Question about Gateway Computers & Internet
When i try a full system restore i get the message file \minint\system32\halaacpi.dll error code 4121
  • 6 more comments
  • drelec97 Jul 02, 2008
    i tried solution #1 and i got an error message saying windows could not start because the following file is missing or corrupted
    \windows\system32\config\system
    ok so how do i reload the system
    i have the windows setup cd and every time i try to start the setup it keeps giving me the same error message. Am i doing something wrong.
    i am not capable of doing anything in dos other than pressing r for repair and getting the same error message or going into the settings menu
    the windows cd will not boot
    i tried and it keeps giving me the windows\system32\config\system is missing or corrupt
    i try doing this and it tells me to press r for system recovery and gives me 5 seconds to do so
    it is windows xp media center version 2005 os disc
  • 983 Answers
If you are not able to boot from the cd then i think you have not changed the boot order in bios settings to cdrom ...
tr changing it ...
if you have already done & then not working means there may be some problem in the cd ...
try using other cd .
if you are not able to repair then may be system is fully infected with the virus or the file system may have got corrupted ...
just try formatting the drive & then try new installation .....
you can do this after booting from the windows xp cd ...
after you boot then press new installation & after that format the partition & it will surely install if there is no problem in the cd ...
Posted on Jul 02, 2008
  • 1 more comment
  • Dileep Keshavanarayana
    Dileep Keshavanarayana Jul 02, 2008
    let me know what happens after following this .
    your system is surely infected by the virus so only you couldnt able to system restore & repair so once you format the drive consisting of the OS then the problem will be solved ....
    take a back up of your important data & just format the drive & do the fresh installation of the OS...
  • 2,071 Answers
Buy a installer Windows XP SERVICE PACK 3
one of the features inside the installer.
Learn more about set up process;
    Sergeant:
    Champion:
  • 248 Answers
As the computer boots up after turning on the power, you will most likely see a black screen.... trying to load.... while on this screen, press either F2, F8, delete or escape key to enter bios mode...(depends on the system, look for the one that says "press ____ to enter setup")
bios mode will give you options... look for the option that will allow you to boot from cd... choose that! Restart the system with the windows install cd in the cd-rom drive... this will boot the computer through the install cd which will allow you to reinstall the OS
    Guru:
  • 1,342 Answers
Most read errors are due to corrupt MBR or failing hardrive.
If you can boot the PC with your Windows CD you can try running the Repair Console. Type "fixmbr" at the dos prompt once you get in. Answer yes and reboot. You might also want to type "fixboot" also before restarting the computer.
  • 3 more comments
  • Georgia B
    Georgia B Jul 02, 2008
    If it's hard drive failure you might want to back up your data if you can and purchase a new one.
  • Georgia B
    Maybe it's the CD. Can you borrow someone else's to see if the same thing happens??
  • Georgia B
    You can download setup disks from Microsoft
  • Georgia B
    I know it goes by quick. You have to be ready to hit the "r" key.
  • Georgia B
    Try unplugging all the cables at the back of your
    tower except for the monitor, power, keyboard, & mouse cables.
    then, resume reinstalling your windows xp.
  • Gateway Master
  • 13,433 Answers
You need the windows setup cd, or restore discs if you have these.
  • 5 more comments
  • Ekse Jul 02, 2008
    you need to perform a full - fresh windows installation. that will fix the problem but also you will loose most of your files.
  • Ekse Jul 02, 2008
    you keep throwing us out from the door with requesting more assistance ( new expert comes in )
    The windows setup cd should start up a blue setup, it should not start windows if you are geting the same error about windows\system32\config\system
    You need to enter bios and change the boot order so the computer starts from cd before the hard drive.
  • Ekse Jul 02, 2008
    you need to change the bios settings so it starts up from the cd first.
  • Ekse Jul 02, 2008
    Im uploading you a video on how to change the bios settings.
  • Ekse Jul 02, 2008
    Dont press that, go with the normal setup, don't recover.
  • Ekse Jul 02, 2008
    or what kind of recovery cd you got? normal xp setup cd?
  • Ekse Jul 02, 2008
    Heres the video on how to change the bios settings.
    It took a while to process on youtube maybe too late.
    Put the cd in and let the setup start. dont start automatic system recovery or don't try to repair, just continue and do a full reinstall - enter setup.
    Genius:
  • 2,028 Answers
This is an operating system error. You can try a reloading the system, however, this usually indicates a hard drive failure. If you have any issues during or after the install then the drive will need to be replaced.
  • Ryan Rogers
    Ryan Rogers Jul 02, 2008
    Run the disc until it get to the point of finding previous operating systems. Once it's found the operating system then run the repair from there. Don't try the repair from the recovery console, this is difficult and if you don't know what you're doing it's almost impossible.
  • Ryan Rogers
    You will need to get to the boot menu at start up, or set the CD drive to boot before the hard drive in the bios/utilities in order to boot from your disc.
    Guru:
  • 1,894 Answers
Why not you try a repair CD of XP.
  • dewan nafees ahmed Jul 02, 2008
    sir.
    this is just a problem with your operating system.
    for repairing your operating system you need not even get into the operating system.
    you can proceed it by choosing the second option during the windows CD boots.
How to fix \minint\system32\kdcom file cannot load error 4 Emachine
Download this file to your computer and burn it to a CD:
http://majorgeeks.com/downloadget.php?id=6501&file=1&evp=ef4247319d4b536cb88b74d1ae4842b0
If you don't have an app that can easily burn .iso files to a CD then get this awesome little FREE app and install it:
http://www.majorgeeks.com/downloadget.php?id=4870&file=9&evp=0636b68877cb69b15faa3374cb1dcd89
The Bootable CD you burn should fix your computer. It's really easy to use. Just follow the instructions from page 15 to page 33 in this pdf:
http://support.kaspersky.com/downloads/guides/kasp10.0_rescuedisk_en.pdf
You basically want to update the virus definitions and select all of the checkable boxes to scan and run the scan and then allow it to delete or quarantine the bad files.
Sep 01, 2012 | E-Machines eMachines Desktop PC
C:\minint\system32\restore.log mising
Restore points are located in C:/Windows/system32/restore.
You have an unusual error message which talks about C:/minint folder. Seems like this is a virus issue. It would be better if you run virus scan for your computer.
Also run a system utility software RegInOut to refresh your PC.
Dec 13, 2011 | Computers & Internet
Says windows root>\system32\hal.dll. is missing or corrupt, can't use laptop Please advise, regards Jason
some system on your windows has corrupted, it caused by a virus or bad disk
you need to restore your system to fix this issue
if your laptop build in windows xp and you have a restore disk just follow these steps
1. turn on your notebook
2.quickly press ctr and f11 simultaneously
3. click restore when "Dell PC restore" message appears
4.click confirm (it means you will lost all data in drive which contains your old operation system)
5.wait and click finish when the process of restore finish
if your laptop build in windows vista you can follow these steps
1. turn on your laptop
2. quickly press f8
3. when "Advance Boot Menu" message appears just click repair
4. select language and click next
5. log in and click ok
6. click dell factory restore and click next
7. click yes on the box "format hard drive and restore the system"
8. when the process finish click finish
if you don't have a restore disk build in your laptop you need a windows cd installer to reinstall your os
Jun 06, 2011 | Dell Inspiron 6000 Notebook
File\minit\system32\Kdcom.dll could not be loaded.The error code is 4. The above massage is showing when I try to restore my Acer Aspire One.I am not able to run my window XP. Please help me.
It sounds like this file is corrupt you need to download a fresh copy and install it.
I would suggest trying to open your laptop in safe mode. While you are booting continually tap F8 and you should get a different menu. You need to select start in safe mode with networking. Follow the instructions to open it as an administrator.
When you have the system open use the internet to download a fresh copy of Kdcom.dll from here
http://www.dll-files.com/kdcom.zip?0WMmXCVMeO
Unzip the file to the same path as you show in your error message and overwrite the old copy of Kdcom.dll
Now restart your machine and hopefully this will have solved your problem.
Mar 13, 2011 | Computers & Internet
Error messages :system32\hal.dll missing or corrupt"
Looks like you might have to format your drive and reload windows from scratch,unless you can restore deleted files from your recycle bin
Apr 30, 2009 | Dell Microsoft Windows XP Home Edition
Tosiba laptop could not start not even with safe mode.
The error message refer to system files it cannot load dur to either corrupted or missing files.
You can try to do a repair with your Windows CD install disk and if this does not work you will need to reinstall Windows again together with any drivers that Windows didn't install and your programs.
Note you will lose you data in this process, hoped you backed up your files.
Mar 03, 2009 | Toshiba Satellite A100-S8111TD Notebook
Windows problem?
just reinstall your Oeratuing System
Dec 09, 2008 | Sony VAIO RB30C (VGCRB30) PC Desktop
Problem w/ WIN2000 Pro & XP Pro
HERE IS THE SOLUTION :
click on the link given below and find oc25.dll....if you are unable to find press keyboard key cntrl + f .A dialog box will appear now type oc25.dll and hit find key and you will find the oc25.dll .click on that file to download it to your computer.
http://www.dlldump.com/dll-files/O_2.html
Once you have downloaded the file you are looking for you still need to make sure Windows or the program causing the error can find it. Follow these steps:
1. If you are encountering an error with Windows...
The file you downloaded needs to be placed into the Windows System directory. On most machines this is one of the following locations:
C:\Windows\System (Windows 95/98/Me),
C:\WINNT\System32 (Windows NT/2000), or
C:\Windows\System32 (Windows XP).
If you are encountering an error with a particular program...
The file most likely needs to be in this program's directory. This directory is where the program is installed (i.e. c:\Program Files\ThisProgram).
If this step solves the problem, you do not need to complete step 2.
2. You may to register this file with Windows. Click on the Start Menu and then on 'Run'. If you are replacing a Windows system file, type the following command:
regsvr32 \windows\system\file.dll (Windows 95/98/ME),
regsvr32 \WINNT\system32\file.dll (Windows NT/2000), or
regsvr32 \windows\system32\file.dll (Windows XP).
For example, 'regsvr32 \windows\system\apphelp.dll'
If you are replacing a file for another program, change the directory where appropriate. For example, 'regsvr32 \program files\Norton\xyz.dll'
If the file is registered correctly, you will receive a positive confirmation message.
Please let me know your feed-back.
Thanks
dilipbagdi
Technical Associate
Apr 28, 2008 | Microsoft Windows XP Home Edition
My laptop wont let me use most programmes because of system 32
What specific error are you getting and what operating system do you have.
Jul 17, 2007 | LG X-Note LM50 Notebook
Computers & Internet Logo
70 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
