Question about Bosch 24 in. SHU43 Built-in Dishwasher
Bosch model SHU43C05UC/17
When replacing a plastic gray rinse button on front panel of dishwasher I had to pull the control panel out to get to the back and snap the button back in. I noticed when I took the control panel off there was one set of modular plug-in wires all red that was unplugged. I'm not sure if I accidentally unplugged or if it was intentionally unplugged when installed several years ago. When I plugged it in it seemed tight like it wouldn't have come out as easy as it did. That's why I began to wonder if maybe it's not supposed to be connected. Please let me know.
The module (timer) have a groove that each set of wires slide in and a tab that snapps in place. usually you can't mess up the plugs. all wires should be plug in..
Posted on Jul 01, 2008
I have a Bosch model number she43m02uc/50... I need to replace the buttons but cant figure out how to do it myself and disassemble the panel.
Hi.
To remove the control panel on the machine there are a total of 6 screws holding it on. Four screws across the top of the inside of the door and 2 more on the sides.
Once you have removed all the wire connecting plugs from the control unit you should lay the control panel on a towel face down to work on the four clips holding the metal frame onto the plastic control panel. Be careful not to break these clips as they are delicate. Don't force them to move more than they need to disengage. Once the steel frame is removed out of the plastic control panel you should have access to the plastic buttons to replace them.
Regards Sam
Sep 30, 2013 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Bosch dishwasher model shu43c05uc diagnostic code C1 at start then P0. what does this mean?
You seem to have inadvertently put it into the test sequence. Try pressing the two reset button simultaneously (usually the reset buttons are 1st and 3rd from left each with a dot underneath, if this does not work, press the button between the two resets (2nd button) P1 should come on then press the right reset button. The unit should run through a test cycle for approx 20mins and eventually reset the module, this is indicated by 0 in the display. Please repost if further assistance required.
Feb 28, 2013 | Bosch 24 in. SHU43 Built-in Dishwasher
Won't change cycles
locate the tech sheet for your machine. It can be taped to the back of a panel or on top of the machine or usually behind the lower panel. The tech sheet will tell you how to enter the service program and check for error codes. It sounds like the control board is failing.
You can check at Appliance Parts Pros or Repair clinic for parts for your unit.
Hope this helps.
Dec 25, 2017 | Bosch 24 in. SHU43 Built-in Dishwasher
I have a bosch diswasher model number SHU43C05UC / 17 and the water is not as hot as it used to be - I thought i remembered the sales person mentioning a heating element - 2 questions - 1) is there a...
Yes there is a built in heater that can be replaced, however, if the heating is intermittently it is possible that it is a filling issue as the heater has a boil dry prevention switch. This basically means if the water level is too low the heater will not come on.use this link http://www.bosch-home.co.uk/store/spareparts/DishwasherBOUG4PaintedStainless/SHU43C05UC/17go to page 4, you need to check parts listed 428 and 427 are free of build up as this will cause a drop in water level. If the heater has failed this is part 409 on the same page. Please ensure that the unit is completed isolated from the mains before carrying out any diagnosis. To check these parts you need to remove lid (usually held on by two clips at rear and pushing the lid toward the back to release) and the left side panel needs to be removed (usually two tx20 screws at the front). Hope this gives you a starting point, repost if you need further assistance. Good Luck.
Sep 24, 2011 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
I have a Bosch dishwasher model # SHE44C06UC / 22. When I do a regular wash, it will count down to 1 minute and stay there. The dishawasher will constantly run until you hit the cancel button and the...
Hello, welcome to FixYa.
Based on your description
I'd say the issue actually is with the control...unfortunately. This is commonly associated with a heating fault on Bosch built dishwashers ( various models including Bosch, Thermador, Siemens, Gaggenau, and Neff ).
**B/S/H/ issued a recall on certain models between 1999 - 2006 depending on the model & serial number, you can check with yours but...you'll need the serial number too. Here`s the link if you want to see for yourself **
http://microsites.boschappliances.com/safetyrecall/dishwasher/
Since the issue is likely within the electronic timer/control, specifically the heater relay solder joint. ( a faulty flow switch, ntc or heater can also cause this, but not very probable ). These are the steps you'll need to follow to resolve it or at least investigate.
If you feel capable of checking this on your own, there`s a way to visually inspect the control yourself...it really isn't very complicated.
It will require you to remove the control from the unit and then remove the control from it`s plastic housing and look for a burnt solder contact on the printed circuit board.
The culprit will 99% of the times be one of the pins from the heater relay,
**Flip this over and inspect the solder joints, it will be obvious when you see it.**
hence the unit sit`s and takes longer & longer to finish because it can`t heat to advance or unless the 2 buttons for "cancel" are pressed...this can also manifest as a long cycle time as I mentioned and eventually display's "1" on units with a display and usually very poor cleaning, no heating ( don't be fooled by the homes inlet hot water temperature ) as a result.
You can also run the unit through a regular or econo cycle ...any cycle with the exception of rinse & hold, and with the door panel removed place an ammeter on the gray/black wire it should draw 11 amps during the wash cycle...after it fills and the flow switch indicates it has adequate water to engage the heater.
i.e. ( this may differ from your specific model, but the same rules apply )
**My Opinion - if you or someone you know is proficient at soldering, a lot of times it can be remedied by simply repairing the solder...but it has to be done well...or it will not last.
Bosch recommend`s replacing the control and I don`t pretend to speak on their behalf nor do I profess to know better. This is just my experience (it work`s) and my opinion (why buy new if one can repair ?)
**Please disconnect the power or turn off the breaker before attempting any service to the dishwasher.**
If you do not feel comfortable attempting this service, call a local pro, preferably one familiar with Bosch/Thermador/Gaggenau/Siemens, to service your machine.
Thank`s for visiting "FixYa" for your repair inquiries. Please take a moment and rate this solution to it's helpfulness. Good luck.
Regards,
Macmarkus :)
Aug 14, 2011 | Bosch Dishwashers
Bosch SGI4345AU/17 shows 2H on the display, it does not seem to matter which program is selected, the unit runs continually. It does not heat the water or finish any cycle. The washing tablet covers the...
The Control unit on your Bosch has a burnt out heat circuit. Just about every dishwasher has a number of "thermal holds" during the wash and rinse cycles in which the controller waits for the water to be heated to a specific temperature. Most dishwashers check for a temperature rise over a certain amount of time and will shut down if this increase is not seen, however, Bosch does not employ this secondary check and the unit will run for as long as you allow.
The Control Unit on your dishwasher will need to be replaced. Being as Bosch is extremely properitary on their parts sells, it is best to actually talk to a parts supplier directly in order to ensure you are getting the correct controller. It is very important that the replacement controller is for your model #, including the /17 designation at the end. A xxxxxxUC/12 controller will not work on your model.
The Control Unit is found in one of 2 places; 1) behind the Control Panel, or 2) at the lower right hand side of the unit towards the rear. Both are relatively easy to replace.
Apr 16, 2011 | Bosch Dishwashers
Bosch Dishwasher will not dry dishes, washing is fine. Model SHU43C05UC / 17. About 4 years old. Cannot find the manual. Any help is appreciated.
Bosch dishwashers do not have built in heated dryers. Be sure your water is hot enough and the rinse aid dispenser is not empty. The Bosch should heat your water to a minimum temp and if it is not, this could be your problem.
Ken
Oct 25, 2010 | Bosch 24 in. SHU5305UC Built-in Dishwasher
The Rinsing aid door keeps opening in my Bosch dishwaser
I believe paddy55 is correct about the rack position affecting the rinse agent door. When the top rack is moved to the higher position, the rack hits the latch on the rinse agent door, causing it to pop open.
Move the rack back to the lower position and see if the door stays closed.
Apr 06, 2008 | Dishwashers
Change a white door to stainless??? can I
Okay here we go. The SHU43C05UC/17 is the stainless model. The parts needed to change over to SS are 1) 431828 SS Facia cost 72.80. 1) 417981 power switch button 15.40. 1) 426062 program buttons set 5.40. 1) 214750 SS outer door panel 101.50. 1) 426063 lid (fits inside the handle area) 3.90. As you see it will not be cheap to change over to a SS dw. These prices are from Bosch's Quick Finder website. Hope this helps.
Mar 31, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch 24 in. SHU43 Built-in Dishwasher Logo
308 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
