Question about Dell 926 All-In-One InkJet Printer
Dell printing problems
I have a dell all-in-one printer 926. I can print pictures just fine on it but when I try to print on regular paper it feeds the paper half way, prints on the bottom of it then says paper jam. There is no obvious paper jam, and I have shook it, used a whole can of canned air in all the area's and it still wont print on regular paper. It used to a while ago, then it just magically stopped. Please help!
  • blonde3 Jun 30, 2008
    I have tried that, and I have tried only putting one piece of paper in the printer. No luck yet, but thanks!
  • blonde3 Jul 01, 2008
    It is set at letter printing. But I really dont know why this is happening because it used to print just fine. one day it just deciced to stop printing on regular paper.
  • 2,794 Answers
Try fanning the paper and see if that works.
Posted on Jun 30, 2008
  • Tim Babcock
    Tim Babcock Jul 01, 2008
    What are the paper settings in the control panel of your printer set at?
  • Tim Babcock
    It could be the feed tired might need to be cleaned. You could try turning the power off and using alcohol and a paper towel and see if that works. It could be the feed tires aren't gripping the paper anymore to feed because they are coated with residue from the photo paper.
Dell 3100cn printer prints individual colors fine. When printing full color picture the paper wraps around the fuser. Tried new fuser - same problem. Any suggestions?
Good old fuser wrap, what a pain. What type of paper are you printing on. Often with full page coverage printing I find that you need to user a heavier bond color printing paper to achieve any sort of good quality and reliability in feeding.
Mar 18, 2011 | Dell 3100cn Laser Printer
I keep getting paper jams. Even if I put one sheet of paper in at a time, the paper keeps jamming and won't print.
Hi
I live in the mid west - during our significantly humid days my 926 wouldn't pull in any paper. I tried a lot of home grown techniques but none worked. I finally raised the air temp in my office which tended to dry out the paper and that worked. Of course your problem could be a broken gear or a worn out feed tire - also something stuck in the printer.
Aug 12, 2010 | Dell 926 All-In-One InkJet Printer
Dell photo aio Printer says Error:2200 Will only feed paper half
Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry.
Keep printer unplugged for about 2 minutes and replug and try a test print.
Also make sure that you have waited long enough for the printer to heat up before giving a print job.
Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing..
Hope that helps!
Aug 26, 2009 | Dell 926 All-In-One InkJet Printer
A dell 3010 which prints fine from webpages etc. but refuses to print from out look and says load plain mpf 024-969 when there is paper in the machine which it was previously happy to print on.... very...
Outlook's printer options are set to load paper from the Manual Paper Feed (mpf) instead of the regular paper tray.
In outlook, select file->print and look for the printer properties button on that dialog box.
Select the paper tray you want to use (or simply uncheck "MPF" or "Manual Paper Feed") and hit OK.
Jun 14, 2009 | Dell 3010cn Laser Printer
Printing too small on my Dell 926
Please check the paper settings of the printer. for example If the paper selected is A3 and the printing matter is on A4 then this problem may occur.
I hope this will solve your issue.
Good Luck.
If my solution proves useful please accept it.
Regards
Arjun
Mar 30, 2009 | Dell 926 All-In-One InkJet Printer
Dell Photo 926 printer no longer feeds paper correctly
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 04, 2009 | Dell 926 All-In-One InkJet Printer
Paper jam followed by printing pics
just check to see if there is any obstructions were the paper is going through, unplug printer cables, press power button for 20 seconds without any cables connected, it will refresh printer memory, connect cables back,try photocopy, if nogo, printer fualty
Nov 04, 2008 | Dell 948 All-In-One InkJet Printer
printer wont print anything. computer says no print documents pending even though ive clicked print a few times and on different programs and internet pages as well. printer will print only if i copy something press print test page from the printer itself but it doesnt print anything from the computer
Oct 15, 2008 | Dell 926 All-In-One InkJet Printer
Paper jam/feed problem
ok i have the freakin same problem and the only i have in mind is that GET A NEW ONE printers are **** these days, makes me wana throw them out of the window lol but if ya need to print something important i suggest u go to the library ahh w,e....
Oct 03, 2008 | Dell 926 All-In-One InkJet Printer
Dell 926 All-In-One InkJet Printer Logo
269 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
