Question about Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned
Ryobi TP30 straight shaft line trimmer convertible - drive shaft disconnected from motor
The drive shaft (internal shaft inside the housing) was not turning when I put on a brushcutter attachment. I put it on my bench and was able to pull the shaft out of the casing. Can I fix this? Or do I need to get a new trimmer?
  • 163 Answers
Check both ends of shaft, they're usually a hex or torx head. sometimes the can strip or even snap off. if you find noticable damage replace the shaft
Posted on Nov 29, 2008
What is oil to gas ratio for a Ryobi TP30 pull start trimmer?
The Ryobi TP30 also has the model number RY52014. This 2-cycle engine uses a 50:1 gas to oil ratio. That means that for every gallon of gasoline, you need 2.6 oz. of 2-cycle engine oil. This information is available on page 9 of the manual. Manuals Lib has the manual for the TP30 trimmer here: https://www.manualslib.com/manual/143217/Ryobi-Ry52014.html .
I hope this helps.
Jan 29, 2017 | Ryobi Garden
Is it possible to fit a brush cutter head to a ryobi rbc30cet line trimmer
Is it a straight shaft? If so measure the inside of the blade and fit the arbor to your trimer.
Aug 17, 2010 | Ryobi Garden
My TP30 Ryobi weed eater turns and stays on while
You have a hairline leak in one of your hoses or a small gasket under primer bulb.
Jul 05, 2010 | Ryobi Factory-Reconditioned 30cc 18" Gas...
I strip the cable inside my lawn trimmer it would turn my cutter below. Is this something I can repair or must I take it to shop?
Hi and welcome to FixYa. I am Kelly. When you say you stripped the cable I am assuming that your talking about the flexible drive shaft. This can be replaced at home. However,.... ou did not state if this was a gas or electric model. At the moment I am assuming it is a 25cc Gas trimmer. To replace the flexible drive shaft the motor will have to be unmounted from the drive shaft housing. It will have 4 flat sides on each end that must mate correctly into the slots of the motor and the power head or you will not be able to re-mount the engine.
With a good model number I can provide you with a source of the replacment parts and probably what mounting hardware that has to be removed to change the fl;exible drive shaft.
Thanks for using FixYa.
Kelly
Jun 15, 2010 | Ryobi 15" Electric Factory Reconditioned...
I have a Ryobi RLT 30CESA with the strimmer attachment. What do I need to fit a Brushcutter blade to it
I would not put a brushcutter blade on this unit. The curved shaft quik disconnect may not hold up to the shock torque created by the brushblade. It may damage the drive shaft since it is a curved shaft quik disconnect model. You may have to purchase a straight shaft trimmer to get that job done.
Oct 02, 2009 | Garden
Installing new string line for Ryobi 4 cycle straight shaft s430
Go to www.managemyhome.com and download a free copy of the onwers manual.
Jul 09, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
The motor want turn the attachments i.e. string on the trimmer or blade on the edger
there is definitely a problem in the drive shaft. check to make sure there's nothing blocking the mal and female ends. if there is, clean it out and lubricate it so that the male will attach to the female slot. also check to see that both ends are not stripped. if the motor portion of it is stripped, which most liekly is out culprit, then it needs to be replaced, or you need to get a new trimmer. if you do, i recommend the Ryobi model CS26 gas trimmer.if the atachment shaft is stripped, the the attachment needs replacement. if you replace the motor portion you need not lubricate the attatchment slot. if the attachment is stripped, it needs to be replaced, but im quite sure the female end in the motor shaft is our problem. it could also be broken inside the shaft. make sure nothing falls out if you hold the attatching ends to the ground.
May 31, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
My Ryobi 132r don't work
THE MOTOR HAS PUSHED BACK INTO THE INTERNAL HOUSING. YOU CAN DISASSEMBLE THE HOUSING AND FORCE THE ELECTRIC MOTOR TO IT ORIGINAL SET UP BUT OVER TIME THE MOTOR WILL KEEP MOVING BACK. THE COOLING FAN WILL BEGIN TO GRIND ON THE HOUSING. THE PLASTIC, HOLDING THE MOTOR IN PLACE,WILL BREAK DOWN AND PUSH AWAY FROM THE ATTACHMENTS.
Sep 30, 2008 | Ryobi 15" Electric Factory Reconditioned...
Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned Logo
773 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Nick Olsen
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
