Question about GE GSD1180X Dishwasher
Leaking water I have a dishwasher that leaks water from the front left corner during the wash cycle
  • 734 Answers
dishwasher leaking might be due to either of these causes, check these:
Main tub seal
Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom
of the dishwasher, the following instructions probably apply to you.
But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the
entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from
leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher,
remove the:
* Lower rack
*Spray arm
* Spray arm support
* Wash/drain impellers
Then try the seal out of its housing and replace it.
Door gasket or seal
Over time, door gaskets and seals harden and lose their ability to seal properly.
You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve
The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the
rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten
or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues
to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the
dishwasher, and replace the valve.
Hoses
Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the
leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
Posted on Dec 12, 2008
3 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: The dishwasher is leaking in the front left
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
Posted on Sep 29, 2010
  • 9 Answers
SOURCE: Miele g841sc dishwasher leaks
Typically the machine only uses 5-6 quarts of water, If you're floor is getting 1 or 2 quarts check for a loosly connected intake or drain hose. I've never seen any overflow drain on a Miele. It only fills the bottom of the tub. The machine uses a logic program that continuously checks the level of fill and drain by water pressure weight so it always runs with proper amount, even if your intake pressure is weak. Now, If you add too much soap then the bubbles can carry a few ounces over a worn door seal. If the seal is damaged then more spray arm water can run down the front of the machine into the float pan. But after it gets less than a pint of water the drain float will start thr drain pump and shut-off the machine controls and alert you. It won't let you run the machine until the water ( and the problem) is gone. Call Miele for help.
Posted on Apr 20, 2008
Front loader leaking underneath in the back corner on the left hand side
If its leaking during the fill cycle, its one of the water valves (solenoids) or associated hoses, loose clamps, etc. If its leaking during draining its the drain hoses, pump, clamps etc. Easiest way to tell. Pull it out, if you can remove the back, run it and look for the leak. Just don't touch anything while its running, you don't want to lose a finger or get electrocuted.
Aug 06, 2014 | Samsung Front Load Washer Control Board...
How to fix door leak in ASKO D3231 dishwasher
Almost sounds like the machine was dropped and is out of square. Can you take it out of the install location and check the squareness of it on the drum and the rails? Also if you take it all the way out of the cabinet, you can see the other hinge locations and check them.
Jun 11, 2014 | Asko Dishwashers
Water leaks during wash cycle lower door corners, frididaire fdb750rcb0
Leaking Dishwasher
heatman101
Feb 03, 2011 | Dishwashers
Leaking water on spincycle
I have the same problem with my washer. The problem just began a few weeks ago. It is splashing out the front left corner of the tub and running down the inside of washer and then leaking out the bottom of the frame. It is just enough water to be annoying. The washer is about 6 years old.
Model: FAV6800AWW
Serial: 11277017EG
Any ideas??? Help!
Jul 27, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Our washing machine started leaking lots of water during the fill and empty cycles. Water pours out of front bottom left corner. Any ideas as to what is wrong?
My Maytag Ensignia washing machine leaks large amounts of water when filling and during spin cylce. What could be wrong?
Jan 04, 2010 | GE WSXH208A Front Load Washer
Dishwasher leaking
just an idea...if i'm understanding you correctly,could the door seal be creased there or folded over by use and age to permit this to happen? cause you said nothing is missing
Aug 28, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
When the dishwasher is finished the waters still left at the bottom and it leaks while it's washing
Reduce the amount of detergent used,observe it during wash cycle, find out where the water leaks from. it might be through door gasket replaced it.
Aug 13, 2008 | Asko Dishwashers
Leaking dishwasher
call the manufacturer, some dishwashers have a lifetime warrantee against leaks
Jan 31, 2008 | Maytag 24 in. MDB8600AW Jetclean II...
Dishwashers Logo
308 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
