like it is either a low charge or lack of airflow, what type of filter are you using? sometimes those filters that claim to be super effecient will actually cut down on your airflow and cause the ac to freeze up.
Jul 15, 2011 | Intertherm Heating & Cooling
Compresser freezing up
not enough airflow over evaporator coil or low on charge. Give more details for better answer.
Oct 05, 2010 | Heating & Cooling
Frozen central ac line inside and out Rheem RAKA-030JAS SER# 4951-M1593-1350
There could be a few possibilities, but I will tell you the most prevalent ones.....Dirty air filter or dirty indoor coil, bad blower, restricted air etc. The other is too low on freon. Turn ac to off and fan switch to on...wait 45 minutes and try again by setting thermostat no lower than 72. While waiting the 45 minutes check the filter , blower, and indoor coil.
May 15, 2010 | Heating & Cooling
We just turned on our central air conditioner last night. today the temp of the house was 80 degrees. someone in the household placed the tempature on 70 degrees cool on auto. we have not felt any air...
Did you hear the indoor unit running (the fan blowing)? If so, there's a good chance that either the filter is plugged or more likely, the evaporator coil is iced up and preventing any air from flowing into the dwelling.
This points to a refrigeration issue with the unit - possibly a leak or low refrigerant charge.
You should turn the A/C off and leave it off for a day. Then just turn the indoor unit fan on by selecting the fan "on" setting on your thermostat. If you feel air coming out of the vents, then the evaporator coil was probably frozen.
If you are not an HVAC tech, it's time to call for professional help.
Apr 07, 2010 | Heating & Cooling
The bigger of the two pipes of my central air unit is frozen and i am getting very little cold air please help
Sounds like you have either a low refrigerant situation or an airflow problem. The lack of cold air is most likely due to a frozen up evaporator coil. You should check your filters and call your service man.
Aug 14, 2008 | Heating & Cooling
Air conditioner problems
Check your filters first. Replace if needed. Also check that the evaporator fan or blower fan in the furnace is running. If this does not fix it you most likely have a low refrigerant charge.
May 30, 2008 | Whirlwind FH-778 Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
