Question about Fisher Paykel EcoSmart GWL15
Water Fill Issues
My Fisher Paykel machine takes forever to fill and more than often will error out before it reaches the firt wash cycle. I have well water and assumed that there was sediment in the hose. Several times when I disconnected the cold water hose cleaned it out then reconnected it the problem went away - this doesn't work anymore -- could I need to have the cold water valve replaced? Warm water run ten times faster than the cold water !?
    Novelist:
  • 161 Answers
Try unscrewing the hose at the back of the machine. There should be another filter there. If this doesn't solve the problem replace the fill valve. This part is not expensive. Take the old one with you. a generic is much cheaper. I have bought new for under $5. You can fix this yourself.
Posted on Jun 30, 2008
  • Art Hessburg Jun 30, 2008
    Try to buy an external filter. They sell these for comercial machines and install it in the cold water line. (It just screws into the washer hose) You really don't need one in the hot line as the crud will settle out in the water heater.
My Fisher and Paykel MW058 top loader wont fill up as fast as it use to
Turn off the water and remove the inlet hose at the machine. There is a filter screen there and it may be plugged up.
Nov 08, 2012 | Fisher and Paykel Washing Machines
When the full washing cycle has finished and all the lights are off, water starts running into the tub. Would keep filling forever if I didn't turn hot and cold off at the connection. I then push...
Water will not shut off
1. Defective timer ( timer fill the machine)---replace
2. Defective water level control---replace
3.foreign particles in mix & fill valve---clean out valve
4. Defective valve---replace
Sep 22, 2011 | Fisher and Paykel GWL11 Top Load Washer
GWL 11 takes forever to fill with water
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Aug 13, 2011 | Fisher and Paykel GWL11 Top Load Washer
Starts and stops
A failed inlet valve is not uncommon in F&P machines. The hot valve is different to the cold one, so don't exchange them. Not a big job for a tech to do in-laundry. Good luck....Nomess
Jun 11, 2010 | Fisher and Paykel Fisher & Paykel Washer
Washing machine cycle far too long
Hi Fiona.I believe the cold valve is probably faulty & is not flowing fast Its probably dribbling water in?taking forever to fill.the machine should be giving up & beeping at you if thats the case.If you have a faulty cold valve then switching to warm won't help as the hot valve will close itself off to compensate for the lack of cold water..afterall you have told the machine to fill with warm,,if it cant make warm water because of a faulty cold valve then the hot will decrease to a point where its not letting any water thru..try a hot only wash..if it goes thru wash cycle ok then good chance its cold valve problem.wow i hope that helped.
May 30, 2010 | Fisher and Paykel Washing Machines
Water not coming with force in Fisher & Paykel SmartDrive Top-loa
Try taking the cold hose of at the tap and check to see if has a little mesh filter in there. This could be blocked up with gunk.
Jan 12, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel washing machine fills and won't stop filling...
If the water stops when you shut if off at the wall you have a bad cold inlet valve, or the valve is getting a constant "open" command from the controller and thus the controller is faulty.
Jun 18, 2009 | Fisher and Paykel (IWL12)
Machine cant get any water.
Does the water fill to the correct level ?
Sep 09, 2007 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher Paykel EcoSmart GWL15 Logo
67 people viewed this question
Top Fisher Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
