Question about GE (PSS26MSRSS) Side by Side Refrigerator
GE side By Side GSS22JEMDWW
The defrost heater burned up. I replaced it with a new one. After I plugged it in and it ran a day or so I realized the ice auger & the crushed ice was not working. A week and a half later the evaporator was frosted complerely closed. I went to the printed circuit board on the back of the refrigerator and jumped J11-L1 to J-9, defrost circuit. The heater came on and glowed red, so I replaced the printed circuit board, WR55X10552. The auger & Ice work but a week and a half later the evaporators frosted completely solid again.
Did I get a bad board?
  • howardkinsel Sep 20, 2008
    heater coil was burn't out , replaced with new coil and defrost termination switch , lady calls back and said frosted up again
  • Anonymous Mar 28, 2014
    Ice up all over the evaporator coils solid
My refrigerator is warm, but my freezer id fine. What is the problem?
Posted on Mar 14, 2011
  • 54 Answers
Maybe but there is also a thermister in the defrost system that might be bad. The thermister is a small, white, barrell shape and is as big around as a pencil, It has 2 wires going in it and is attached to the top of the coils in the freezer.
Posted on Jul 03, 2008
GE GSH25GGCBBB COND FAN NOT RUNNING, COMPRESSOR NOT RUNNING
If the heater HAS shorted (burned look) it CAN destroy this board. FYI: Usually, heaters burn because the defrost termination thermostat is defective. The heater can literally melt the aluminum shield if this is the case.
ALSO: If your compressor won't run after replacing the heater and thermostat, WAIT for about an hour (with your fridge plugged in) before deciding this board is bad and preventing the compressor from coming on. Mine miraculously started...after 1.5 hours. YES.
It has a pair of freezer sensors (along with the simple defrost termination thermostat) with a microprocessor control that apparently brain fades sometimes.$$ saved.
Oct 15, 2013 | General Electric GSH25JGDBB: ENERSTAR 25.3...
Refrigerator not getting cold after couple days freezer gets ice about halfway up side by side
Behind the rear wall of the freezer=. PSI23NCRCBV Photo Here
you will see the location number 230 and that is the WR51X10055 Defrost Heater Assembly
Derfrost ice with a hair dryer and lets have a look at that heater. It is most likely burned out, I will be here should you have questions, Thanks Sea Breeze
Apr 20, 2013 | GE Profile PSI23NCR Side by Side...
My rgr profile side by side is at 47 and wont go down
The PSS26MSRSS is famous for burn out of the defrost heater part number=> WR51X10042 or 914080 Defrost Heater you may click on photo or banner for Repair Clinic once on our web site. You should always replace the defrost thermostat while working behind the freezer rear wall with power disconnected. Part=> WR50X10054 Defrost Thermostat or 1170024 Defrost Thermostat
Watch our "Part Testing" video to determine if the defrost heater has burned out and needs to be replaced. Please rate this solution and as always thanks for usingFixya, Sea Breeze
Feb 10, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
GE side by side has ice from top to bottom on inside back wall of freezer. GE repairman replaced defrost heater about 2 years ago. Could this part burn out this fast. Freezer temp. is 25 to 30 degrees.
It shouldn't burn out that fast but may have. Some of the side by sides came from the factory with only one heater. Later on it was decided that the replacement heater kit include a second heater. This could be the case for you.
Jul 11, 2010 | GE Refrigerators
Our GE sss25kfmdww "freezes up" and then stops refrigerating
Most times on that model the defrost heater and defrost thermostat will need to be replaced. The timer is built into the mother board and for some reason they are not the most likely reason. The defrost heater has a glass tube around the element and easy to spot if burned out. If you replace one part you should replace both. Now is a good time for you to do a little reading about your model. I will give you a link to the service manual and a page with a tech sheet, Sea Breeze
Dec 19, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE model GSS22JEMDWW. Replaced the compressor six
check the RTX overload on the compressor body its bad and trying to start the compressor
Dec 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer is not freezer
If it is not cooling the the most like ly reason is the defrost heater part number WR51X10055 You will need to defrost and look at the bottom of the evaporator coil behind the freezer back wall. If the defrost heater is burned out it will be easy to see because it is glass and the element inside will show burned. The part number is WR51X10055 If you replace the defrost heater you should also replace the defrost thermostat. Part number WR50X10054 Sea Breeze
Aug 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a GE side by side refrigerator that keeps blowing the defrost heater element. MODEL # TFT22JWDA WW SERIAL # TZ264141 I bought it from a GE dealer about 5-6 years ago. It ran fine for 3 years,...
In my GE side-by-side there is a defrost temp sensor located near the top of the evaporator coil. I think the control board uses that temp sensor to know when it should be done defrosting.
On the schematic of my fridge (link below), the defrost thermistor is part number 240 in the diagram (not part number 241, which is a different temp sensor located adjacent to the one you want)
http://www.partselect.com/ModelFrames.aspx?ModelID=361233&ModelNum=GSS20IEMDWW&mfgModelNum=&ManufactureID=2&Selected=00113321i06&Position=2&mfg=GE&Type=&Mark=2
I don't know why the defrost element would fail immediately other than incorrect supply voltage or just a bad defrost element.
Jul 28, 2009 | Refrigerators
GE Model tfx24f defrost not working.
Replace the defrost heater and defrost thermostat located behind the freezer panel inside the freezer compartment.
Jun 12, 2009 | GE PSC23NHN Side by Side Refrigerator
GE side by side GSS20IEP Refrigerator freezer freezing
this is a problem that is no stranger to most GE side by sides; GE has used a glass type defrost heater in the freezer which often fails. If you manually defrost your appliance (unplug and leave doors open for 24 hrs) then plug back in, it will appear to work normally for a few days and gradually build up frost on the evap panel (back panel in the freezer) and eventually the refrigerator side will seem to loose cooling due to frosted damper, or lack of cold air transfer over the evap coil. The fix for this is to replace the defrost heaters (s). While not as common, defrost thermostats can open causing the unit to skip defrost, and even less likely is the defrost control (either mechanical timer or adaptive defrost). First, defrost your appliance, then remove the evap panel and ohm out the heater(s), if open, replace. If they check ok, check your defrost thermostat (small disc like object attached by a clip on the evap. coil itself) for signs of popping open or open ohm readings at normally closed temperatures. Its a good idea to change this anyway when replacing defrost heaters as the two work hand in hand. Last, check the defrost timer by manually advancing the screw advance clockwise until you hear the first click, then check voltage to the defrost heater and thermostat, if no voltage present replace timer. If your appliance is equipped with a adaptive defrost board, refer to the schematic for proper diagnostics.
Jun 11, 2009 | GE GSS20IEP Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
593 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
