Question about Gateway FPD 1730 17" Flat Panel LCD Monitor
Green line from top to bottom of monitor
Appx 3' from the left side of the monitor is a thin green line and then again at the far right of the monitor.
    Scholar:
  • 144 Answers
Try changing your resolution, if the lines stay in the exact same position (so do not change together with the resolution) this might be a mediacentre issue. Press CNTRL-ALT-DEL and see in the processes tab if ehtray.exe is running. If it is running, turn it of by unchecking it and see if the lines disappeared.
Posted on Jul 08, 2008
2 Suggested Answers
inferno45
  • 45 Answers
SOURCE: Thin Green line from top to bottom of screen
Usually the case with this issue is the LCD panel itself. After a certain long period of time, some LCD panels just bug out and stop working. ( not sure why, possibly the way they were assembled and manufactured. For instance the LCD Panel has 8 connectors ((top)) and 3 connectors ((left)) (((Depends on model)))that attach to the main board of the LCD Panel, and on many occasions the thin lines wear and cut and therefore loosing part of your screen. If i explain further how it works i can write you a good explanation, just message me. That is the issue or the Cable connector from the Video Card to the LCD Panel is faulty. Try replacing that or the line will stay there for a long while then eventually your LCD display will begin to show more lines and eventualy Nebula itself. ( unusable )
You can also try repairing the LCD, in some rare cases the only problem when the line shows up is because of the video genesis card inside the FPD. try swapping that out with a known good one and perhaps that will work otherwise eventually the monitor will begin to stop working over time.
Posted on Sep 12, 2008
Picture went black except for partial green and blue lines &2 thin red lines
Vertical scan section circuit fault. Check and replace damaged component/s at its vertical scan output section circuit. If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Jan 17, 2014 | RCA MM36100 36" TV
Samsung plasma 42inch 1 month old has got 1 thin blue line 2 thin green lines from top to bottom on left side of screen
Most likely your control board: The board with the large processor that controls most of the picture formation is bad. Sounds like it is under warranty if it is only a month old.
Feb 23, 2010 | Televison & Video
I have a veiwsonic n3752w LCD TV which is 3 yrs old,the screen on the left hand side as you look at it has a coloured line, pencil thin, and with the colour of green. This green pencil line is about 6...
A LOT OF THE LCD,s have cold solder joints, Inspect it with a magnafiying glass or somethingfor bad solder joints,bad,or burnt caps,or resistors, call ENCOMPASS PARTS DISTURBUTION for parts or service manuals.1-800-638-3328
Feb 15, 2010 | Televison & Video
Kyocera Mita Ecosys PS 1010 all prints have thick and thin line down left hand side A little while back the printer started printing completely black sheets. Fixed by turning off and then on again. Since...
Try cleaning the charge wire. Move the lime green plastic handle from one side of the image unit to the other in the groove. If this doesn't work you'll need a new image unit.$$$$$. note: Make sure green handle is moved completely to the right when finished or black line will occur.
Feb 09, 2010 | Office Equipment & Supplies
Puzzles 130 Too Many Queens 5 --- 132 Princess's Escape
puzzle 130:Assuming on a chess board 8x8 that each square is numbered 1-64 top left to right.Place a queen on each of these squares 3,13,18,32,33,47,52 and 62 bobs yer uncle
Mar 09, 2009 | Nintendo Professor Layton & the Curious...
Where is puzzle 120
http://www.wikicheats.com/index.php/Professor_Layton_and_the_Curious_Village_(DS)/Walkthrough#Puzzle_No._078
Go here for all puzzle walkthroughs
Puzzle No. 120 Tap the open manhole above from the Sewers below.
Get the Ball Out! 3: Slide the bottom-right blue block over to the right and drop that lower purple block in the slot with the hole. Now, drop the big yellow block down. Drop the top purple block down one and then reposition the top two blue blocks so they are touching end-to-end directly under the red ball. Raise the left green and the big yellow block up into the center. Slide the bottom-right-most blue block all the way to the left. Drop and slide the other right-hand-side blue block as far left as it can go now. Drop the green block on the right down and into the right-hand nook. Slide one of the top blue blocks to the far right along with the yellow block and the right-hand blue block on the bottom. Drop the red ball all the way down to the bottom row. Move the left-hand green block up into the ball's starting slot and slide the yellow block all the way to the left. Move the bottom-right blue block up and the small purple one that blocks the hole. Now simply put the red ball into the hole.
Jan 04, 2009 | Nintendo Professor Layton & the Curious...
Lines on screen
laptops do not have degausing thats only on rct screens what you have is a pixil problem and the lcd or plasma is in need of repair or replacement, if your laptop is under warrinety i sugjest you bring it in soon.
Sep 13, 2008 | Dell Inspiron 2200 Notebook
Green Line
Hi...there,
Well, there nothing you can do.... You've got a busted panel.
Aug 06, 2008 | NEC MultiSync LCD1765 17" Flat Panel LCD...
Jul 02, 2008 | Gateway FPD 1730 17" Flat Panel LCD...
Green line
sharp is very aware of the panel and main video processor problems.They should give you no problems on the repair.It sounds most likely you have a main video processor problem.
Mar 13, 2008 | Televison & Video
Gateway FPD 1730 17" Flat Panel LCD Monitor Logo
331 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
