Go down to your local gas bar and pick up a couple bottles of gas line antifreeze or de-icer and pour them in.They contain alcohol which will clean the ice out with some time. Give it an hour and try to start the car then. If it doesn't let it sit another hour or so and then it should. It won't hurt to add another bottle of de-icer either. At the same time place a trouble light if you have one or if not any light as close to the throttle body as you can and leave it turned on with the hood closed. A 100 watt bulb is best but a 60 watt will do. Don't use those new screw in flourescents, they don't provide enough heat. This should thaw out lines under the hood. Hope this helps.
