Question about Philips SA4020 MP3 Player
Windows Media Player11
I am not getting any sound..my speakers are fine and I have checked the volume panel on my PC.This is very frustrating.Are you able to help me?
oolaura@sympatico.ca
  • 8,596 Answers
Go into Start --> Control Panel --> Printers & Other Hardware --> System --> Hardware --> device Manager --> Audio controllers - look and see if your sound card has a yellow question mark by it. If so, right click on the device and select Update Driver (make sure you are connected to the internet). Also, make sure the mute button is not pressed inside of Windows Media Player 11 itself, or that the Windows Media Player 11 volume is turned all the way down (you can find these items in the lower right of the Now Playing window).
-Tha Mp3 Doctor
Posted on Sep 19, 2008
Low headphone volume on laptop
Hi , is the sound working ok on the pc speakers or is it the same.
Apr 09, 2013 | Computers & Internet
No start up music when opening media centre
A. As you have stated that "music plays just fine" and you also said that "there is absolutely no sound", so I am a little confused on this issue. Could you clarify whether you get any sound while playing a song/video on Windows Media Center or is it an issue only with the navigation sounds on Windows media Center? B. You may check the Volume mixer settings for the Windows Media Center.
Cross check the settings.
Here is how:
1. Right click on the Speaker icon on the task bar.
2. Click on "Open Volume mixer".
3. In the Windows Media Center mixer drag the slider down till you get the adequate sound.
Mar 26, 2013 | Audio Players & Recorders
Can't hear them on skype,they hear me very well
I assume you are using headphone for skype, but this test will work for speakers too. Open windows media player and try to play one of the pre-loaded songs. If you cant hear it check your computers volume controls (double click the speaker looking thing by the time clock, or access through control panel). Also check to make sure that the computer is not feeding the sound out through the digital output. This can be found by checking in control panel in the same place as your volume is. If it is feeding out to digital, change it to the analog output. Once you have sound with media player, you should have sound with Skype.
Hope this helps
Jan 27, 2012 | HP PROMO ELITE 7100 MT WINDOWS 7...
Sound (volume) of media player is at maximum but still very soft.
Go to your volume control via Control Panel or double click on speaker icon on task bar and check sound settings and computer volume or check your speaker's volume. Otherwise your speaker at fault.
Aug 25, 2011 | Computers & Internet
No sound device
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps
Jul 15, 2011 | AMD Computers & Internet
My pc doesnt play sound at all when i play music or video clips even when windows starts.
Hello
Try these steps 1. Check cables, make sure the audio cable is in the correct colored connector. make sure the power is hooked up 2. check power, make sure the speakers are turned on if needed 3, check volume. turn it up on the speakers themselves. then check the volume in windows (often located by the clock in the lower right part of the screen. or you can search thru windows control panel under sound. Or you can open windows media player and turn up the volume/unmute there 4. update drivers which you said you did 5. test a wide variety of audio thru a wide variety of different sources. windows media player, youtube, pandora.com etc.
If none of this works then its time for trial and error. You will want to try the spearks in a known good computer. or try known good speakers with your computer. see if you can figure out which is the problem. you may have a defective sound card or the speakers may be defective. at which time you will need to replace.
Hope this helps, good luck!
Feb 05, 2011 | Computers & Internet
No sound from external speakers with toshiba dynadock
if using XP, go to start control panel , sound and audio devices.Under the audio tab make sure the C Media CM106 sound device is selected under sound playback. Then under the volume tab set the volume somewhere in the middle or at the top if you don;t have active speakers . Then Under Speaker settings advanced, make sure the speaker setup is set to Laptop Stereo speakers. Also make sure the speaker volumes are up on the speaker volume button. click ok. If no result check that the cm106 sound decvice was cemented in as I saw it dissaper when I thought i had slected it. I think the key thing here is the device and the laptop speakers setting.
Aug 26, 2009 | Toshiba Dynadock Port Replicator, Docking...
Speakers aren't working
Is speaker Power indicator is working fine ?
If not, then u need to repair ur speaker.
If Power is fine then follow the steps :
1. Play any MP3 files in any media player. Did u get any error ? if yes then u need DRIVER for ur sound card.
2. If player plays file, and e\equalizer of player is animated then please check speaker jack(back of ur MotherBoard)
3. If still problem then please check configuration from control panel of your windows.may be volume of speaker is muted
If you have any problem let me know.
Thnaks,
Mukund
Einfochips
WWW.einfochips.com
May 15, 2009 | Dell A215 Computer Speakers
There is no sound and volume on my laptop.
check for the sound for the required audio might be muted
Oct 03, 2008 | Audio Players & Recorders
My sam sung yp-u2j is being odd
Change Windows Media Player11 back to Windows Media Player10. To do this: 1.Go to control panel and remove Windows Media Player11. 2.A notification will come up telling you if you remove Windows Media Player11 it will roll back to Windows Media Player10 click OK. 3.Save and exit all programs and rolling back will take a few minutes. 4.Restart your computer. Quite a few files might be missing from your MP3 player but just put them back on.
Jun 10, 2007 | Samsung YP-U2JQB MP3 Player
Philips SA4020 MP3 Player Logo
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
