Question about Dacor Epicure ERD30 Dual Fuel (Electric and Gas) Kitchen Range
Control panel The control panel has developed a small crack ( 2 inches) in the middle of the panel just below the the touch pad. Our range is just over 5 years old. The Dacor representative would sell me a new control panel but would not cover installation. The cost would be about $500. I have been told that this was a problem on previous models but was told that the problem was fixed. Apparently, it was not. Should I be concerned about this crack?
  • 639 Answers
I'm Neil and glad to be at your service!
This is a top quality range and worth the repair.
Compare what it cost to replace the same range and it seems worth the repair!!
This time you need to call service!
For a good service you might try,
A&E Factory service
1-800-905-9505 7days / 24hours Nation Wide
Please give me a solution rating here at fixya.com
Thank You
Neil
Posted on Aug 24, 2008
Maytag model mer6770awc keeps showing f1-1 error code
Hi rayrolls,
The F1 fault code indicates a defective touch pad or clock (ERC). To resolve this issue, you need to replace touch pad or clock (ERC).
The steps below will help you to determine whether the ERC or the touch pad is defective.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Hope it helps.
Thank you for using FixYa.
Sep 14, 2011 | Maytag Kitchen Ranges
What is an F 1 error code?
Hi nikkiwms,
The F1 fault code description is a defective touch pad or clock (ERC). Please refer to the steps below for additional information.
1. Unplug the range power cord or turn the power off to the range at the circuit breaker. It is very important that the power to the range has been disconnected, so please double check before continuing.
7. Please replace the ERC, if F1 comes back. If it does not, replace the touch pad.
Hope it helps.
Apr 19, 2011 | Maytag MER5775Q Electric Kitchen Range
I try to turn one my Oven and said F-1 problem What F=1 mean
Hi ambertone53,
The F1 error code is about a defective touch pad or clock (ERC). Please follow the steps below to determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective.
Hope it helps.
Dec 06, 2010 | Maytag MER5775Q Electric Kitchen Range
Error F-1, on upper oven What does this mean? Oven is 17 years old
F1 touch pad / ERC test This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock).
Warning: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
Nov 21, 2010 | Ovens
My range is beeping f1 where the time should be
HI. This will be a control fault. Possible touch pad issues detected. Use the procedure below to isolate the problem.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so double check before continuing.
Jan 07, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
F1 appeared on the panel screen,my model is MGR5770ADB.Please reply.
HI. Essentially, this will be the result of a failed touch pad. Some models incorporate the touch pad in to the ERC(control board) as a single assembly, in which case, the test I will post below is not necessary. If your touch pad is Incorporated in to the control board assembly, Simply replace the entire Control board. Follow the test below if the touch pad is separate from the control board.
Warning: If you feel in any way uncomfortable with performing this test or making this repair, please contact a qualified appliance repair technician.
Dec 21, 2009 | Maytag MGR5770 Gas Kitchen Range
F1 code appears, broiler is on and will not shut off.
Hi william_atch,
Hope it helps.
Dec 14, 2009 | Maytag MER5775Q Electric Kitchen Range
I have a Maytag Advanced Cooking System Model #MGR5745ADA that is showing a code "F1" on the display. The oven doesn't work.
HI. This will occur when there is a fault present within the main control board, or touch pad assembly. use the procedure below to determine where the actual damage is located.
Caution: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
Nov 25, 2009 | Maytag MGR5750 Gas Kitchen Range
What does the F1 error code mean? The stovetop works, but the overn and broiler do not.
Hi mdecastr,
continuing.
Hope it helps.
Oct 07, 2009 | Maytag MER5775Q Electric Kitchen Range
The Alarm keeps buzzing to my Jenn Air ww2780w wall oven. The code reads F1. What can I do to fix?
Defective touch pad or clock (ERC)
Replace touch pad or clock (ERC). Touch pad is a more common problem.
You can use the test procedure below to narrow the actual issue.
Jul 09, 2009 | Ovens
Dacor Epicure ERD30 Dual Fuel (Electric and Gas) Kitchen Range Logo
198 people viewed this question
Top Dacor Kitchen Ranges Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
