Question about Jenn-Air JFC2089H Bottom Freezer French Door Refrigerator
Water dispenser not dispensing
Our fridge is less than 4 months old and water stopped flowing from dispenser.  We replaced the filter but still no water.  Help.
  • ldierks Jul 06, 2008
    We have the same problem with ours. Ours stopped sometime last year as well and then started again on its own. We've tried taking the filter out as well but to no avail. Hopefully, that will start on its own again!
  • robcrash Jan 18, 2009
    Same problem here. Jenn-Air french door bottom freezer, just under one year old, no water going to dispenser or ice maker. Happened once before for a short time but then came back on by itself. Any answers?
Water line or water tank is frozen intermittantly
Posted on Jul 07, 2008
Changed filter and now water flow is limited
If the water shutoff valve has a seal like a faucet instead of a saddle valve it's possible a piece of it has broken off and is partially blocking the water line to the fridge. Check the line to see if you can see it or disconnect the line at the inlet to see if the filter screen is plugged.
May 10, 2017 | Maytag Refrigerators
In-door water dispenser for Whirlpool ED25UEXHW00 stopped working
Sounds like the water valve for the water dispenser is not opening..You can search the internet for you model number and order a new valve online..I just order a duel water valve for my whirlpool and it was 80 dollars..Got it from www.partselect.com Hope this helps
Mar 16, 2017 | Whirlpool Refrigerators
How to increase the water flow from water dispencer on a FLSC238DSO when getting water it takes for ever to fill a glass
If your fridge has a water filter, you should change it every 3 months. An old filter can cause slow flow problems.
But it will never come out as fast as the kitchen sink. Depending on the location of your fridge, you have 10 to 25 feet of 1/4" pipe between your water glass and the high-flow plumbing, and water just won't move very fast through that.
Sep 16, 2009 | Refrigerators
Not making ice or dispensing water
Does your fridge have a inline water filter or one inside the fridge? If so, try replacing the wate filter, as it could be obstructed and old and causing the loss of water flow.
It's a good idea to keep track of the date when any filter is installed so you can replace it before it losses it ability to filter properly, both from a issue of conveinence and for health reasons.
A dirty, old filter can allow some nasty contaminants to pass through after a fixed amount of time or set amount of water has passed through it.
If there is no filter, you might have to replace the water inlet valve that supplys water to the fridge. Just be sure to turn of the water line the fridge is connected to, before servicing the water supply valve that supplies the fridge.
Hope that helps, Best regards!
Jul 30, 2009 | Frigidaire Refrigerators
Slow water flow from GE Fridge water dispenser
slow water from my ge refrig side by side. less than a momth old
May 04, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
My water dispenser suddenly has stopped working.
Yes, it could be the water filter. Also check to make sure the water is turned on and that any lines to the refrigerator aren't kinked or crushed somewhere. It's also possible that you will not be making any ice as well if your appliance has an ice maker
Apr 06, 2009 | GE Profile PSW26P Stainless Steel Side by...
No cold water
  1. Make sure filter is installed right.
  2. Disconnect water line see if water is flowing from line. May have a water valve in line not working.
  3. reconnect line but leave lose open inline valve just a little see if water flows out. No water PSI may be to low to reach up to fridge or valve stuck closed.
  4. Got water to connection tighten check dispenser for water.
  5. No Water If your system has a reservoir to store & chill water Your float may be stuck locate & check unstick if needed.
  6. Still no water May have faulty dispense value. Check value replace if needed.
Please rate hope this helped. If I can help further I'll standby.
Mar 09, 2009 | Samsung RS2534 Side by Side Refrigerator
WATER DISPENSER,
GSH25JSTASS -- I have a one year old ref..Same problem..Ice comes fine, no water. Changed filter..defrosted Freezer compartment. Kept the light ON for a couple of days, .used compressed air to check water tube between water disp to bottom of the freezer. Not frozen...
What could be wrong with this SMART water filter from GE!
Aug 02, 2008 | GE GSH25JSTSS Stainless Steel Side by Side...
Water/Ice Dispenser is not working
at the very least replace that water filter.clogged water filter will reduce water pressure to the line.
Feb 24, 2008 | GE Profile PSW26P Stainless Steel Side by...
Jenn-Air JFC2089H Bottom Freezer French Door Refrigerator Logo
248 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
