Question about Pioneer PL-990 Turntable
Platter problem My platter is hitting the motor pulley. I don't know if it's the platter sitting too low or the motor pulley is too high, but whenever I turn it on it just catches on the hole in the platter for putting the belt on. What gives?
It sounds like the motor pulley is too high. try to screw down the pulley, maybe it came loose...The platter is designed specifically for the turntable and should fit perfectly in place....Another reason might be that the platter does not belong to the turntable, it might be too small and therefore sits lower than it should.
Posted on Aug 18, 2008
Teac schematic
To replace a drive belt.
Before starting unplug from mains power source.
1, Remove the rubber platter mat to expose the platter.
2. Put your thumb and forefinger through the two round holes and lift the platter off. You may need to give the centre spindle a light tap (whilst applying upward pressure) with a screwdriver handle or some similar tool that will not leave any marks or damage.
3. Remove the old belt and wipe the platter pulley and motor pulley with an alcohol swab to remove any old belt residue.
4. Place the new belt around the platter pulley making sure t is sitting flat without any twists.
5. Flip platter over the right way up. There are1or 2 larger rectangle shaped cut outs in the platter.
6. Through the cut out pinch up the belt and slip a finger or belt hook between the platter pulley and the belt gripping the belt ready to fit over the motor pulley.
7. Align the centre hole of the platter with the spindle and place platter back into position keeping a grip on the belt.
8. Slip belt over motor pulley and give the platter a light clockwise rotation to ensure the belt is riding correctly.
9. Replace the rubber mat and then run the turntable to ensure correct operation.
Job done.
Stylus city
Jul 03, 2014 | Teac Audio Players & Recorders
Change belt on rotel 310 turntable
Job done.
Jul 02, 2014 | Audio Players & Recorders
How to replace belt
To replace a turntable drive belt.
Before starting ensure you disconnect the power supply.
2. Put your thumb and forefinger through the two round holes and lift the platter off. You may need to give the center spindle a light tap (whilst applying upward pressure) with a screwdriver handle or some similar tool that will not leave any marks or damage.
7. Align the center hole of the platter with the spindle and place platter back into position keeping a grip on the belt.
Remember, when changing between 33 & 45 rpm the platter must be rotating to ensure correct belt repositioning on motor pulley.
Job done.
Copyright, Styluscity.com
May 05, 2013 | JVC AL A158BK Turntable
Replace belt
Job done.
Onkyo Diagram
Job done.
Apr 27, 2013 | Audio Players & Recorders
Replace turntable belt
Job done.
Apr 26, 2013 | Stanton Audio Players & Recorders
Need Instructions to replace belt on panasonic SL-5N Turntable
Job done.
Apr 11, 2013 | Audio Players & Recorders
Belt needs installed
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} b\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} 285 1 7560000 10692000 359410 259 261 257 280 262 283 1 0M=D#_"(P_4>T8_8*@@.320 5 1 1 286 False 0 0 -1 304800 243 True 128 77 255 3175 3175 70 True True True True True 282 134217728 1 1 -9999996.000000 -9999996.000000 8 Empty 16711680 52479 26367 13421772 16737792 13382502 16777215 Bluebird -87325200 -87325200 (`@````````` 267 263 5
Job done.
Copyright.. Styluscity.com
Nov 26, 2011 | Aiwa PX-E860 Turntable
How do you put on a drive belt?
Hi Janie, Thanks for your question. To replace a drive belt.
8. Slip belt over motor pulley and give the platter a light clockwise rotation to ensre the belt is riding correctly.
Job done.
Note the new belt should sit on the platter pulley and not fall off when the platter is flipped over the correct way up.
When changing speeds between 33 and 45 always be sure that the platter is turning to ensure proper placement and rpm.
All the best, John. Styluscity@gmail.com.
Oct 30, 2011 | Technics SL-BD22 Turntable
Turntable belt
Check below exploded view of Aiwa PX-E860 might help you to install belt.
Need further help, let me know.
Oct 24, 2008 | Aiwa PX-E860 Turntable
Pioneer PL-990 Turntable Logo
94 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
