I have a Hampton Bay dehumidifier HB40 that produces ice and water over the grid and does not drain down the attached hose.
    Novelist:
    Champion:
  • 230 Answers
Turn it off and let it thaw. Once this is done remove and clean the filter. I am assuming that all the fans are operational too. Finally do not turn the temperature down too far. Just set it to the temp that you want it to be. Anything below 70 may result in a freeze situation.
If non of the above work, you will need a technician to measure the refrigerant levels in the system.
Posted on Jul 01, 2008
I have a hamptom bay dehumidifer model # HB40-D i am looking for the tray that you attach a hose to drain
it should be in the same area where you pull the pan out to dump. There should be a hose hook up inside the space where the drain box is.
Apr 30, 2011 | Dehumidifiers
/my dehumidifier has a hose attachment on the back. how does that work?
The hose attachment is used in place of the water collection bucket, to drain the water directly into a floor drain or a sump pump holding tank. A garden hose is connected to the "hose attachment" and run to the floor drain or sump pump holding tank. However, it will not drain UP, only DOWN.
Hope this helped.
Mar 20, 2011 | Amana Dehumidifiers
Not cooling
you may be low on refigerant
Jun 27, 2010 | Hampton Bay HBLG5004 Air Conditioner
There are power surges every few minutes that last for a few seconds. Other lights on the same circuit dim. This is really a Hampton Bay HB40 which I understand is the same unit. What can I do?
it sounds like the compressor is trying to start. if it hums and clicks then either the compressor relay or the compressor is bad. find the compressor and tap on the relay cover with the end of a screw driver. if it starts then change the relay
Dec 03, 2009 | Fedders RDG40 Dehumidifier
Water will not go down drain tube
Sounds like you have a clog. Either try plunging the drain in the stationary tub or replace the line from the humidifer.. Just a thought
Jun 10, 2009 | Danby DDR586R Dehumidifier - 58 Pints...
My Hampton Bay HB30 dehumidifier is still running, but no longer produces any water. The fan is running, you can feel the air moving. In addition, it will not turn off with the switch.
The filter and coils might be clogged with dirt. Turn of the unit and unplug it. Look at the filter and coils to see if they need cleaning.
Apr 17, 2009 | Dehumidifiers
Back of dehumidifier forms ice
I have a Hampton Bay HB50 with the same problem. I replaced the defrost control switch that connects to the compressor inlet line. The part # is 112900550001 and it was about $50.00
Dec 12, 2008 | Dehumidifiers
My dehumidifier stopped working. It doesn,t produce ant water. Is there a common problem with this unit. It is a model HB40 By hampton bay
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Oct 25, 2008 | DeLonghi DE500 Dehumidifier
Heating & Cooling Logo
118 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
