Question about GE WSXH208A Front Load Washer
Stops at 19 minutes left and will not do anything
My GE front loading washing machine stops at 19 minutes left on the cycle. I ran another load and it doesn't seem to be rotating much, one or
two times and then it just hums. I push the button to restart it and it get stuck again at 1 minute left.
As a first step, try cleaning the lint filter as per instructions elsewhere on this site.
Posted on Jul 15, 2008
Its stops when it reaches in 39 minute the function set on cottons what is the problem
Try resetting the mainboard by removing the wall plug overnight. May also be a faulty lid switch if it is a top loader.
  • Hello, my washing machine stops completely when it reaches ... www.shopyourway.com > Manage My Life > Questions ... my washing machine stops completely when it reaches the pause cycle, ... Answered in 5 minutes ... Kenmore washing machine 417 44252500.
  • Washing machine stops mid cycle - White Goods Help www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help Possible causes when washing machine stops mid cycle by a repairman with 30 years experience.
  • What could cause my washing machine to stop before the ... diy.stackexchange.com/questions/21181/what-could-cause-my-washing... What could cause my washing machine to stop before the ... i.e. it never reaches the end of the cycle ... What would cause my washing machine to stop at the rinse ...
  • Washer Stops Mid Cycle - Repair Parts - RepairClinic.com www.repairclinic.com/...A-Washing-Machine/50---/Washer-stops-mid-cycle ... listed below for the symptom Washer stops mid cycle are ordered from most likely to least likely to occur. ... Electrolux Front Load Washing Machine Disassembly
  • once my washing machine reaches the rinse cycle, about 3 ... https://answers.yahoo.com/question/index?qid=20080526150940AA3izVT
    • RESOLVED
    • 6 POSTS
    • 5 TOTAL ANSWERS
    2008-05-26 · Once my washing machine reaches the rinse cycle, about 3 minutes after ... Once my washing machine reaches ... My washing machine stops after the ...
  • Common Problems to all Washing Machine Brands ' Washing www.appliancerepair.net/washing-machine-repair-2.html Washing machine designs vary widely, ... but stop agitating after a few minutes and fill some more. ... stop the spin cycle and unplug the washer.
  • My washing machine will not spin and now it does not stop ... www.shopyourway.com > Manage My Life > Questions My washing machine will not spin and now it does not stop when it reaches the water level. ... Answered in 5 minutes
  • washer stops in the middle of washing cycle - Appliance ... forum.appliancepartspros.com > ... > Washer Repair
    • 6 POSTS
    • FIRST POST: 2012-02-07
    2012-06-22 · Appliance Repair Forum > Appliance Repair Help > Washer Repair » washer stops in the ... but when the timer reaches 24 minutes left to ... Washing Machine stops ...
  • LG Washer Stuck Timer 2 - YouTube Youtube
    • BY SBUBANDIT
    • 14 MIN
    • 4.9K VIEWS
    2012-08-29 · Video embedded · In this video the washer display shows 8 minutes remaining in ... machine stops and turns ... 10kg Top Load LG Washing Machine
  • http://www.bing.com/search?q=washing+machine+stops+when+it+reaches+39+minutes&qs=n&form=QBRE&pq=washing+machine+stops+when+it+reaches+39+minute&sc=0-47&sp=-1&sk=&cvid=04BC47135B524BD8B5BAC3759F010C1B
    Jun 10, 2016 | Washing Machines
    Washer gets to spin cycle and stops
    If you are having a problem with your top load washer then check out this tip...
    Washing Machine2_bing.gif does not Pump or Spin
    http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
    If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
    Front Load Washing Machine2_bing.gif not draining and or not spinning
    http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
    heatman101
    May 14, 2010 | GE WSM2700D Top Load Stacked Washer /...
    Washer stops with 3 more minutes on spin sycle, then stops, flashes F and adds more minutes to the cycle while beeping.
    Find the clean out (usually have to remove the bottom panel) there will be a lot of junk and water that comes out so be prepared. Once you clean it out it will finish the cycle....it happend to our GE front load and this solved the problem. Hope this works.
    Nov 23, 2009 | Kenmore Elite 45986 Front Load Washer
    Washer stops w/ 19 min. left to finish and door pops open.
    the same thing happened to our washer and a friend told us to take off panel below door and there's a opening that's covered with a circular plastic cover, open manually and remove all the junk that's accumulated from all washes, careful it may leak a great deal of water! Try that if anything else, unless you've already had it serviced!
    I'm looking to try and solve yet another issue with the same washer...
    Mar 31, 2009 | GE Energy Star WCVH6260F Front Load Washer
    Washing machine stops when there is 19 minutes left!
    you need to have a tech out to look at it it sounds like the motor isnt going into high spin and /or cutting out on over load this is a problem with the g/e's there is no filter on this machine all the lint is flushed down the drain
    Jan 08, 2009 | GE WBSE2090A Top Load Washer
    Loads interrupted
    interrupted wash cycles and also give a code of F06. A service tech was supposed to be at my residence today... he did NOT show. This machine is little over a year old. Tried unplugging with no sucess. Any help would be appreciated.
    Sep 15, 2008 | Kenmore Elite 45986 Front Load Washer
    GE Energy Star WCVH6260F Front Load Washer: door locking problem
    http://www.instructables.com/id/GE-Adora-Lint-Filter-Cleanout/?download=pdf
    Had the same problem, this fixed it!
    Mar 12, 2008 | GE Energy Star WCVH6260F Front Load Washer
    Wash stops at 30 minutes.
    jc, remove the bottom panel by removing the 3 screws on the bottom, it will pull out and off. Right in front is the pump filter. Get yourself some towells or a flat pan and open the filter. Clean it out, your washer should come back to life. Catriver
    Dec 03, 2007 | GE WBVH6240F Front Load Washer
    GE WSXH208A Front Load Washer Logo
    278 people viewed this question
    Top GE Washing Machines Experts
    Dan Webster
    Dan Webster
    Tim Whalen
    Are you a GE Washing Machine Expert? Answer questions, earn points and help others
