Question about Toastmaster TBR20H Bread Maker
Paddle ??? Hi, buddy! How can I get / find the paddle?
  • jrdpo2 Jul 03, 2008
    A couple of e-bay addresses would have been nice.
    Novelist:
  • 161 Answers
Go on E Bay. They have a couple of stores that sell nothing but parts for bread machines. They are expensive $15 - 20
Posted on Jul 03, 2008
Hi there! I've been using my toastmaster model 1142 bread maker a lot lately like almost every day and it has stopped mixing the dough. Once the dough is dense the motor sounds like its running but the...
Pull the pan out and turn the little paddle with your finger. Is the paddle slipping on the spindle? If yes, then your paddle is worn out. If you move the paddle around and it doesn't slip on the spindle then look to see if the ears on the bottom of the pan are turning too when you move the paddle. If yes, then your problem is further down in the machine. You may have a slipping belt. Those are some of the things you can check.
Nov 07, 2010 | Toastmaster 1142 Bread Maker
Re Black & Decker Bread Maker: Most of the time the paddles remains stuck in the pan and the bread sticks to the paddles. As a result, loaves usually have large chunks torn out of them. There are...
Hi, Take the paddle out of the machine at the end of the last kneading cycle and before final rise.. Use pause or take pan out of machine to remove paddle. OR... spray the shaft with a small amount of olive oil. This should allow paddle to come out when bread is done. You will have to fish the paddle out of the bread in this step. Hank
Oct 31, 2010 | Black & Decker B2000 Bread Maker
The machine gets warm but the paddle doesn't turn.
Hi, The paddle should turn freely by hand with the bread pan out of the machine. Make sure the pan is inserted in the machine correctly. If the motor shaft turns but the paddle doesn't then the sealed bearing that the paddle rotates on has failed and is frozen so the paddle does not turn.. You may need a new bread pan. Hank
Jul 01, 2010 | Kenmore KTR2205SPR Bread Maker
The kneeding paddle is no longer smooth.where can
If the paddle is sticking it could be the sealed bearing on the bottom of the pan is sticking. Either that or the belt is loose and not allowing the paddle to spin freely.
Hank
Feb 08, 2010 | Breadman TR2200C Ultimate Bread Maker
Can the kneading paddle be removed before baking?
Yes you can remove the paddle before baking. The cuizinart has a buzzer that sounds when to take the paddle out
If you want to take the paddle out you should make sure your machine has a pause feature so you don't lose any rising time.
Take pan out of machine, empty dough into a bowl, remove paddle, squirt the shaft in the bread pan lightly with veg oil (prevents sticking) then return the dough after final kneading time and before final rise.
Hank
Aug 26, 2009 | Kitchen Appliances - Others
Have lost the paddle for my cookworks breadmaker (model 11597)
Hi David,
You can buy your replacement paddle here- http://www.ioffer.com/i/Cookworks-11597-Kneading-Paddle-Blade-94374281. You can use the drop-down "Your Country" menu to select pricing for the UK.
Jan 23, 2009 | Kitchen Appliances - Others
Long of the canoe
When you are sitting in the boat and the blade is totally immersed, the top grip should be about shoulder high for general and touring use. For white water and more specialized paddling, a longer paddle, especially for the stern paddler, provides more reach and leverage for maneuvering the boat.
Dec 01, 2008 | Advanced Elements Straitedge Canoe
Remove drum paddle from hotpiont wma37 washing machine
Hi.
Firmly grip the paddle, and pull it towards you, this should release same. When you put it back, locate the paddle in the slots, and push firmly away from you
towards the rear of the drum
Good luck
Nov 22, 2008 | Washing Machines
Toastmaster TBR20H Bread Maker Logo
24 people viewed this question
Top Toastmaster Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Henry  Thomas
Henry Thomas
Are you a Toastmaster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
