Question about Brother MFC 7840W Printer
I had new tonner cartridge installed and it still says tonner life ended
  • 32 Answers
The toner cartridge in this machine has a gear assembly that resetting the "toner empty" light, it is build in a way that after resetting the printer it "disabling" the gear, so no second reset is possible. If you install the new cartridge previously and took it out it already run the reset cycle and will not be able to reset the printer even if it full with toner. Some time the gear reset system will not reset even if it is new. If you reset the gear and the light comes back your cartridge is empty.
You can open the gear cover on the toner cartridge and reset the gear to the original position it is not a big deal, but don't hold me liable to your technical ability. The reset gear is the most right gear behind the "window" on the right side of the cover, when you are holding the cartridge with the gear housing in front of you. Good luck.
Posted on Dec 14, 2010
SOURCE:
My printer is requiard toner rear end
You meen tonner near end you have to purchase a new tonner cartridge and replace or refill if you refill it you must get with your cartridge a reset card
Apr 15, 2014 | Xerox Phaser 3100MFP/S Laser Printer
Tip
Toner life end message
If printer displays "Toner Life End" after installing new cartridge, open front cover, press 'Option' button, then key *00 on the keypad. This resets the device so it knows it has had a new cartridge.
on Jul 07, 2008 | Brother IntelliFAX 775 Plain Paper Thermal...
The printer's ink pads are at the end of their service life. Please contact Epson support.
just reffill your tonner or cartridge and then see if the problem presist or not.?
Apr 25, 2011 | Office Equipment & Supplies
I changed my black cartridge, which was low. Now I get color bleeds, mostly yellow, in vertical streaks, on the printed paper.
Install the old black tonner back inside, if the yellow vertical marks disappear then the problem is in the new black tonner
Feb 02, 2011 | HP Color LaserJet 3500 Printer
Installed new cartridge and comming up machine won't regognise it saying tonner life end install new cartridge
To reset the sensor after installing a new toner cartridge follow these steps. 1. With unit powered On, open the front cover. 2. Press the “Options” key. Display will show “Replace Drum?” 3. Press “Start” key. 4. Press 1,0 . 5. Display will show “Accepted” for approximately 2 seconds. Then display will change to “Cover Open”. 6. Close cover and see if Toner Life End error message has gone.
Try this. We are Brother authorized.
Apr 15, 2010 | Brother MFC-7420 Laser Printer
Brother 2040
Tonner light is blinking means that the tonner life is end.
The other problem come from usb cable change the cable.
Jan 21, 2009 | Brother HL-2040 Laser Printer
Invalid tonner
I have had this problem come up a lot, even using genuine parts. All I do is clean the contacts with white spirit (dry cleaning fluid) NOT METHOLATED SPIRITS OR TURPENTINE. It should then resolve itself.
Jul 20, 2008 | Samsung CLP-500 Laser Printer
Black Lines and Very Harsh noise on a new Tonner. No printing with New tonner
Those printer tonners are very tricky to refill and a bad refill induse on bad printing so you can clean the drum (the round green thing) with isopropilic alchool. If it continues it indicates that the blade ( inside tonner plastic blade that cleans the excess tonner powder) is durty and you can clean it too with the same alchool. If it continues replace the tonner cartridge.
Feb 12, 2008 | Samsung ML 1710 Laser Printer
Problem in accepting the tonner by machine
This is a common problem. You need to be sure that the toner and drum unit are seated correctly. I assume you. You may also want to try a different toner in case the chip is bad on it.
The following has been known to work also. Open front cover leaving the toner cartridge and drum unit in.
Press the Options button,
When "Replace Drum?" comes up quickly press the Start button.
Immediately press the "1" and "0" button. The display will say "Accepted" and the error will go away.
You need to this these pretty quickly.
Nov 29, 2007 | Brother IntelliFax-2820 Laser Fax
Brother MFC 7840W Printer Logo
1,459 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
