Magicolor 2530dl fatal error 14h - Office Equipment & Supplies
  • characterco Nov 20, 2008
    Ever since we put in new toner cartridges we've had on and off problems with fatal error 14h messages.  (machine is lightly used and only a year old)
SOURCE: magicolor 2530dl
IF YOU LOOK AT THE PRINTER FROM THE TONER BOTTLE END THERE IS A SMALL CLUTCH IN THE TOP LEFTHAND REAR CORNER OF THE PRINTER.
YOU WILL NEED TO REMOVE THE TOP COVER TO ACCESS IT.
IT IS BEHIND A PLATE BUT FASTENED TO THE MAIN FRAME OF THE PRINTER.
YOU NEED TO SPRAY INTO IT WITH SOME LUBRICANT LIKE WD40 NOT OIL.
THIS CLUTCH GOES RUSTY AND DRIVES THE CAROUSELL SO GIVES 15H CAUROSELL ERROR
Posted on Nov 14, 2008
Konica minolta 2530dl fatal erro 15H
Check the transfer belt might need to be replaced.
Apr 26, 2014 | Konica Minolta magicolor 2300DL Laser...
Model 2530DL - Fatal Error Code 08H - help!
Worcesterlad came up with this some time ago: it's not a solution but somewhere to investigate:
Error 08 relates to the main motor having problems turning. Quite often this is caused by a faulty consumable (opc,toner or transfer belt). Could also be that the lid is not closing properly and stopping the toner carousel turning freely
Jul 14, 2011 | Konica Minolta Magicolor 2530 DL Laser...
I have fetal error code 08H,14H &15H in KONICA MINOLTA Magicolor 2430DL. pl help to resolve the problem
 When fatal error codes are displayed call tech support at Konica Minolta:
http://kmbs.konicaminolta.us/content/salesservicelocator/findservice/findservice.html
FATAL ERRORCODE:XX
An error has been detected with the item indicated "XX" in the service message.
Reboot the printer. This often clears the service message, and printer operation can resume.
If the problem persists, contact Technical Support
Jul 14, 2010 | Konica Minolta magicolor 2430 DL Laser...
Fatal Error 14h 2300 DL
printer.konicaminolta.com/service/ASP/mc2300/.../mc2300SM.pdf
this link is going to take you the manuel that what you have to do when you got an error.
Nov 16, 2009 | Konica Minolta magicolor 2300DL Laser...
Trying to get magicolor 2530DL printer connected & printing
http://onyxftp.mykonicaminolta.com/download/SearchResults.aspx?productid=965&filetypeid=0&osid=18 Try this website and let me know how things go. all you need is a new driver as for the old one might be corrupt. Good Luck
Fehdi
Apr 14, 2009 | Computers & Internet
Magicolor 2530dl
Oct 25, 2008 | Konica Minolta Magicolor 2530 DL Laser...
Printer driver
You can go to the konica web site, under service, software, and simply download what you need, instructions for use are slef explanatory
Jul 02, 2008 | Konica Minolta magicolor 2300DL Laser...
Fatal error 14H MY MAGICOLOR 2530 DL HAS FATAL ERROR 14H
Try first rebooting the printer, if that doesn't work, reinstall/update all drivers. If that doesn't work, you need a service tech.
Error 14h is:
Service Call 14 XFER ROLLER: Incorrect pressure by or seperation from the Second image transfer roller..
not too sure on how to fix that if reboot/driver update doesn't work.
Mar 28, 2008 | Computers & Internet
389 people viewed this question
k24674
