Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
Bike cranks but will not start. Was fine when I last drove it. It has fuel . what could I do next
  • Anonymous Jul 13, 2008
    hi I have a 2002 harley davidson fat boy and when i go to start ituyou can here the fuel pump and everything else turn on and it starts but when i shut it off and go to start it again it wont turn over. It wont even turn the fuel pump on. I got it checked out by a mechanic and he said there was nothing mechanicaly wrong with it and told me it has to be electronical problems can u help me?
Pull sparkplug out, rehook plug wire on plug. ground plug against cylinder and
check for spark. no spark? have coil checked
Posted on Jul 27, 2008
Have the same problem on my 1991 fatboy... did you get any answers?
Posted on Jul 02, 2008
Truck won't start
Sounds like you have several problems.
If the engine will not crank, do you have power on the purple wire on the small starter terminal when the key switch is in the start position ?
Apr 14, 2013 | 1995 GMC Sonoma
98 Ford F150 w/4.6l Wont start. Hear fuel pump click. Have pressure on fuel rail. Pulled #1 plug from head and plugged back into wire. Grounded plug and cranked. No spark. Changed wires 4 and 7 four days...
have diagnostic codes checked to see if you have a cam or crank sensor fault. make sure fuel pressure is at the required pressure, just testing to see if you have fuel at the valve is not enough. replace all spark plug wires. if you replaced two then all are just as old and even when they "look good" does not qualify as "they are good". Replace coil pack. start up drive away happy
Sep 05, 2011 | 1998 Ford F150 Regular Cab
My 95 Wrangler wont start when the engine is cold. it will crank but not start unless you give it gas. It starts fine when its hot (90 degrees) outside or i've already started and drove it that day, but in...
i was told that if the jeep all of a sudden didnt start on its own without giving it gas, then next time you start it hold the pedal all the way to the floor and it resets something in the computer and sets you back to normal.
Sep 04, 2010 | 1995 Jeep Wrangler
2002 ford tarus cranks but wont start. 32000 miles. I did not drive much during the last 6 months. I started it and it ran fine drove to a neighbors house when i tried to start it cranked but would not...
First, verify that there is gas in the vehicle. Next, listen for the pump to energize when you turn the ignition switch to the on position. If you dont hear anything, check the fuel pump relay. Swap it with another one next to it, they are often the same part. If it still doesn't energize, its most likely the pump thats failed. If you hear the pump energize, then the pump pressure needs to be checked. A fuel gauge needs to be connected under the hood on the fuel rail to read system pressure. Verify that its at factory specs. If not, replace the pump.
Apr 21, 2010 | 1999 Ford Taurus
Car was low,low on fuel,put half tank in car.drove about 3miles onto 4lane and kicked it. when car tacked out in passing gear it started heasitating.eased off the accelerator and shifted fine.kicked it...
Replace the fuel filter. That should fix the problem. You can follow the fuel line back to the fuel tank to find it. It is usually in the middle of the vehicle near the edge of the vehicle, like right under the passengers or drivers door.
Nov 03, 2009 | 1990 Nissan 300ZX
Engine tries to crack but will not fire up.
if its a efi there are sensor like the cam and crank that tell the comp to send fuel if any of these are bad it will not start
Aug 17, 2009 | Eagle Summit Cars & Trucks
1997 mpv mini van runs great. While traveling i drove from SC to Atl GA....parked and went into motel for evening...the next morning i had very difficult time getting it re started....Like it was not...
I think you should check your battery and alternator.If they both check good you may have a battery draw,something draining the battery over night.Check your doors make sure they are closing like they should.
Jul 28, 2009 | 1997 Mazda MPV
My 1997 Dodge Avenger's engine won't start
Try cam and/or crank sensor. If crank to cam timing isn't detected properly it'll crank all day but won't start. I had similar problem on my 2.5L V6 Avenger....drove home fine, no engine light, next morning it cranked, but wouldn't start. The crank sensor was faulty.
Jan 11, 2009 | 1997 Dodge Avenger
Too much fuel in engine
my first thought is that something is wet, which is possible since you just washed it. However you said it sat for a couple of days...... I doubt that it is to much fuel in the engine, you have strong spark?
Nov 10, 2008 | 1998 Suzuki GSX-R 750 W
Stalls / Dies / dead
this engine fuel pump prassurae low. it fuel pump celan. Your problem sovel
Jul 13, 2008 | 2003 Ford E150
Lands Phones Logo
219 people viewed this question
Top Harley Davidson Lands Phones Experts
ted dux
Ronny Bennett Sr.
Ronny Bennett Sr.
David Payne
David Payne
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
