Question about Yamaha Mg8-2fx 8-Channel Mixer with Effects System
Tapco MIX60 6-Channel Mixer
I know its not yamaha but i need help.
its a Tapco MIX60 6-Channel Mixer. I need a 6 channel or 8 channel mixer with crossfader and 2 or 3 mic channels.
Is this the right one?
its the cheapest one i seen.
  • 624 Answers
It does not appear to have a crossfader
Check this link for a closer look at the mixer. You can click the "larger image" link and get a really good look at it. Unless one of the knobs are a crossfader, but I always seen sliders as a crossfader. At least you can see it better here.
Posted on Jun 30, 2008
How to connect microphone to Yamaha RX-V365 as a PA system.
Home-theatre receivers don't have microphone inputs. If you want to use the receiver as an amplifier in PA system, you need to use some kind of mic pre-amp or a mixer with mic inputs.
For PA mixer is needed anyway almost every time and all mixers have at least one mic input (with a pre-amp). Mixers have line-level output(s), which you can connect to the analog input of receiver.
Using receiver as an amp in PA has advantage that you have 5 channel amp. When using high sensitive PA speakers (as oposed to less sensitive Hi-fi home speakers), you can get good performance with the power rating of receiver. You could even use 2 separate channels for subwoofers and 2 channels for satelite speakers - but for that you would need a receiver with 5.1 analog inputs and special device called crossover which would divide the output from mixer into low-frequency signal and high-frequency signal which you would then connect to the front and rear analog inputs. But with RX-V365 you can use only 2 channels with analog input
Sep 15, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
Whow i connect my xenyx 1002 mixer to audiophil 2496 sound card
You must connect:
the main out of the 1002, or the ctrl room out of the 1002 at your power amplifier's input.
the line in 9/10 of the 1002 at your 2496's line out.
the cd/tape out of the 1002 at your 2496's line in.
in case of a cd connect it's line out at line in 3/4, or line in 7/8 of 1002
some mic at the mic 1 or mic 2 of 1002.
That's the way you're going to have control for:
the mic level from channel 1 or 2.
cd level from channel 3/4 or 7/8.
pc playback from channel 9/10.
master speakers from main mix or ctrl room.
All the above connections are not absolute and may vary depending on your needs.
In case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Dec 03, 2009 | Behringer Xenyx 1002fx Mixer 10 Input 2...
I have mg124cx yamaha mixer and bose l1 compact. when i conect them together and 2 mic the music sound very nice but the mic sound not right please help
If you are using Compact Channel 1, try Channel 2
If you are using Compact Channel 2 - make sure that the ToneMatch Switch of OFF (down)
Jul 20, 2009 | The Singing Machine Top Load Karaoke...
Yamaha Mg12-4fx 12-Channel Mixer
ok look here on page 21 & 22 of 32
section #5," ST output"
the "st out" will go to the amp you have for the mixed sounds
section #1, "line or mic input"
this is the input for the guitar or a mic , but only one(mic or line ) per input # at a time
Mar 31, 2009 | Yamaha Mg12-4fx 12-Channel Mixer with...
What do i need in a mixer? i want to connect my kaoss pad mini, and kaossilator, and obviously a couple of cdjs, and where do i connect them straight in the mixer or amp, im awaiting my purchase and just...
For dj use, industry standard would be something like a Pioneer DJM600 mixer. 4 channels w/ effects and a mic input. To use kaoss it's best to go into Send/Return input through the effects. By tapping on Send, all sound is sent out to the kaoss pad, and comes back into the mixer into the Return inputs. By doing this you can have the kaoss pad on sitting next to the mixer ready to apply effects all the time. Then connect the master outputs from mixer into your amp, or straight to powered speakers. Kaossilator is more of an instrument than effects unit, so plug in to channel 3 after your 2 cdjs in channel 1 and 2. You still have a spare channel left. I use 2 x 1200s and 2 x cdjs with kaoss pad through effects channel in this way. A 4 channel mixer is plenty.
Mar 25, 2009 | Korg Mini Kp Kaoss Pad
I need to know where you plug the guitar cord into the mixer
you plug it in to any channel you want just lick a mic.
there you go DFD
Mar 18, 2009 | Yamaha Mg102c Stereo Mixer
My Behringer DX626 Mixer got beer spilt on it, and i got it back from repairs today, but it seems as channel 2 / the crossfader still doesnt work. e.g i have crossfader in the middle, and both channel 2...
sounds like the beer short circuited the equipment, the people who tryed to fix it didnt do a good job seems like, try taking it apart an use a cue tip an find any beer fragments that could remain in the unit, that mite be the problem
Oct 24, 2008 | Audio Players & Recorders
If you don't want to spend much money and you are not using it in a professional setting, this might be the right choice for you. But only you can make that judgement. Just remember, you get what you pay for. Cheap price means not a lot of quality. There are no exceptions to that when it comes to electronics. If I had to guess, I would say it was probably made in china.
A good mixer might cost over $500.
I hope that helps you decide.
Jul 01, 2008 | Yamaha Mg8-2fx 8-Channel Mixer with...
Whats a crossfader
The cross fader switches the source from one input to the other input. D.J.'s use them to fade from one song into the next one they are going to play when using 2 different turntables or 2 different cd players..
You did say in your question that you needed a crossfader.
Hope this helps Brittany.
What's the 721 stand for?
Yamaha Mg8-2fx 8-Channel Mixer with Effects System Logo
287 people viewed this question
Top Yamaha Audio Players & Recorders Experts
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
