Question about Lexmark Office Equipment & Supplies
Tried to install new z16 cartridge. the screen appears and asks if cartridge is new, Will not do anyting after i hit next. I tried to uninstall lexmark and start over, but it won't let me, says printer in use. Seems to be stuck on the same screen.
  • 2,785 Answers
Plz reinstall the printer drivers
Posted on Jul 01, 2008
When I open my printer from the start menu and look at the epson. It has a green check mark and an error message right next to it. I tried uninstalling it and installing it. I think it is a connection...
Please repeat the procedure of installation by following the tips once again.In this case the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken . Check all the leads and connections of the mother board , the tags to the ink cartridge. Also check the mechanical settings of the ink cartridge , if jammed or tight remove motor and manually free the drive before it is set back.
Thank you for using Fixya
Aug 24, 2011 | Epson WorkForce 310 All-In-One InkJet...
I tried to renew my Webroot AntiVirus with Anti-spyware. I ran into a compatibility issue with vista. I uninstalled both the firewall and antivirus, thinking this will help, and now I can not install...
HI There,
I recommend that you use Sytem Restore to go back to a point before the problem began.
1. Click the Start Button
2. Select All Programs> Accessories> System Tools and click on System Restore.
3. Select a point before you tried to install/renew your antivirus and restore to that point.
Your description of what you were trying to do was not completely clear to me so I have to guess. If you were trying to install a different product than Webroot, then you need to completely uninstall Webroot BEFORE you install a different anti-virus.
Also, after uninstalling Webroot, hold down the Windows key on the keyboard and press the R key. A run window will appear. Type in %temp% and hit enter. When the Temp File window appears hold down the ctrl key and hit the A key. All temp files should now be highlighted. Hit the delete key. A message may appear saying Windows cannot delete a file because it's in use. This is normal. Check the box in that window for Skip All similar files and hit ok.
Reboot your computer and then install the new Antivirus.
Good Luck
Aug 26, 2010 | Webroot AntiVirus with AntiSpyware &...
C4280 photosmart printer - printer screen says "Printer cartridge missing or not detected" - I replaced the old HP cartridge that was in when the message appeared with a new HP printer cartridge in but it...
Uninstall the program from your computer. Plug in your printer first replace with new cartridge making sure to remover the film on the cartridge Then plug in patch cord to computer, program should reinstall if need be you may have to have your disk that comes with the printer. Hope this works, Printers are going for very cheap I would suggest buying a new one if this does not work.
Apr 01, 2010 | HP Photosmart C4280 All-in-One InkJet...
Lexmark x85 multifunctional, not recognize cartidrige color
The cartridges are only installed through the printer itself and there is no installation of cartridges through the Lexmark software. You should ensure the Lexmark X85 has the cartridges installed in stand-alone mode. To do so, please follow the steps given below:
1. Push the "Menu" button 10 times, until "Maintenance" appears.
2. Then hit "Select" and "Change Cartridges" should appear.
3. Hit "Select" again. It will prompt you to open the lid and change the cartridges. Please do so.
4. When the lid is closed, the display will ask you if new or old cartridges were installed. If new, it may ask you to align the cartridges and you should do this too.
If it is not noticing a change, remove and reinsert the cartridges about 3 times in a row to re-establish pin connections. If this still presents you with a "Change Cartridge" or "Low Ink Level" message or something similar, try a different cartridge.
Oct 17, 2009 | Lexmark X85 All-In-One InkJet Printer
Printer is not recognising that the cartridges are there
Nov 17, 2008 | Canon PIXMA iP1600 Printer
Computer says there is no ink cartridge
OK guys, I don't know if this will work for you but it worked for me. Here it is:
  1. Uninstall all Lexmark software from Add/Remove Programs in Control Panel.
  2. Reboot the computer as suggested by the uninstall software
  3. Start the ALL-In-One Installer
Now, the first thing the installer does is load the drivers to your hard drive.
4. When the driver is installed it will ask you what ink cartridges you have. Tell it which ones you have and say they are both brand new (even if one is empty or not new). If it asks you to align the printer or print a test page, say no!
After this is complete, the installer will begin to put in the other software (i.e. fax and scan). It will pause and ask you to click next, but do not do this.
5. Press Ctrl+Alt+Delete, select the installer task and click end task to stop the installation process.
6. When you print for the first time, it may ask you what cartridges you have installed again. Just select the cartridges you have installed select the option from the drop-down boxes that say that both cartridges are new.
Hope it helps since it worked for me. Good Luck
Sep 08, 2008 | Lexmark X2250 All-In-One InkJet Printer
Incorrect right cartridge - unsupported cartridge.
I had the same "unsupported ink cartridge" thing going on with hp until I got fed up and uninstalled the hp software and just used my windows devices and printers. Windows will automatically find drivers for your printer and you should be able to choose how much of that software you want to download and install. Eventually I did get some software from hp but I still use Windows fax and scan. When I had a chance to participate in a questionnaire, I made it plain to hp that it's my printer, my ink, my cartridges and I'll do what I want with them. I'll take them out and use them for a planter if I want! In the meantime, I do expect them to print with whatever I put in them. It might not be as good a quality as the original, but it's still my right.
May 27, 2008 | Dell 924 All-in-One InkJet Printer
Printer ink cartidge
Your best bet is to uninstall the Lexmark All In One Center, and reinstall it.
First, you'll need to install the software and driver for this printer:
  1. Make sure you have the regular printer driver installed. If you don't, you can grab it from the Lexmark website and install it.
  2. Next, keep your USB cords plugged in but turn your printer off.
  3. Download the All-In-One Center Software here.
  4. Unpack the archive, open the "Applications" folder, anddouble-click Setup. This will install the application - it can take abit.
  5. Once the application is installed, turn the printer on and try a test scan. If it works, you're good and can quit reading.
  6. If you get an error when running a test scan, don't panic.Reinstall the regular printer driver, using the "Update Driver" optionthat appears.
  7. Restart your computer.
  8. Do a new test scan. This should bring up the All In One Center'sloading screen, which will start searching for programs (this canreallllly take a while). When it's done, everything will be workingbeautifully again!
Then, hit Lexmark's site for the Setup Sheet and User Guide available here.
Mar 06, 2008 | Lexmark X1270 All-In-One InkJet Printer
Scanner/Director problems since installing new ink cartridge
Dec 28, 2007 | HP PSC 1210 All-In-One InkJet Printer
Ink problems
Your printer an " original ink " manufacture by lexmark printer don't use genirec printer connot detect.
Dec 11, 2007 | Lexmark X5150 All-In-One InkJet Printer
19 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
