Question about Sony Grand WEGA KDF-60XBR950 60" Rear Projection HDTV
Sony Grand WEGA KDF-60XBR950 60 3 RED BLINKING LIGHTS
Upon turning on this TYV tonight it now has a red blinking light (3 times) and after a couple of minutes powers off. Was working fine yesterday. Replaced the bulb less than 6 months ago. Check to make sure the doors and covers were all secured.
Any idea? Thanks
  • 1 more comment
  • miketurp Jul 01, 2008
    Unfortunately that solution did not resolve the issue. I left the TV unplugged overnight and tried it again today with the same resultes. 3 red blinking lights and the after about 30-60 seconds the TV powers off.
    Anything else to try?
  • miketurp Jul 02, 2008
    posted by miketurp on Jun 30, 2008Report abuse
    Any idea? Thanks
    Comment by miketurp, posted on Jul 01, 2008
    I will try vacuming the fan later and blowing away any dust. Do you think the problem could be similar to the one discussed that this site........
    http://www.agoraquest.com/viewtopic.php?...
    Genius:
  • 1,665 Answers
Power supply troubleshouting:
(Some experience in electronics repairs and measurements needed)
remove the TV back.
Locate the big mains smoothing capacitor (near the mains input usually) its often 40uf-220uf 400v on 240v mains.
Switch on and test the voltage across this capacitor and expect 300volts or more (320v average uk) or 1.414 times the mains RMS voltage
Sony Grand WEGA KDF-60XBR950 60 3 RED BLINKING LIG - 07d6466.jpg If 300v is ok at the mains smoothing capacitor
then check to see if 300v is reaching the chopper transistor
(middle leg) and its not at the other two legs.
d6fc2da.gif now check the output from the chopper transformer it will usually have at least 2 outputs
one is HT ,about 95v to 115v for 14" to 115 to 150v 28" screen and the other LT will be about 10v to 20v
if HT very low then check for shorts across loptr or tripped crowbar
if 30v to 70v then use wire link to short out the base /emitter of the loptr, if voltage rises then loptx is probably gone.
Posted on Jul 02, 2008
    Genius:
  • 1,447 Answers
Hi-
If you have tried cleaning and reseating the lamp for it and still you are getting the 3 red lights, chances are there is a problem with the mainboard itself, if product is still within warranty, call your manufacturer for Home service, if not have it service. These lights indicate a fatal error internally. Thanks for using Fixya!
  • 4,234 Answers
The 3 blink code indicates an over voltage condition detected and the set shuts down. This is usually a problem with the resulator IC in the power supply circuit. I don't have the manual with me at the moment, so I can't give you the specific part. This type of repair will usually run about $25 or so for parts plus hte local labor rate. I'll loko up the specific part(s) and post here.
Dan
  • Sony Master
  • 6,487 Answers
Most of the red blinking light. Problems can be fixed with a can of air and a vacum.
what happens is the sensors around the cooling fans get so dusty they send false signals that ether fans have stopped working so you either get an over heat code etc.
you need to first vacum the dust out of the vents on the back then with the can of air blow out as much remaining dust as possible.
this always eliminates the red light syndrome for me.
Hope that helps........
Posted on Jul 01, 2008
  • 689 Answers
It seems there is power supply related issue like overheating, I suggest you to try again after keep the TV unplugged about 30 minutes.
Red flashing after tv turn on for KDS-R60XBR1
How many times does the red light flash before it pauses and then starts again? This is important info as it helps to diagnose your problem.
Mar 20, 2013 | Sony Grand WEGA KDF-55WF655 36" Rear...
Yesterday i changed the lamp. After this I turned the TV on and it worked fine. This morning, upon turning it on,it showed for a few minutes and then the screen went blank, the green power light started to...
how many times is the red led blinking? if you just changed the lamp make sure and check that the lamp door is secure if the door is ajar it will flash 3 times.
Dec 22, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
Tv won't turn on. It blinks green then red.
Question shows tv is Sony KDF-60WF655.
Green light blinks when tv gets prepare to fire up lamp, check internal circuits then show picture on front screen.
Red light blinking shows some kind of internal problem during circuit check and protection got activated upon some failure.
Count the red light blink as you will see 3 second long pause and post it here to diagnose what section of tv got problem.
Did you replaced its lamp in last 2-3 years?
Thanks.
Jun 01, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
IT TURN OFF ITSELF RIGHT AFTER TURN ON GREEN
If the Lamp red light is blinking then replace lamp, replacement procedure is written in user manual and its easy.
If standby/ power red light is blinking then please count its blinking and post here. It is an error code that has info about problem in specific section of tv.
You will see 3 seconds long pause between blinks so count pause to pause.
May 11, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
Sony Wega Tv powers on w/ green power light and
need to know how many time the red light is blinking there should be a pause. 4 blinks is a fan, 3 blinks is the lamp door is not closed 6 blinks is thermal sensor.
Apr 22, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
Sony wega 70 in new bulb lasted 8 hours now
hello.+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
Oct 21, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Sony LCD television will not power on.
I get 5 blinking red lights for about a minute or so before it powers back down. The Sony TV has a specific light that i presume is supposed to light up when the bulb is out. I'm unsure if this is what it is.
no picture, no sound. tries to boot with green light blinking a few times. then goes to red blinking light, six in all, then waits a few moments, then another 6 blinking red light.
Bulb was already replaced several months ago but we do have the TV on for long periods of time.
Jan 15, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Sony Grand WEGA KDF-60XBR950 60" Rear Projection HDTV Logo
4,007 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
