Question about Dometic Rooftop RV Air Conditioner
Thermostat probe position for a 7000 Coleman AC
    Genius:
  • 1,036 Answers
You should be able to ask the customer support at Coleman, as hey can send you the instalation manual for future reference -
Just click HERE or Email to
consumerservice@coleman.com
Thanks for using Fixya!
Posted on Jul 06, 2008
No fan when ac kicks on Ihave a eb15b funace with a coleman ac
The heat will normally use a low speed on the fan, & the AC along with the fan switch on the thermostat will use the high speed. The thermostat turns that high speed on when there is a call for cooling & is the same switch if you were to manually turn the fan from auto to on. Try turning the fan on @ the thermostat. If it works, then replace your thermostat. If it doesn't, it could be a bad fan speed, a bad fan relay on a control board or external relay, or a loose or broken green thermostat wire.
Apr 14, 2014 | Coleman Home Electric Furnace Eb15b/Eb15d
COLEMAN SHROUD REPLACEMENT 7000 SERIES
If you Google airxcel.com, you should get some options. to get either their literature or tech support and they should be able to help you.
Apr 15, 2013 | Coleman Air Conditioner Shroud Rv Roof Top...
I have a coleman super mach a/c thinking of buying a 2 kva gennie **** need to know if it will run a/c 7000 .we dont know the watts on the a/c
Best to call or e-mail Coleman and ask. You need to have a 15% power cushion available for the A/C when the compressor comes on as it creates a slight power surge. Have the Genie power supply specs handy.
Aug 27, 2012 | Coleman Heating & Cooling
Where can i buy a thermostat control box for a coleman 7000 rv air cond
COLEMAN R.V. AIR CONDITIONER SERVICE AND REPAIR QUESTIONS
COLEMAN R.V. PRODUCTS
GO TO rvcomfort.com
Click on RVP (RV PRODUCTS)
Click on type of AC, if you can’t find the information you want there,
then click on contact us on the Green Bar.
You can get Service Support or Email address and Phone numbers.
Oct 10, 2009 | Heating & Cooling
We have a Mach III coleman AC unit... a little
Sounds like the evap coil is dirty or its low on freon.
Aug 31, 2009 | Dometic Rooftop RV Air Conditioner
Coleman (RVP) 7000 AC unit compressor problem
I had a problem with my coleman mach 3 AC, we were at an RV park up at lake shasta CA and the fan would stay on but the compressor would come on for a few seconds and then trip off. It was the motor overload relay on the compressor that was tripping. the RV park was old and apparently the wiring to the panelboard at the RV park was too small, when you are drawing a lot of current there was too much voltage drop across their line, to make up for this the motor tries to draw more current and heats up the motor overload and it trips off. I solved this problem by buying an autoformer from Camping World, it senses a voltage drop and automatically boosts the voltage.
I am now having a seperate problem, the compressor is either locked up or has too much back pressure and trips off the service breaker when trying to start. The only solution I can see with my current problem is to replace the entire unit.
Oct 07, 2008 | Coleman Mach 15 Air Conditioner
Need to find schematic on coleman 7333c886 ac
http://www.rvcomfort.com/rvp/tech_info/manuals.php
This is the web site for Coleman AC's from RVP. Go under the service manual for the 6700, 7000, 8000 and 9000 series air conditioners and they should have everything that you need.
Hope this helps,
Jeff
Jul 15, 2008 | Coleman Mach 15 Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
135 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
