Question about Frigidaire 30 in. Electric Gallery Series Self-Cleaning Double Wall Oven
Fridgiaire Gallery series Model GLEB30T8CBA lower elements dont work
My gallery series double oven has an issue with the lower elements in the top and bottom ovens. The top oven lower element stopped working awhile ago and the lower oven lower element stopped working today. Both top elements work on broil and to heat up in bake cycle.Any ideas?
  • 1 more comment
  • dsims119 Feb 18, 2009
    Exact same issue as listed above, the bottom element in the top oven has quit heating. The top element works fine.
  • Anonymous Mar 26, 2014
    When setting the lower oven to bake or broil the temperature displays for only a fewd seconds and the relay on engages only for a few seconds. The heating elements does not get hot.
  • Anonymous Mar 29, 2014
    Installed today about 5hrs ago when the oven began to beep with error code F68
I replaced the relay board for the top oven (the one with the transformer) and it works properly now. My issue was only for the top oven so you probably have to replace both relay boards since both ovens have only the top element working.
318022002 is the part number for the relay board with transformer
318022001 is the part number for the relay board without transformer
Yes the one without the transformer is more expensive for some reason.
The boards are on the top of the oven, I was able to pull out the oven about 75% of the way out of the cabinet and easily get to the boards. Just unplugged the connections and plugged them into the new board.
To get the oven out there are two small screws that go into brackets inside the top oven door. Highly recommend taking the doors off the oven to pull it out, much easier to work with.
NOTE: On my old board I noticed one solder joint that was burned out and I since I already had the new board I just replaced but you might want to check that first and see if just a solder fix gets you working again before you spend $$ on a new board.
Posted on May 13, 2009
  • dsims119 Jul 24, 2017
    Bottom element quit again last month, pulled the board and sure enough there was a solder joint burned out, re-soldered, put the board back and everything working
It is definitely a design flaw. I too had the same thing happen and sure enough both bottom relays for both boards had lost solder. I re-soldered and put back together and bottom oven worked fine but for some reason the touchpad for the upper oven stopped working. The only push pad on the left that works or beeps is the cancel and oven light. I don't see anything loose or not plugged in right. Anyone have any ideas?
Posted on Jun 27, 2013
My 2002 model is showing the same failure - both bake elements bad.
I pulled the element (top first) and it tested okay. Swapped it to lower oven and the one from the bottom did not work in the top oven. Service tech ended up replacing the 'top' relay board, which fixed the top oven. The bottom is still not working, and the ST tells me the part is backordered at the factory. This has been going on for a month. I'm concerned that both ovens suffered a failure. No lightning strikes, so what happened?
Posted on Jan 19, 2010
Frigidaire Gallery series model GLEB30T8CBA key pad not working
Hello Dana, thank you for your post!
From my understanding your Frigidaire oven is displaying an error code of "F8" and your keypad is not working properly. An "F8" error stands for runaway temperature (overheating). I would recommend performing a reset on your oven and you can do that by disconnecting the power cord for at least ten minutes.
If that does not help correct your issue then you could have a problem with your RTD (Resistance Temperature Detector) or the EOC (Electronic Oven Control). I would suggest having a professional technician out to perform a proper diagnosis and repair. I hope this information is helpful. -Matt
Jan 10, 2016 | Frigidaire 30 in. Electric Gallery Series...
Frigidaire double convection wall ovens, model GLEB30T9DSA ... The top oven will not heat, both the bottom element and the broiler.....
I have the Frigidaire PLEB30S8CCA single wall oven. About 3 months ago the baking element appeared to have gone out. We replaced it, but still didn't work. We ended up sending our control board off to a company named Corecentric. They fixed the problem and returned it to us. The oven has worked perfectly ever since. I searched extensively for a new one, but no one sold them anymore. I found Corecentric on Ebay. They were able to confirm over the phone that it was more than likely a control board issue. It cost about $130. My husband was able to do it himself by taking a couple before px and using them when reassembling it.
Apr 04, 2014 | Frigidaire 30 in. Electric Gallery Series...
Why has both top elements stop working at the same time
Hello kimberlymaso - If you are referring to the bake element, but the broil element works then you would need to just replace the bake element. If both your bake and broil element does not work, then there might be a problem with the wiring communication. However, if the oven does not bake and/or broil but the cook top works; contact a professional to diagnose the EOC (electronic oven control).
Sep 25, 2012 | Frigidaire 30 in. Electric Gallery Series...
I have a frigidaire 30" wall oven GLEB30T8CBA.
The control on the upper bake element has failed.and needs to be replaced
Nov 28, 2010 | Frigidaire 30" Built-In Double Electric...
Frigidaire wall over model number CGEB30S8AB1 is not heating. It is just the bottom bake element. I tried to replace the element but it is still not working. I can hear the relay clicking but it will...
I had this problem a year ago (both elements worked in top oven but only broil element worked in the lower of the dual ovens). I swapped elements around but the problem was still the bottom element bottom oven.
So I called the repairman. He replaced the relay board (Part #AP2127301) for the lower oven, and it worked again. Yippee.
But now a year later, I have the exact same problem. Lower element on lower oven is not working (Frigidaire you have got to be kidding)!
However this time I decided to take a look at the relay board myself, to at least save the expense of the repairman. I looked closely at the board and thought I saw a cold solder joint on relay K4. But just to be safe I touched up all the connections on all the relays with flux and a soldering iron.
Works perfectly again !!
Please if you try this, disconnect the power first. In fact if I had to tell you that, then just call somebody.
Oct 11, 2010 | Frigidaire 30 in. Electric Gallery Series...
Slow to heat on convection mode, bottom element not get as hot as
Check to see that the convection element is heating. If not, ohm it out, either the element is bad or it is not getting power from the control.
Jun 25, 2010 | Frigidaire 30 in. Electric Gallery Series...
Frigidaire Gallery ES340 electric range, burners will not turn on
Okay,
1, check your power, locate your breaker for the range. turn the breaker off and turn it back on.
Your Range it is electronic control on the Oven but not the Stove Top heating elements.
After you reset the breaker and it still not work.
Please let me know more about the unit.
When you purchase.
How/when it happen.
What is the indicator showing.
nguyen@ite.net
Jun 09, 2009 | Frigidaire 30 in. Electric Gallery Series...
Element in top oven not heating up all the way.
Yes needs a new element.they burn out. easily.you know this because they sell them seperately.its there way to make money off of you.anytime they sell you something and the parts are readily available especially sold seperately you know its going to need to be replaced eventually..If you replace 1 replace them all to avoid furthur issues.
May 29, 2009 | Frigidaire 30 in. Electric Gallery Series...
Elements do not heat to proper settings
If both elements are not working properly then the problem is either the temperature probe or the control board.
Replace the temp probe first.
May 21, 2009 | Frigidaire 30 in. Electric Gallery Series...
Frigidaire 30 in. Electric Gallery Series Self-Cleaning Double Wall Oven Logo
839 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
