Question about Sansui HDLCD-2600 26 in. LCD Television
PC video to Sansui
I'd like to know how to connect my laptop to my tv (to watch movies and stuff). It's just that simple. I have a VGA cable, my laptop's a Dell, and I've tried hooking them up, but so far all I have is a dark screen on the TV and my laptop. Is there anything I'm missing here??
Once that you hookup the TV to you laptop you need to me sure that the second monitor is active, you can check it on the control pannel screen/config, also make sure of the resolution if this is ti high the sansui tv do not support it and jus get a black screen.
Posted on May 14, 2009
You probably need to tell your laptop to detect the second monitor, or somehow activate the video out function. How these things are done depends on your specific laptop model. Try looking in the user manual or on Dell's website page for your specific model of laptop.
Posted on Oct 20, 2008
My laptop doesn't have a HDMI port so I have to connect with two cables...I think ones VGA and the other is audio. This goes into the back of my old smaller tv...which is ok but I'd like to route the
Your TV doesn't have video output on either HDMI or Composite video. (There are a few TVs that do have a video out but often that is only available for some input/output combinations. You would need to check the manual but the PC input is usually not available for the video output.)
You could get a VGA to composite or component video converter and direct the signal to your new TV from your PC. One example of the first converter is here: http://www.cablestogo.com/product/29548 . An example of the VGA to component video is here: https://sewelldirect.com/audio-authority-vga-to-component-pc-to-hdtv-converter.asp . There are other models available. A few VGA to HDMI converters also exist. However, since those need to convert an analog output to digital, they are more expensive.
I hope this helps.
(A few VGA to composite cables exist. They will not work for your purpose. They are designed to connect projectors with RCA ports and understand the VGA RGB signal to a computer.)
Jan 15, 2015 | Computers & Internet
Want to put computer movie on tv
Sort of depends on the TV connections? Your laptop specs list a VGA prot and a HDMI port. What does the TV have? HDMI? VGA? Do you have the cables? Does your TV have a USB port? If so, you can put the Movie on USB. Does your TV have a Wireless Adapter? If so, you can add/share your videos from a Home Network. There are option but without the TV info, I can't give a informed solution.
Jan 11, 2013 | Gateway NV5378u Notebook
How do i connect the pc to the lg tv to watch a movie
Hello......Let's talk video....Your Tv has an S-video input and a VGA input....Chances are your computer's video card hay not have S-video output...It's small ,round...looks similar to a PS2 mouse or keyboard port.If it does...you can use the S-video(SuperVideo).If you computer is not equipped with this...You can use the VGA typacally used to connect the monitor to the pc...Depending how far apart the TV and the PC are..this can be easy...this determines the length of the cables you are to use...If you go with the S-video cable..It may be less expensive...if you go with the VGA cable..be sure to get one long enough...as far as the sound...since your tv has a VGA input...I may also have the sound input for your pc connection..This requires a cable with a 1/8" stereo plug on either end...You can connect one end to you tv and the other to the headphone jack on your pc....or you could just listen to the sound thru the pc fpr now....Let me know how this works out....I hope this was helpful....PEACE....
Jan 26, 2012 | LG 42PG20 42 in. Plasma HDTV
Hi I'm trying to connect my laptop to play photographs through the TV screen using windows XP. No success at the moment. How do I connect up please? And can i get a manual for the TV anywhere...
For making the physical connection between PC and TV first we need video cable.
PC has S-Video port that should be connect to the S-Video input of your TV using S-Video cable.
Connect the computer to the TV using VGA ports or via the DVI to HDMI cable. These Macs need Adapter for a VGA cable.
RCA for audio, connect RCA to your PC and red and white colored sockets of RCA cable to TV (left audio-white, right audio-red).
In your PC open the Display Settings and activate output to the TV screen.
In your TV open the menu from that open the External inputs. And change the video to HDMI depends on the connection.
You can also change the screen resolution of your TV using the Personalize and Display Settings options in your Control Panel on PC.
After giving the connections you can watch the movies and everything is running on laptop on TV.
Jun 07, 2011 | Televison & Video
WHAT TYPE OF CABLE DO I NEED TO CONNECT HP NC6400 LAPTOP TO HD TV TO WATCH MOVIE ON TV FROM LAPTOP? VGA TO HDMI CABLE? THANKS
Hi.
The best way is to get a s-video converter to connect your round s-video computer output to your HDMI port on your tv. This is the best you can do according to your laptop connections. You will need a s-video cable, HDMI upscale converter box and HDMI cable.
The other way is to plug a VGA cable to your tv VGA port if you have one.
VGA to HDMI is also possible with a converter. A standard VGA cable with a HDMI plug on the other side will not work because your computer sends out an analog video signal and HDMI is digital only.
Hope it helps!
Feb 08, 2011 | HEWLETT-PACKARD HP NC6400 Core 2 DUO T5600...
Can I connect my Toshiba NB 205 to my TV to watch etflix movies? the netbook has a VGA out, and the TV has S-cable and HDMI inputs. Thanks!
Interfaces 1 x Display / video - VGA - 15 pin HD D-Sub (HD-15) , 1 x Network - Ethernet 10Base-T/100Base-TX - RJ-45 , 1 x Microphone - Input - Mini-phone 3.5 mm , 1 x Headphones - Output - Mini-phone stereo 3.5 mm , 3 x Hi-Speed USB - 4 pin USB Type A
The above interfaces are in your laptop. There is no S-cable or HDMI interface.
If your TV have VGA port you can connect your TV to the VGA port in laptop. This will alow you to convert the TV as monitor.
May 31, 2010 | Toshiba Computers & Internet
Lead from external harddrive to tv- to show films,--usb connection from harddrive to 15pin to tv
Dear ragalgey,
As far As I can remember, most TV design to receive the signal to watch whatever you want limited to available TV station in your local broadcaster.
If you think you connect your harddrive to TV USB or 15pin (VGA cable) then you can watch the movie file from harddrive is a totally wrong!
You need a drive or a player for those file that capable to configure your TV to play them. Or at least you need a PC or Laptop Computer that played your harddrive then send the images/video via Video Out Jack (Yellow) from your laptop, or connect the 15pin VGA jack from Laptop PC out then plug in to your TV. In this case you'll need the Jack/adapter to convert from 15pin VGA from laptop to available Video jack on your TV.
Good Luck!
Best Regards,
bionic23
Dec 08, 2009 | Samsung Computers & Internet
Need help watching a movie from laptopn to tv
What kind of help?
Connection?
  • if you have a S-Video connection use it (remember to use another cable for audio)
  • If your TV set has a VGA connection use it (always + audio cable)
  • If HDMI connection available use it
OR look for a special connector matching PC VGA port with RF modulated antenna signal on TV set or composite input. Here some detail
Jan 30, 2009 | HP Compaq nc6000 Notebook
Sansui HDLCD-2600 26 in. LCD Television Logo
353 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
