Question about GE Profile JTP18 Electric Single Oven
GE oven self cleaning
Code F2 comes on all the time
  • Anonymous Feb 14, 2009
    Put on self cleaning mode and after about 2 hrs F2 code comes on.
I cooked a turkey yesterday and there was a whole in the pan which caused a large amount of grease to spill ~ smoke was coming out of the oven. I immediately shut off the oven (luckily the turkey was cooked), and while I cleaned some of the grease off, there is still a large amount of grease which has hardened in the oven.
I'm afraid to turn on the self-cleaner because of the intensity of the oven when it's turned on to the self-cleaner. Can you please tell me what household product I can buy to first clean the grease off and then put on the self-cleaner?
I have a gas General Electric oven?
Thank you
Posted on Feb 02, 2009
    Problem Solver:
  • 10 Answers
Try fix found here http://www.fixya.com/howto/h155060-dreaded_f7_error
worked for me
Posted on Aug 18, 2008
GE wall oven was in self clean mode and suddenly an F2 error keeps beeping. It also flashes looked door - please help
Those are error codes which are listed in your owners manual. If you do not have the manual go to the GE web site, customer support section.
Mar 06, 2011 | GE Ovens
Tried to do self cleaning on oven, about 10 minutes in got "f2 locked door" and it won't clean. what is that all about?
Error code F2 on clean cycle is indicating that the maximum permissable cleaning temperature has been exceeded. (or it's got too hot!)
However it seems unlikely that that would happen in just 10 mins. more likely it is a problem with the oven temperature sensor which should be checked over as should the lock switches..
Dec 14, 2010 | GE JRP24 Electric Double Oven
F2 Failure Code after cleaning cycle on GE Double
f-2 is usually a runaway oven temp which most of the time means a bad oven sensor.try replacing this first.
Jan 16, 2010 | GE Ovens
I'm getting a F2 Error and door locked with flashing and beeping after I ran the self-cleaning mode on my GE Model JTP85 built-in oven.
f 2 code states that your oven temp exceeds 590 w/unlocked door .. the oven tempt sensor will need to be replaced .. hope this helped mm
Dec 04, 2009 | GE JTP85 Electric Double Oven
F2 error
F2 is a bad temp sensor, needs to be replaced.
Jun 23, 2009 | GE JKS06BFBB Electric Single Oven
F2 displayed when using self cleaning
REPLACE THE OVEN TERMISTER PROB IT WILL FIX YOUR PROBLEM. CALL 800-614-2700 TO GET PRICE ON IT AND HAVE MODLE # REDAY
Jan 25, 2009 | GE JKP15 Electric Single Oven
F2 message when self cleaning
I have the exact problem, had a service man look at it while still under warranty. He said it was fixed and left. Tried it again, same problem. Called him back 2 times after that, he quit responding to my calls. By tyhen warranty expired and GE refused to do anything.
Nov 07, 2007 | GE JKP45 Electric Double Oven
F2 Oven overheats
jaz3133, it's probably the temp sensor that has gone bad. You should be able to get it from the front. It's the probe that comes out from the back wall of the oven. You can have someone ohm it out. Should read approx 1100 ohms at room temp. Part number for the temp sensor is WB20K5040. Make sure power is off befor removing the sensor. Catriver..post back.
Mar 04, 2007 | GE JTP15 Electric Single Oven
GE Profile JTP18 Electric Single Oven Logo
436 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
