Question about Brother ML-100 Typewriter
Brother ML100 Lift-Off Correction Tape won't lift off
I have the actual Brother replacement lift-off correction tapes (3015) for my machine--they are maybe 3 years old, but they don't lift off the ink--are they dried out? I tried actually hold them in position to make sure position was not the problem, and I tried both sides, neither was was any ink lifted off.
    Sergeant:
    Champion:
  • 307 Answers
Correction tapes DO have a shelf life, Also make sure the ribbon is moving and very important and this may sound dumb, but I have seen it that the ribbon is not a correction ribon. Are the spool turns orange or yellow? should be. Blue is multistrike and will not correct. Don't know the shelf life of ribbons but they do loose the ability to correct.....Good luck try new supplies..
Posted on Aug 05, 2008
Typewriter does not correct
There is a cam cluster under the ribbon plate that has to move over when you hit the correction key this lifts the correction tape, make sure the lift is not working and that the correction tape is old, and just does not lift off, have seen that...
Mar 21, 2014 | Brother ML-100 Typewriter
Lift off tape
Does the tape lift up far enough for correction? If so check to be sure the dull side of the tape is facing the paper. Then be sure you are using a correctable ribbon, the feed wheel should be either yellow or orange. DickyO
Jun 02, 2009 | Brother GX-6750 Typewriter
This is soooo lame but I cant remember how to put the correction tape in.... :~)
As you face the machine, the full spool goes on the left side of the printwheel carriage and the takeup (empty) spool goes on the right. Be sure that the shiny side of the lift off tape faces AWAY for the paper. The matte side is what does the lifting.
Hope this helps.
Apr 17, 2009 | Brother Office Equipment & Supplies
Typewriter is an ML100 Standard Brothers Typewriter
repost if you are still having this problem
Aug 28, 2008 | Brother ML-100 Typewriter
Ribbon/correction tape
Ribbons:
Correctable film - MODEL 1230 or 1030
Nylon - MODEL 1032
Multi Strike - MODEL 1031
Correction tape:
Lift-off - MODEL 3010 for use with correctable film ribbon & cover-up - MODEL 4010 for use with nylon ribbon and multi strike ribbon.
Aug 22, 2008 | Brother SX-4000 Typewriter
Correction Tape
Two possibilities, one the correction tape is twisted and the wrong side is .facing the paper. The shinny side should be facing you, the dull side facing the paper. Second possibility you must make sure the ribbon is compatible with the correction tape. There are 2 types of ribbons. A correctable one (orange or yellow knob) and a multi strike (blue or purple knob on ribbon cartridge). The lift off correction tape (orange or yellow spools) only works with the correctable ribbon and the cover up correction tape (blue) works with the multistrike ribbon.
Jul 17, 2008 | Brother ML-100 Typewriter
Correction tape
To replace the correction tape:
1) use [SPACE BAR] or <<-¦ to move the carrier to the centre of the platen
2) open the top cover
3) remove the cassette ribbon (if installed)
4) pull off both spools, pressing against the correction tape with your thumbs. Bring it back to a position parallel with the platen and lift it up and out.
5) Pass the new tape through the left guide, behind the ribbon guide, and out thropugh the right guide. The rough (stick) side of the tape should face the platen.
6) Attach the feeder spool to the pin on the left
7) Attach the take-up spool to the pin on the right
8) Turn the take-up spool counter-clockwise until a small amount of white tape has wound around it
9) Replace the cassette ribbon and close the top cover
10) Press 'spider web' key +// to move the carrier to the previous position.
Hope this helps.
Regards TC
Jul 16, 2008 | Brother GX-6750 Typewriter
Brother ML100 typewriter
Make sure that the correction tape is place in the guides one on each side small metal guides, remove ribbon to see, it should be behind ribbon guide (closes to you). Dry lift-off tape only(#3015)
Dec 05, 2006 | Brother ML-100 Typewriter
Brother ML-100 Typewriter Logo
249 people viewed this question
CheckitRight
CheckitRight
Soulvisitor
Soulvisitor
Ron Dufek
Ron Dufek
