Question about Asko D1716 Built-in Dishwasher
Asko Superior 1473-262 Dishwasher
Hi there, I was wondering if someone could give some advise relating to my Asko dishwasher.
I have just replaced the water inlet valve, there are two electrical wires which attach to, two spade terminals, on the inlet valve itself, my question, is it imperative individual wires are connected to their correct terminals?? if so, how can one test which is the correct terminal??
If someone can help me I would be very appreciative,
Cheers Brian
The brown wire mounts toward the front of the dishwasher, and the green wire to the back spade
Posted on Jul 24, 2008
Our Asko D3450 is no longer heating up. We talked to a tech and they said the problem could be the thermastator. We have a new one but I have no idea where it will go. Any help appreciated, thanks!
Check your heating element..
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Aug 26, 2010 | Asko 24 in. D3450 Dishwasher
F2 error message after dishwasher backed up when draining. Asko brand.
Hi
Thanks for using FixYa. Error F2 in your Asko Dishwasher means high water level. This error occurs due to plugged/bad water pump and/or a bad inlet valve. If the water pump and/or water inlet valve are bad it should be replaced to resolve this issue. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 26, 2010 | Dishwashers
The top rack on my Asko D1796 dishwasher is defective
call manufactuerer and ask or a good appliance parts and repair they usually are on a spring clip and you just replace the whole roller
Dec 25, 2009 | Asko 1385 Dishwasher
Asko Dishwasher insulating liner (sound or heat? not sure)
This is insulation to retain heat as well as sound dampening. If you are in the south where it is rarely cold you can get by without it save the noise increase. If it gets pretty cool then operation will be severely affected. You can use any insulation method available to you to accomplish the task. Styrofoam, cork, fiberglass. If cost is no object the material for putting in car doors works nicely. I've seen them so insulated you cannot hear them running at all.
Eric
Dec 23, 2009 | Dishwashers
ASKO D 1796 NEEDS COMPUTER BOARD
FIXYA does not know of any used appliance retailers . check with a local repair shop .
Aug 04, 2017 | Asko D1796FI Built-in Dishwasher
Asko Dishwasher 1473 - 262
The sound is the drain Pump I believe ,it turns on to make sure the unit is clear of problem so it can re cycle and start again.
Jun 12, 2008 | Asko D1716 Built-in Dishwasher
Dishwasher Asko D 1776
you may need to reset the inlet time on the board do you have the instuction book,turn the power on then press the fifth button five times within 15 sec then press third button normal wash this should fix your problem
Apr 06, 2008 | Asko D1776 Stainless Steel Built-in...
Asko D1716 Built-in Dishwasher Logo
456 people viewed this question
Top Asko Dishwashers Experts
Owen Barnes
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
